Question about LG Televison & Video
My lg DVD receiver is too dim to read what setting it is on from across the room. The remote does not have a dimmer option on it. It is an HE903paw
4 Suggested Answers
SOURCE: 2 lg dvd players in same room,can I change remote frequency
I have new Panasonic DVD & Combo units stacked on top of each other and had the same problem, until last resort I read the manual and and easily changed the frequency on the DVD unit and remote, you can have up to 3 Panasonic units with different frequencys close to each other.
Posted on Oct 22, 2009
SOURCE: LG ht902tb DVD receiver
nuk me lexon disc dvd+r
Posted on Aug 23, 2010
  • 5384 Answers
SOURCE: I lost the Remote Controller to my LG DVD HT353 Receiver while moving home. Don't know its number. Any help can do. Lemmuel_1
I found the HT353 replacement remote available in the UK here: http://www.avuk.com/product_info.php/buy/Original-LG-Remote-Control/model/HT353/products_id/253?osCsid=104768add3e62be2669abc8c5b608fb4 . I also found a remote, AKB36087610 , for the LG HT353SDA0 at http://www.electronicadventure.us/Merchant2/merchant.mv?screen=prod&store_code=EA&product_code=AKB36087610 . It's also listed at Encompass Parts: http://www.encompassparts.com/item/8006951/LG_Electronics/AKB36087610/Remote_Controller_Assembly . Remotes.com also lists the AKB36087610 remote: http://remotes.com/remotes/servlet/rs?a=gmi&smodel=AKB36087610&brand_pn=ZENITH_AKB36087610&mode=large&uuid=13446606264530 . Use the picture here to tell if this might be the correct remote.
I hope this helps.
Posted on Aug 11, 2012
Kendal fan/light remote UC7208T doesn't dim
If you have CFL bulbs they won't dim. There should be a switch to change remote from CFL to incandesant light inside the transmitter. You'll have to match settings with settings in receiver.
Nov 25, 2013 | Dryers
Instrument Panel Lights
Daytime headlight issue ? No , no sensor behind the front bumper . No Daytime time head lamp issue , doesn't turn on the instrument panel light's . This is more then likely a remote dimmer module problem .
Interior Lights Dimming Circuit Description (Pontiac)
When the park lights are on, battery positive voltage (B+) is applied via CKT 32 (YEL) to the remote dimmer module. The interior dimming switch in the lamp dimmer switch is a variable resistor which applies the dimming input via CKT 44 (DK GRN) to the remote dimmer module. The potentiometer in the lamp dimmer switch cannot provide enough current in order to operate the incandescent lights. The remote dimmer module amplifies the current, applying a variable voltage to the incandescent lights. As the amount of current increases, the lamps become brighter. As the amount of current decreases, the lamps become dimmer.
The radio, heater and A/C control assembly, instrument cluster, and passenger climate control each has a vacuum fluorescent (VF) display. When each module receives an input that the ignition switch is turned to the RUN position, each module activates the VF display at the full intensity. When the park lights are on, the radio receives the dimming level from an input on CKT 8 (GRY). The radio then relays this information to any other modules with VF displays. All modules with VF displays then adjust the dimming level of their VF display in order to match the level of the incandescent lamps.
May 16, 2017 | 1998 Pontiac Bonneville
RCA dvd player DRC6338T remote not working
The remote can be tested--shops use a card which when remote is pointed at and buttons pressed--a strip on the card lights up.
Many digital cameras in a dark or very dim room will react on the display screen in the same way--faint flash will be seen if remote is working.
If remote is tested and found to be good---try it very close to unit--you if no response at all and remote is good have a bad remote receiver in the unit(make sure the receiver lens is not blocked or dirty).
Apr 24, 2012 | RCA DRC6338 Portable DVD Player
I think our house is haunted. Just installed
See my post below: (Sorry, we're in the same boat!) Hunter ceiling fan with remote, have 5, 4 are seriously impaired! Lights dim to half strengh after variable time 10 seconds-30 minutes. And lights or fan turns on randomly (come home & fan on full blast), and one in which the lights won't dim (just blinks when try to dim)! Hunter "kinda" admits there is serious problem with remote but doesn't have a solution. Tells people to try changing to different code/channel on the remote due to possible interference (pain in **** to change code on ceiling base!), was totally ineffective. Then replaced receiver in ceiling base (another total pain) in 3 fans with new ones sent Hunter, still totally useless. Hunter's suggestion, don't use the remote, just use the pull chain. If I had wanted a pull chain fan, I'd have bought a pull chain fan. TOTALLY USELESS! Moral of story: If you want a remote ceiling fan (my friend found out that all their remotes are made by the same company in Taiwan), don't buy Hunter!!!!!
- P.S. I found a "Kinda"- fix for the lights dimming to half strenth. After turning on the lights, wait 1 second, then dim lights slightly, they will then stay on the strength that you dim them to. - P.P.S. When I changed the receiver in the one where the lights won't dim, it "solved" that problem...Now it has the same problem as the others, lights or fan turn on randomly!
Mar 20, 2010 | Hunter 52" Ceiling Fan With Light And...
No sound on analog channels
I came across this problem yesterday. Digital channels sound... Analog no sound. press the tv button on your remote to change it from DTV/TV
go to any channel you want. press the menu button then go along to Sound setup. In there you will see quite a bit. I went down to an option in there.. it was sound input or something similar. this was set to BG I changed this to 'I' and the sound came straight back on. Hope this helps you out.
Little Dish Fitter
Sep 02, 2009 | LG DR787T DVD Recorder
Fan and dimmer remote does not work
The remote is a Hampton Bay remote that should dim the light and fan on and off. I replaced the battery and do not have a red light when I press the button. Light and fan does not turn off with remote.
Mar 01, 2009 | Universal Remote Control Hampton Bay...
Dec 28, 2008 | Televison & Video
I've hooked up my LG 47" 1080p widescreen to a LG HE903PAW audio receiver / 5 disc dvd player with upscaling capabilities. I have tested the speaker system and everything's connected properly....
I was talking with LG on virtually the same problem. I have a samsung blu-ray player hooked up via HDMI. Even though the blu-ray is outputting 5.1, 6.1 or 7.1, the LG is only outputting 2 channel unless you switch to pro logic. LG states that this is a known problem and that you are to return the system to where you bought it for a replacement. Call the 1-800 number and they should give you the same answer.
Nov 23, 2008 | Audio Players & Recorders
Plasma tv with suspected SAP turned on
Hi
Try going to the audio menu then audio language and see what your settings are also try going to the options menu then caption/text and see what your settings are also in the options menu go to caption option. if that doesn't help try the same thing with the dvd player. hope this helps.
May 28, 2007 | LG 42PC5D Television
Televison & Video Logo
29 people viewed this question
Computer Repairing
Computer Repairing
