Question about Microwave Ovens
Have an amana countertop combination oven
I have an amana countertop combination oven acm1580ab. I was using the microwave it shut off on its own and i cannot get it to come back on. Nothing works now. Used in my motorcoach less than 20 hours. I checked circuit breaker and plug in they are okay. It is something inside of microwave. Does this microwave have a fuse inside? is it something bad and worth fixing?
The microwave was in use and when i press stop the microwave never come back on can you help me slove this problem
Posted on Jul 27, 2009
Why doesn't it turn on?
The internal fuse may have opened.
Sep 25, 2015 | Microwave Ovens
How to replace light bulb in combination oven model acm1580ab
Cannot find your model number, please provide make and model.
Jul 23, 2008 | Amana Microwave Ovens
Microwave shut off completely
Microwaves have an inline fuse inside that fatigues over time.Take the cover off,follow the power cord after it enters the housing to locate the fuse.
Mar 14, 2012 | Amana MVH220W Microwave Oven
Oster OM1201E0VG countertop microwave
It sounds like the thermal fuse may be defective, or the fan is not running, or the magnetron is getting to hot. If there are any heat issues the thermal fuse will cut power and reset in 5 minutes.
Mar 07, 2012 | Oster OGB61101 Microwave Oven
Amana convection/micro #AMC1580AB popping SOUND and sparks
That would be ACM1580AB, just in case that was throwing off your searches.
If the noise came from within the oven cooking cavity, it may be grease of food on or behind the waveguide cover (called a canopy in this case) which is fastened to the wall of the oven with two screws, apparently.
The cover and the area behind it must be clean.
If the canopy is burned or damaged it must be replaced.
If the sound was coming from behind the controls or on the right side under the outer cover, then it is probably a bad high voltage rectifier diode.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
(even if the magnetron passes these tests, it can still be bad. If you have high voltage and the diode is good, assume the magnetron is bad)
You can find helpful exploded view diagrams and order parts by entering your full model number here.
The actual service manual (with installation & operation info, too) is free to download here.
Your owner's manual is availabel free here.
Sep 26, 2009 | Amana ACM1580 Convection Microwave Oven
Amana AMC1580AB convection.Micro electric popping spark
Sep 26, 2009 | Amana Radarange Microwave Oven
Which brand microwave oven is best in the market
That kind of depends what you want. Kenmore, Whirlpool and Fridgidare are the best value. Maytag, Amana, Jenn Aire are a little higher end. LG and Electrolux are the higher end. When it comes down to it most of them have some of the same components. Keep it simple. The more bells and whistles, the more likely it won't last. Sometimes the cheapest ones are the best. Personally, I have a countertop unit by Emerson. 10 yrs old, no problems.
Mar 25, 2009 | Samsung 80092 Microwave Oven
I want to see the clock on my microwave amana rcs820bl
Set the clock?
Normally one of these combinations will work:
CLOCK > 1 > 2 > 3 > CLOCK
CLOCK > 1 > 2 > 3 > START
CLOCK > CLEAR > 1 > 2 > 3 > CLOCK
CLOCK > CLEAR > 1 > 2 > 3 > START
Please write back if you need further help.
Sep 07, 2008 | Amana Microwave Ovens
Panasonic NN-T994SF 1250 watt countertop microwave stopping
From my research, this sounds like a fairly new model. Consult your user's manual to see if this is a user, or common issue. If nothing is descibed then I would seek possible warranty service, or dealer replacement
Jun 03, 2008 | Panasonic NN-T994SF Microwave Oven
Amama 2.0 Cu ft. Radarange Microwave model# UXA3036BAB
This model does not list Stainless Steel as a feature. Stainless Steel is used in the interior (CAVITY) of a Microwave if it is a Combination Convection/Microwave Oven. The Convection Oven can reach temperatures of 400+ degreesF. This Temperature would MELT the paint off a painted interior.
Stainless Steel can be tested with a Magnet. It will not be attracted or "Stick" to Stainless.
Hope this answers your concerns!
Thanks!
Feb 05, 2008 | Amana ACM2160A Microwave Oven
Microwave Ovens Logo
96 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
