Question about Kenmore Dryers
Kenmore elite mixer E1 (I will say error 1 )
Kenmore Elite 600 watts when plugin flash the white light and do not work and says on the mini screen E1
dididsaythat
  • 291 Answers
SOURCE: Error Code E1
got a model #
Posted on Sep 02, 2007
SOURCE: Error E1
I went on another site where I found out that it was a thermistor a part of the heat blower. I will be ordering it for $20 off that site and my husband will fix it.
Posted on Oct 07, 2008
jyackle5
  • 8197 Answers
SOURCE: I constantly got E1 Error code on my Kenmore Elite H3 GAS dryer
E1 error code indicates an open thermistor or open thermistor circuit. A thermistor is a component that relays the temperature in the dryer to the control board. If the thermistor has failed, Error code E1 will be displayed.
You need to call a repair person to fix it.
Posted on Dec 18, 2008
SOURCE: Sud and F35 error in my kenmore elite h5 steam
I got the f35 and suds code repeatedly and my clothes weren't washed, I ordered from Sears the analog pressure switch that regulates the water coming into the washer and the codes went away, the part is esitmately $125.00 including shipping but you have to order from the Sears parts department.If you print a diagram of the washer it is #38 in the diagram and is easy to replace. You can install it yourself and as a female I did not call service to do it.
Posted on Aug 13, 2010
blueextc3221
  • 15935 Answers
SOURCE: what is error code e1?
The E1 displayed indicates the thermistor is open and needs to be replaced.
The connections can be loose but the most likely cause of an E1 error is a bad thermistor.
The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
If you're comfortable and confident in your do-it-yourself skills and have access to a volt/ohm meter you can check and replace this part yourself.
The thermistor is available from the following: www.searspartsdirect.com
Enter your model # in the appropriate box to get a full parts break-down and diagrams.
To access the thermistor see the image below.
Remember to unplug the dryer from power first.
The thermistor will have a black and red/white wire on it.
You can check continuity across it with the meter and if the circuit is open then the thermistor needs to be replaced.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
The thermistor -may- check ok when cool and freak out when warm!
http://media.fotki.com/1_p,wkrsfrgsskrbttbxgtqsskgwtqkq,vi/wbsdwtgwgxwrgbbgsgs/1/1303472/5961857/image6767img-or.gif
HE3 Dryer: http://media.fotki.com/1_p,wbfbgrrwtrrkfttxgtqsskgwtqkq,vi/kgwgwwwdkxkfkkgwgqs/1/1303472/5961857/image7127img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
Kenmore Elite stops early and flashes e1. How do we corect this Thanks Todd
The electronic control detected the thermistor is open. The wire harness connecting the thermistor and electronic control is broken or the connection is loose or the thermistor is indeed open. Measure the resistance of the thermistor then refer to the temperature and resistance table for the normal thermistor resistance values. Click on the link below for the detailed troubleshooting and replacement procedure.
Troubleshooting Error Code E1 on Kenmore Elite and Whirlpool Duet Dryers
Feb 13, 2011 | Kenmore Dryers
How do I take the front panel off my kenmore elite electric dryer to see if their are tech notes about my E1error code? My dryer turns off after only a few minutes displaying and E1 error code. The...
Sep 21, 2010 | Kenmore Elite HE4 Electric Dryer
Has a E1 code
If I remember correctly that means the thermistor is shorted or open on a Kenmore elite model. You can take off that bottom front panel and should find the tech sheet which will inform you what the code means.. The thermistor is located behind the lower panel, then behind that black duct which 1/4 inch screws hold it in. Remember to take the lint screen out before duct can be removed fully. Then once duct is removed you'll see 4 wires connected to 2 different thermostats. White one is thermal fuse and the black one on the right is the thermistor. Unplug power or shut off breaker before going any further. Hope this helps
Jun 09, 2009 | Kenmore Elite 45986 Front Load Washer
My dryer stops in mid cycle and gives me an error code of E1
It is a bad thermistor on the blower housing
http://forum.appliancepartspros.com/dryer-repair/1379-kenmore-elite-e1-sensor.html
Apr 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Error Code E1
replace the thermistor
Dec 20, 2008 | Kenmore Elite HE4 Electric Dryer
Dec 18, 2008 | Kenmore Elite HE4 Electric Dryer
Error codes
Jul 25, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite quiet pak 9 dryer
Error message E1 indicates the temperature thermistor has failed.
Jun 22, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
43 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
