Question about Maytag Kitchen Ranges
My Maytag oven beeps and flashes "bake" What is this deriving from?
huuum
  • 750 Answers
SOURCE: mgr5875qdw
Hello sfgelectric,
Welcome,
You said, your broiler and oven won't work. That you set bake and it beeps and the bake light flashes but oven wont light.
Does the display flash any error codes, or just the bake light?
Fault codes
1. BAKE or LOCK may flash rapidly in the display to alert you if there is an error
or a problem. If BAKE or LOCK appear in the display, press the CANCEL pad.
2.If BAKE or LOCK continue to flash, disconnect power to the appliance.
3.Wait a few minutes, and then reconnect power. If the flashing still continues,
disconnect power to the appliance and call an authorized servicer.
4.If the oven is heavily soiled, excessive flareups may result in a fault code during
cleaning. Press the CANCEL pad and allow the oven to cool completely, wipe out
excess soil, then reset
For most concerns, try these first.
Check if oven controls have been properly set.
Check to be sure plug is securely inserted into receptacle.
Check or re-set circuit breaker. Check or replace fuse.
Check power supply
I'll check the repair manual to see what I can find.
Let me know how it goes.
Perhaps this will fix a glitch.
Huuum
Remember to leave a rating.
Posted on Oct 16, 2008
scottowa
  • 87 Answers
SOURCE: Maytag gas Stove MGR5710 bake oven does not work. boiler works
Usually I always find it's the ignightor. They are not to hard to replace. It's #5 on this looooong link
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=MGR5710ADW&productCategoryId=0124002&brandId=3048&modelName=GAS-RANGE&diagramPageId=00005&componentDescription=GAS%20CONTROLS&documentId=X2906551&backToLink=Return%20to%20Sub%20Components%20list
Or go to http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
enter your model number and it'll kind of show you how to get it apart. Good luck.
Scott
Posted on Jan 23, 2009
jumptrout51
  • 3361 Answers
SOURCE: I have a Maytag model MER5775QAW free standing
Unplug the range open the control panel to access the electronic oven control. Unplug the wires and wait 5 minutes. Replace all wires on the control and turn the power back on.
If this does not reset your oven control it must be replaced.
Your ERC(clock) is bad and must be replaced.
Posted on Nov 09, 2009
  • 87 Answers
SOURCE: maytag MER5755QAB gemini bake light flashes when I
U need a new element
Posted on Oct 14, 2010
SOURCE: Maytag Performa Advanced Cooking System,
says F1 will not stop beeping. unpluged and waited still beeping!
Posted on Nov 15, 2010
Maytag Oven won't work
either you element is bad or the relay on your control will not open , if able check voltage to element and inspect element for defect .
Feb 20, 2013 | Maytag Kitchen Ranges
Maytag oven error with 'BAKE' flashing
upper thermo coupler is probably bad and it wont let the element reach full temp and sets back to default "bake"
Jul 04, 2012 | Maytag MERH865RAB Electric Range
Oven won't bake F-4 signal
God i havent been around i hope you unpluged this unit by now, leave unpluged for a few min's , this will usually fix this problem
Nov 24, 2011 | Maytag Ovens
My maytag gemini oven has been stuck in sabbath mode for months and holding the clock button does not help. It does this everytime we lose power and it stays off for months and will turn on when ever it...
This is from the Maytag website it explains how to cancel the sabbath mode;
To cancel the Sabbath Mode:
Press the Clock pad for three seconds.
Or
After 72 hours, the Sabbath Mode will end.
  • "SAb" will flash for five seconds.
  • The time of day will return to the display.
NOTES:
  • Sabbath Mode can be turned on at any time with or without the oven on.
  • Sabbath Mode cannot be turned on if the keypads are locked out or when the door is locked.
  • Most prompts and messages and all beeps are deactivated when Sabbath Mode is active.
  • If the oven is baking when Sabbath Mode is set, the Bake icon will go out at the end of the baking cycle. There will be no audible beeps.
  • If the oven light is desired while in Sabbath Mode, it must be turned on before the Sabbath Mode is started.
  • When the Sabbath Mode is started, the temperature display will immediately show the set temperature, rather than the actual oven cavity temperature. No preheat beep will sound.
  • The self-clean cycle and automatic door lock do not operate during the Sabbath Mode.
  • Pressing the Cancel pad will cancel a Bake cycle, however the control will stay in the Sabbath Mode.
  • If power fails, the oven will power up in Sabbath Mode with 72 hours remaining and no cycle active.
I hope this helps to return it to normal mode,
GENE
Oct 13, 2011 | Maytag MER6772 Gemini Electric Kitchen...
I HAVE A MAYTAG BUILT IN OVEN THAT WAS WORKING FINE LAST NIGHT AND GET UP THIS MORNING TO BAKE AND I AM GETTING, ITS FLASHING A F2 AND F7 ERROR CODE AND THE ALARM OR BEEPING IS GOING OFF
Hi You have a bad touch pad , there maybe a be a button stuck in , try running your fingers over all the touch buttons but i think the touch pad will need to be replaced as always remove the power before taking it a part
Dec 21, 2009 | Maytag CWE4800A Electric Single Oven
Oven comes on for 5 min then shuts down everything even the keyboard
Same problem here on JKP15WOW1WW. The cycle starts like this:
1) Open circuit Breaker
2) Open oven panel and push ribbon connector to ERC. Replace planel.
3) Close circuit breaker
4) Run to oven, notice clock flashing some time but not 12:00 and start Bake. Bake button beeps and starts bake coil.
5) Within 5 minutes hear a beep and all buttons on panel are unresponsive. Bake continues. if oven light is on it continues to glow. Only button that responds with a beep (and not to clear bake or oven light) is Clear botton.
Rinse..wash..lather...repeat...
Nov 11, 2009 | GE JKP15 Electric Single Oven
Mgr5875qdw
Hello sfgelectric,
Welcome,
Fault codes
Check power supply
Huuum
Oct 16, 2008 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Cannot figure out how to make oven work
Hi, try this and see if will help you. Most of the Gemini models are the same.
To set Bake:
1. Press the Bake pad.
• BAKE will flash.
• 000 will flash in the display.
2. Select the oven temperature. Press the
Autoset 0 pad for 350° F or the appropriate
number pads.
• Each additional press of the Autoset 0 pad will increase
the temperature by 25 degrees.
• The oven temperature can be set from 170° to 550°.
3. Press Bake pad again or wait four seconds.
• BAKE will stop flashing and light in the display.
Nov 20, 2007 | Maytag MER5775Q Electric Kitchen Range
Kitchen Ranges Logo
54 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
