Question about Garden
What causes the blade not to engage when you put it into mowing but then after a few minutes
  • 41 Answers
SOURCE: blades not engaging
Tim, first turn key on engage and disengage blade button. See if you can hear the clutch making a clicking noise. If not check switch., if not your problem is in the clutch.
Posted on May 29, 2009
wadembly
  • 462 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
SOURCE: LTX1000 42" 18HP Kohler - Blowing fuse after 2-4 min mowing.
i hav a 18hp ohv eng. back fires and gas is coming out of muffler.
Posted on Jul 18, 2009
SOURCE: Craftsman zero turn - blades won't engage
The PTO switch contacts to operate the clutch that starts the blades is defective. I have replaced mine and the new one just failed again. Sears must know this is a defect problem but so far they are quiet about the problem
Posted on Nov 24, 2010
H2_Brad
  • 425 Answers
SOURCE: electric blade clutch won't work and battery went dead
If you have a new battery and it went dead that quickly I would check the charging system on the mower engine. Many of them use a voltage regulator and if it goes bad it will not properly charge the battery. Get the engine running (do not engage the PTO) and use a multimeter set on DC voltage. Place the multimeter leads on the battery and you should see approximately 13-14 volts DC at the battery terminals when it is running. If less then that then it's a problem with the charging system and further tests would be needed to figure out if it is a bad regulator or charging coil.
Posted on Aug 24, 2012
Testimonial: "I think that's it, the clutch was just a symptom of low voltage maybe. checked two leads from the alternator and got 31 volts ac from each. Hoping then it is the regulator."
Craftsman Model Number: 917.377151 motor shuts down when blades engaged
The engaging of the mowdeck is cause an excessive demand of your engine. From that, we can assume your problem is in the deck. Since the power drive is all about belts and it threw the belts, from your information I can only deduce that either an object (stick-wood-rock) has wedge into a position that has stopped rotation of the blades. Also, each blade has a pulley/spindle. These have bearings which must be free to rotate.
A bearing failure or seizing can also cause the problem you report.
Follow safety rules in your manual to insure the engine cannot start. Attempt to rotate each blade to check for free rotation. If the do not you most likely will need to remove the mower deck and check further. An obstruction or seized spindle should be easy to determine and sit repair is easily possible.
Sep 03, 2016 | Craftsman Garden
It has been shutting down and it mows for a few minutes and shuts down. It shut down three or four times before I could finish. Could it have to do with the arm that engages the blades?
it could be. check all the connections be sure they are tight. maybe change the spark plug. it kind of sounds like the spark plug or coil is breaking down at high temperatures. or the fuel pump is getting clogged.
Jul 29, 2016 | Garden
We have a John deere 314 lawn mower. After you mow a few minutes there is a loud pop and the mower stops running. After it sets just a few minutes it will start right back and mow a few more minutes and...
Julie this sounds silly but try and run it with the exhaust and muffler removed. If it ticks over and then stops when it's engaged for a few minutes it sounds like its suffocating.
Sep 07, 2013 | Garden
Blades fail to engage (using pto) after tractor has been running for awhile.
bad wiring to the charging system or the alternator is bad
May 03, 2012 | Garden
Blades will not disengage
SOUNDS LIKE THE CABEL IS BAD IF IT HAS ONE OR THE ENGAGEMENT IS BENT
Oct 08, 2009 | Craftsman Garden
Mowing deck makes ticking noise when blades are engaged.
A FEW THINGS TO LOOK AT ARE ,1THE PULLY SHIELDSMAKE SURE THEY AREN'T BENT TO CLOSE TO THE PULLEY'S.2 THE PULLEY BEARING'S MAY BE WORE OUT AND TO BREAK .3LOOK UNDER THE DECK TO MAKE SURE YOU DIDN'T GET SOMETHING TRAPED IN THE CUTTING DECK.HOPE THIS HELPED.
Jun 11, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
sounds as though you are on the right track
but be sure to check the wiring directly from the electric clutch on the front of the motor back to the switch
a wire could be pinched in the frame and shorting out intermittingly
look around and find those wires and move them around and look for chaffing and tightness
and what you could also do is to unhook the clutch at the connection to it at the front of the motor and engage switch and ride around and see if fuse blows and if not you may have an electric clutch issue
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Wicked noise
have the blades been removed and replaced. if so perhaps blades put back on wrong?
May 23, 2009 | Garden
Blades won't engage
I have a john deere 185 was mowing and my blades Quit turning with the switch still on,any quick fix?
May 16, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
