Question about The Health & Beauty
My lights flash continuously and the chair wont move. Im not sure what model it is, its older and was given to me.
dromtonpa
  • 40 Answers
SOURCE: lights just flash on controller and wont move jet 3 wheel chair
Do they flash in series? Like ten flashes then a pause then ten flashes?
Posted on Mar 30, 2009
SOURCE: All six lights blink on my Jet 3
I just had the same problem with my uncle's power chair. The number of "blinks" indicates a problem code to the technicians. My chair needed the joystick control assembly replaced. Once replaced, evrything was back to normal. 'Not a cheap fix but much needed. Good luck my friend!!
Posted on May 06, 2009
  • 37 Answers
SOURCE: chair fully charged lrd lights flashing and chair wont move
Try using a Voltage meter to test the Voltage coming from your batteries. Your batteries should be as close to 12v. your motors are 24v. Even if just one battery is bad this can cause alot of headaches.
Posted on Jun 23, 2009
  • 175 Answers
SOURCE: all lights are flashing, and chair won't move when I try to use
The flash codes for the VSI controller used on this chair are located here:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
These will tell you what the fault is; repost with more information.
Posted on May 23, 2010
  • 177 Answers
SOURCE: The lights are flashing and i cant get the chair t...
The flashing lights is a fault code. Count how many lights are flashing, and let us know, then we can tell you what the fault is. Check that both free-wheel levers are in the correct place. Good luck. Neil.
Posted on May 28, 2010
Jazzy 600 powewr chair intermittion operation
The small click noise is the parking brake releasing to allow you to drive. the flashing is called a flash code that will give you an idea of what is wrong. count the amount of lights flashing this would indicate the problem. Post the amount of lights flashing and some could give you the meaning of the code.
Apr 28, 2016 | Pride Mobility Jazzy 600 Powered...
Hoveround won't move.
Double check to be sure drive levers are fully engaged. Go down and up a few times. If problem persists have Hoveround come and check it out. One of the drive motors may have shorted out when you continued driving with gravel in the wheel.
Mar 29, 2015 | Hoveround MPV5 Electric Wheelchair - Used...
Chair won't move..lights flash continuously
You may have locked it by holding the power button . try turning it on then hit thee horn 2 times . That should unlock it.
Jul 16, 2014 | Jet 3 Ultra Power Chair
Why won't chair move?
check levers under chair make sure they are engaged,first
then turn off power and reboot
Dec 30, 2013 | Jet 3 Ultra Power Chair
Battery level indicator continually flashes when turned on, chair does not move.
Not much info to go on, but you may be in Lock Mode. On a VSI the Profile LEDs scroll left to right.To Unlock a VSI: Push joystick forward until beep, then pull joystick back until beep. Unit is now unlocked.
Mar 09, 2013 | Health & Beauty
My hoveround light flash and then goes off wont move.it is in forward gear and the batters are ok.thank Charles
The number of lights that are flashing will indicate what the problem is related to.
You can visit this website to find answers on what the flashing trouble indicator lights mean: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Locate the page that has the controller used on your power chair/scooter and count how many lights are flashing to diagnose the trouble. Try resetting your brakes to see if that will help reset the system (makre sure the power chair is turned off first.) If your insurance purchased the power chair for you, they may also cover the repairs; contact Hoveround for an appointment.
Dec 08, 2010 | NRS Hoveround MPV 5 - Used Power...
Wont move yellow lights ,flashing
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Sep 10, 2010 | Pride Jazzy 1103 Ultra Standard Power...
The lights are flashing and i cant get the chair to move. What should I do?
May 20, 2010 | Jet 3 Ultra Power Chair
One red light three green flash when turned on
Your chair has a motor problem. The code does not tell which side it is. Make sure both motors have the brakes in the drive position before turning on the chair. Also check that both motors are plugged into the main control module in the base of the chair.
May 15, 2010 | Invacare Supply Group Invacare Pronto M91...
Lights just flash on controller and wont move jet 3 wheel chair
Mar 27, 2009 | Pride Mobility Products New Pride Mobility...
Health & Beauty Logo
Top The Health & Beauty Experts
Motshidisimary
Motshidisimary
Level 1 Expert
Stacy Harrison
Stacy Harrison
Level 1 Expert
Dave Jacobs
Dave Jacobs
Level 1 Expert
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
