Question about Cameras
My eclipse UCNV1000 is turning itself off and on continually at 10 second intervals. This happened after I inserted an sd card and it wont open up to let me remove the card.
  • 14 Answers
SOURCE: Can not detect sd card
Make sure your card is NOT an SDHC. the HX470x only reads standard SD cards. The largest that I have found is 4GB SD (not SDHC)
Posted on Apr 10, 2008
  • 4090 Answers
SOURCE: Navigon 5100 SD Card problem
I woulod think the data is corrupted or not in ther format the GPS is expecting. redownload the data to the PC desktop and see how it is organised
Posted on Jul 22, 2009
SOURCE: i insert a sd/mmc card in the slotwhich is same as
I have a Memory Card that works in my camera but when it is inserted into the SD/MMC slot it says there is a memory car error. I have intserted my last memory card and it works. What is the problem?
Posted on Sep 11, 2009
SOURCE: SD Card
did you ever find a solution?
Posted on Jul 25, 2010
jayatithapa
  • 83 Answers
SOURCE: i insert new SD card
sd card slot damaged. Change slot with new
Posted on Mar 16, 2011
My wii remote wont turn on. when I push the on button the four lights at the bottom flash a couple of times then nothing happens and it wont recognise it on our tv...?
Try syncing the wiimote to the wii itself. Underneath the SD card cover on the front of the Wii and inside the battery compartment on the wiimote are red buttons. Hold both of these at the same time for 5-10 seconds and then try again
Apr 13, 2013 | Nintendo Wii Wireless Remote Controller...
Dead, power light flashes 10 times then nothing for 4 seconds then flashes 10 times then repeat. This is after I inserted an SD stick.
Unplug,replug the tv about hour later.Tv will,reset itself,back to factory setting.Should have power now.Still have the same problems.The power supply board is dead.That the board,where the power a/c plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Aug 07, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Tomtom1 keeps restarting itself
try resetting it, if that doesnt work, connect your unit to tomtom home. if you dont have tomtom home, follow the link at the bottom.
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
Aug 20, 2009 | Tomtom One XL GPS Receiver
My tomtom720 wont reset. help
  6. The reset hole is located on the bottom of the GPS depending on model.
Jul 25, 2009 | Tomtom GO 700 GPS Receiver
Restore to factory setting
n rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. The only information lost on your device is the clock’s time zone setting. Select your device from the list below to see how to reset it.
Select your device: TomTom GO 940/740/540 TomTom GO 930/730/630/530 TomTom GO 920/720/520 TomTom GO 910/710/510 TomTom GO, GO 300/500/700 TomTom XL IQ Routes TomTom XL (30-Series) TomTom ONE XL TomTom ONE IQ Routes TomTom ONE 30 Series TomTom ONE 3rd Edition TomTom ONE 2nd Edition TomTom ONE 1st Edition TomTom RIDER 1st Edition, RIDER 2nd Edition TomTom ECLIPSE II TomTom DAIHATSU, TomTom ECLIPSE, TomTom TOYOTA Help Not sure which device you have? ico_close.gif Type the first two characters of your device's serial number below to find out.
The rest button is on the top of the GPS
Jul 23, 2009 | Tomtom GO 910 GPS Receiver
My camcorder will only record in 10 second intervals
There is a 10 second limit to the SD card recording. pretty useless, but that is how it somes from the factory
Apr 11, 2009 | Canon Optura 20 Mini DV Digital Camcorder
Continuous mode
i think the frame rate is 1.3 frames per second.
Issue:
How do I set Continuous Shooting?
Solution: Setting Continuous Shooting mode PowerShot SD750 and SD1000.
Continuous Shooting In this mode, the camera shoots continuously while the shutter button is held down. Recording ceases when the shutter button is released. In addition, under the following conditions, continuous shooting can occur at a consistent interval until the SD card is full*.
  • A resolution and compression combination other than 145.gif and 129.gif is selected.
    * If continuous shooting suddenly stops, the SD card may be full.
Continuous shooting is available in all modes except 171.gif[AUTO], stitch_assist_icon.gif[Stitch Assist], coloraccentdropper.gif[Color Accent] and colorswapdropper.gif[Color Swap].
To set Continuous Shooting
  1. Press the cont_icon.gifbutton to display cont_icon.gif.
  2. Shoot the image.
    The camera will continue to record successive images while the shutter button is fully pressed. Recording will cease when the shutter button is released, the card is full or the card does not support a write speed to allow continuous shooting to continue.
To Cancel Continuous Shooting
  1. Press the cont_icon.gif button twice to display single_icon.gif.
caution_a70.gifTo enhance the continuous shooting performance when you suspect the speed has dropped, you are recommended to format the SD card in the camera (Low Level Format) after you save all its images to your computer. note_icon_a70.gif
  • The interval between shots may lengthen slightly when the camera's built-in memory fills.
  • If the flash is firing, the interval between shots will lengthen to accommodate the flash's charging requirements.
Feb 18, 2009 | Canon PowerShot SD1000 Digital Camera
I dont know where to put this
Hi, First insert the micro SD into its adapter which resembles a SD card itself but has a small opening at the bottom to insert the micro SD. The adapter should not b locked while inserting or removin the micro SD. Now insert the adapter in the card readers slot which should be connected to a PC via a USB. If its a card reader then insert the adapter with microSD in the right side top corner of the card reader with the adapters copper pins facing down. OR if u already have slots in ur CPU to insert the SD card install it there, Now transfer files to ur card happily. NOTE: Rename ur device so that next time when u plug it in the adpter n connect it to PC, u wont get confused. Just right Click on the drive icon in ur PC n select rename n just giv any name as u lik. Rate he soln dude Bye..........!
Jan 25, 2009 | PNY 2GB microSD Memory Card
Mustek PVR-H140 shuts down when I insert some SD cards
Yes that's correct newer SD Cards use faster memory chips that are not always compatable, not just with this unit but you can have the same problem with cameras and other MP3 players as well.
The PVR-H140 is quite old now so stick to the older type cards, oh and they dont like being hot swapped, this can cause a shutdown or driver corruption, insert them before turning the unit on.
Jul 26, 2008 | Mustek PVR-H140 Digital Media Player
Wont turn on
It may be the SD memory card causing the problem. I just bought a G7. When I turned it on without an SD card, no problem. I put it my old cheap SD card and it wont turn on. I take out the memory card and battery, then insert the Canon SD card and battery and turn it on, no problem.
Hope this helps someone.
Dec 09, 2007 | Canon PowerShot G7 Digital Camera
Cameras Logo
47 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
