Mode button stopped working on my Pyle Snorkle master watch. Any suggestions how to fix it?
How do I use the buttons in this QHY watch?
Hopefully, this will help...
Lego Watches Manual Instruction:
There are 4 buttons on this lego watch case, Light button, Mode button, Stop button and Reset button, now I will show how to set the time easily!
1, Light Button: Press this button, the watch LCD light will display for 3-5 seconds;
2, How to use the stopwatches chronograph function?
Answer: When the lego watches in normal working condition, Press "Stop button" for 1 time, then the watch goes into the chronograph mode, then you can use "Stop button" and "Reset button" to operate this function.
3, How to set the alarm time?
Answer: When the lego watches in normal working condition, Press "Stop button" for 2 times, then the watch goes into the alarm mode, then you can use "Stop button" and "Reset button" to set the alarm time, also you can turn off or turn on the alarm function and chime on every hour function by the same operate.
4, How to set the right watch time, hour, minute, second, week, date, month, year?
Answer: When the lego watches in normal working condition, Press "Stop button" for 3 times, then the watch goes into the time setting mode, then you can use "Stop button" and "Reset button" to set the second, minute, hour, week, date, month and year.
This is all. So now please have a try to set your lego watches time!
Dec 06, 2014 | Watches
Time master tc100 wont stop punching by itself-how to fix it?
Is it printing automatically when you insert a time card or printing without a card inserted (randomly)?
The Time Master TC100 can print both manually via the print button and automatically, depending on your print method settings. If the print method is the problem, follow these steps:
  1. Press the Mode button until P5 (Program Mode 5 for Print Format) is displayed.
  2. Press Settings to choose the print method. 1 = Automatic (default setting) - The TC100 automatically prints when the time card is inserted; 2 = Manual - After inserting the time card, press the Print Button to activate printing.
  3. Press Select to confirm the Print Method chosen.
  4. Press Mode to return to normal operation mode.
To see the full instruction manual you can visit http://www.royalsupplies.com/clocks/Instruction%20Manual%20TC100%20English%20GOLD-2005.pdf
If the issue is that the time clock is randomly printing times, I would suggest either checking the mechanism that senses a card for issues or calling Royal.
Programming Information: 1-908-429-4357Royal Service Centers: 1-888-261-3888
Sep 26, 2013 | Office Equipment & Supplies
How to fix the date on my watch
Hold down the mode button until the time is flashing, then press the mode button to cycle through to date, then press the set button (the one that isn't mode) to set the date. Finally, press the mode button until the numbers stop flashing.
Oct 23, 2012 | Watches
How to fix pyle p3001at humming when master volume at zero
Chances are this is caused by the big electrolytic capacitors in the power supply. They filter out the 50 to 60Hz hum in mains electricity. When they fail it gets in!
Apr 08, 2011 | Pyle P3001at 2Channel Amplifier
Aquatech watch
press mode button 3 times untill you get into the time set mode - press lap/reset twice until the hours start to blink.
press start/stop and cycle thru all the modes depending what time you want to set - it will go thru 1, 2, 3, etc thru 24 H then 1, 2, 3, etc thru 12 A then 1, 2, 3, etc thru 12 P - depending on thte time you want to set the A is for AM and the P is for PM
hope this helps
jeff
Jul 23, 2008 | Watches
Prospirit watch
in order to SHUT OFF THE ALARM:
go to the normal time setting, where nothing is flashing. then press and hold reset. then the time you want the alarm on shows up. in order to turn the alarm off press start...press start again to turn it on
May 15, 2008 | Watches
Time Change
Using a Sportline but I'm an hour off with daylight savings time. How do I change the time, I can't figure it out. Can
Mar 10, 2008 | Sportline Big Digit Watch
Sportline 240
Try the left and right buttons together BUT you must be the corrrect mode. So try the 2 buttons in each mode until the alarm icon disappears.
Dec 22, 2007 | Sportline Stopwatch
Acqua Indiglo Digital Watch
My watch has 4 buttons (2 on the left, 2 on the right) plus the "Indiglo" button. Use the "Mode" button (lower left) to move between the time and the stopwatch. When seeing the stopwatch, hold the "Mode" button. This will get you to the alarm setting mode. Press the "Mode" button again to switch to the time setting mode. Use the "Start/Stop" button (upper right) to move from seconds > minutes > hour > date > day of week. Use the "Spl/Reset" button (lower right) to change the numbers.
-AP
Dec 04, 2007 | Watches
How do I change time on timex watch?
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
  1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
  2. Press ADJUST to set SECONDS to zero.
  3. Press START/STOP to select MINUTES.
  4. Press ADJUST to change.
  5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
  6. Press MODE when done.
  7. To display DATE from Time display , press START/STOP.
  8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
  9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
  1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
  2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
  4. Press ADJUST to change.. Press MODE when done.
  5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
  1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
  2. With time displayed, press MODE to select Chrono Mode.
  3. Press START/STOP to start.
  4. Press ADJUST to view lap time. Press again to sesume lap timing.
  5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
  6. Repeat for successive laps.
Have fun! - Not a bad watch for the money! - - Silver Bullet
Mar 16, 2007 | Timex 5B841 Wristwatch
k24674
jasbo
jasbo
