Washer will not drain.
Have a stacked washer and dryer Kenmore mod# 41790812992. Will not pump water replaced pump and checked for stopped up lines, OK. Washer works fine in ever mode it just won't pump water. HELP!!!!!!!!!!!!!!!!!!
  • jdonm Nov 21, 2007
    No power to pump, Do you think it is circuit board or timer?
Pull the pump apart and use some steel wool on the inside and outside of the motor assembly where they spin. This will allow the voltage to make contact and allow it to pump. I had the same problem you had and this fixed it.
Posted on Feb 19, 2008
    Champion:
  • 249 Answers
Put test bulb on the two wires going to the pump, it should light, if it those not, it could be the PC board or broken wire, make sure the outlet hose is not blocked you might have to blow through it.Close reland bye bye
Posted on Nov 21, 2007
98702 Stacked Washer / Dryer Your question about 98702 Stacked Washer / Dryer has been posted. Mom has a Kenmore stackable washer. She ran water in for a load and the water ran out of the washer and onto...
Get the control panel off and remove the water pressure tubing. Blow it out and reconnect to pressure switch. Remove water so that pressure can once again build inside the tube. Retry>
Oct 22, 2011 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 417.99980120 stack washer/dryer won't drain.
Check for a kinked drain hose. Also, if it is an older machine it could have something stuck in the drain pump. The usually culprit is an under wire bra
Mar 20, 2010 | Kenmore 98702 Stacked Washer/Dryer
Water won't drain
Check filter or pump. Clean as required..
Oct 03, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stackable mod number 417.94802301
check your lid switch. if your lid swith is bad, it will fill and agitate, but will not pump or spin. therefore it will not go into rinse cycle without being able to pump out water. some lid swithes control the agitation also (usually frigidaire and older maytags), but i doubt yours does. you can check the lid switch for continuity while opening and closing the lid with a meter
Apr 30, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stacked washer wont drain
you have to remove the front and take the water pump off and get all that clogged up stuff out of it-mike
Mar 13, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Washer/Dryer Does Not Drain. Please Help!
Check out your exit hose spigot, it may be clogged. This is if your filter is all clean(ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Some connect to sink, fine. Snaking out your standpipe would be good too.
If the above fails, check to see if your pump is blocked. Pl rate if helped.
Jun 17, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Check for plugged drain hose, or hose from bottom of tub to pump.
Nov 20, 2007 | Washing Machines
Washing Machines Logo
113 people viewed this question
Top Washing Machines Experts
