Question about CADAC Grilling
How to assemble my CADAC model 98336s - CADAC Grilling
Which gas is recomended for use on a cadac eezy chef as mine is generating black smoke on propane
You get black smoke - and other unwanted & unexpected effects -
'cause 'false draft' occurs during mixture process in the venturi pipe,
PREVENTING THE BURNER FROM 'INHALING' ITS SPECIFIED
PERFECT COMBUSTIBLE HIGHLY CALORIC GAS/OXYGEN MIX.
THIS MIXTURE PROCESS CAN BE IMPROVED BY FOLLOWING
THE INSTRUCTION AS OBSERVED IN THE YOUTUBE VIDEO
'THE CADAC LEGEND',
AS PUBLISHED AUGUST 15, 2011.
May 03, 2011 | CADAC Safari Chef Portable Grill
Using a cadac burner with a skottel model extension 8304 , with no 24 Jet ( using a LPG 9kg gas Bottle - no Regulator ) flame is good on full ( good Blue Colour ) however on Low Flame keeps going out...
My experience shows me the old steam engine problems.
No gastight connections where they should be.
So not the specified Kilowatts output.
Think of the old fashioned flanges witht the artificial (synthetic) rubber gasket between them. And the flangebolts which held them together, all with the same torque momentum in kilopounds/meter.
Check with good quality leak detection foam and/or use your imagination.
Alternative: look for YouTube High Definition
video 'The Cadac Legend', as of August 15, 2011.
Dutch: ................... Trek in BBQ.
English: ................. Draught in BBQ.
Talkin' about airtight/gastight connections.
Oct 08, 2010 | CADAC Safari Chef Portable Grill
Cadac Handi Blowtorch and equipment no spares
I think my problem is solved. This is old equipment and must be replaced by latest simular tools manufactured by CADAC. I will follow up with local dealers. Thank you. Okkie van der Merwe
Sep 07, 2009 | CADAC Grilling
I need an instruction booklet in order to sell a Cadac Carri Chef
go to there homepage and find files and download it disc usually it s an adobe file and burn from there
Aug 10, 2009 | CADAC Grilling
Cadac eazi chef flame burns yellow and makes a lot of soot.This happened after i tried to light it and there was some kind of blow back and some smoke but no visible flame. I have striped it down as far as...
Yellow flame = not enough air. (Remember using Bunsen burners in school science lab? Air hole closed = yellow flame). Have you twisted the main metal tube (whilst trying to remove the burner assembly)? Remove the gas tube and metal plate (6 small cross headed screws). Draw out the gas valve. Look into the metal tube. You should see 3 slotted holes - the air holes. On mine they had twisted and were blocked by the plastic of the leg assembly. Using a good pair of pipe grips, rotate the metal tube until the air holes are clear. Then re-assemble. My Cadac Eazy Chef now works like new.
Jul 01, 2009 | Grilling
Were do the parts go on the cadac bbq
hi i need a new gas igniter for my carrie chef, can you tell me where i can buy one
Jun 15, 2009 | CADAC Safari Chef Portable Grill
Require instruction manual
http://www.cadac.co.za/index.php?page=usermanuals TRY HERE FOR MANUALS
I have just bought this product and have got the manuals with it!!! They arent clear
May 27, 2009 | CADAC Grilling
Cannot get the cadac to light
the blue tube is the air baffle, it should be in there but the people at cadac told me it will work safely without it. this baffle has been known to melt on occasions, i phoned cadac and they sent me out a new one free of charge. dont know why yours wont light though. mine produces a yellow flame instead of a blue flame?
Apr 12, 2009 | Grilling
Cadac safari chef
Hi Paul
I asked the same question and found this web site which sell a propane regulator.
http://www.flogas.co.uk/buy-online/gas-barbecues/cadac-carri-chef-deluxe-combo-8150/
Cheers
Sepp
Jun 11, 2008 | CADAC Safari Chef Portable Grill
Grilling Logo
54 people viewed this question
Top CADAC Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a CADAC Grilling Expert? Answer questions, earn points and help others
