Has been displaying OE and now won't work ? - Washing Machines
OE error please
There may be a few different reasons why the OE error code can display on your washing machine. Is it the LG washer getting the OE error code? The OE error code on the LG washing machine display is an indication of a NO DRAIN issue. The 3 issues that may cause this fault code is a bent drain hose, the drain pump filter is blocked, or the drain pump may have foreign objects lodged in it making it unable to drain. All these issues can cause your LG washer to display the error code OE. With all these different reasons, checking all 3 components will clear the error and fix your LG washing machine.
Oct 29, 2017 | Washing Machines
Lg d/washer about 8yrs old Oe code. Checked grey wire thiery. Cleaned hose filter etc. Was working fine moved house.Whats next.
A drainage problem causes "OE" to be displayed on the digital display panel. The drain hose is likely kinked, clogged or frozen. Inspect the hose and remove kinks. Unclog the hose, if needed. Replace the hose if the problem is not resolved. If the dishwasher still does not drain,
Feb 23, 2015 | LG Washing Machines
What does 'OE' display mean after washing circle?
The LG error code OE simply means "the pump is blocked".
A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain.
Sep 12, 2014 | Washing Machines
Water won't drain and it says oe
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Aug 10, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
THe machine won't rinse. Displaying a "OE" symbol
Kevin
Jul 26, 2011 | LG Washing Machines
We had a short in the wiring where the dishwasher plugs into the wall. After fixing the wiring, the dishwasher now has a message "OE" when I turn it on.
Hi
Thanks for using FixYa. Error OE in your LG dishwasher is a drain error, which is displayed when the unit won’t drain out in spite of 5 minutes drain operation. To resolve this issue you’ll need to check the drain hose for any blockages, also check the wiring connection to the pump. If still the issue is not resolved then you’ll have to replace the drain pump/motor. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 14, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
I am getting an OE code on the display. I changed
Make sure you check to see if anything is caught inside the drain line, or the bottom bellow (black hose that connects from the tub to the drain pump/motor.)
Mar 25, 2010 | LG WM2487H Front Load Washer
I have an OE code on my WM1814CW LG Washer
OE code - Check for clogged drain filter on end of hose, bent or clogged dain hose. Make sure hose doesn't go too far down drain pipe.
Hope this helps
Bob
Jul 06, 2009 | LG WM1814CW Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
