Question about Microwave Ovens
Hi, my microwave is JES772SK this model, I wanna turn the display brightness up, how do I do this?
  • Microwave Ovens Master
  • 17,417 Answers
Dim display panel
Hi. The service manual is here - perhaps your solution is here too:
GE JVM1790SK Service Manual
Jul 13, 2016 | GE JVM1790 Convection / Microwave Oven
Dim display light brightness
You will need to replace the display, call Dacor first to see if they will assist in a price break or replacement part. They are normally good with there customers. But there is no way to adjust the display, its just fading over time, like a light bulb.
I hope this helps
Oct 30, 2013 | Dacor DMT2420 1200 Watts Microwave Oven
The display light is not bright.
It likely needs repair of the backlight circuitry.
Assuming your model number is R-630D-something, the service manuals here and here will help you.
Jan 30, 2013 | Sharp R-630D Microwave Oven
The display on my Sharp Grill 2 Convection Model R 82ojs-f is too dim to read.
either the display is bad or the unit may have a setting in the menu for adjusting the brightness level
Dec 04, 2012 | Microwave Ovens
The control display on my microwave is very dim. Is there any way to make it brighter?
If you had mentioned your full model number, we could have looked whether the VFD is available as a separate part in case your model has a VFD display, or whether the whole control board would have to be replaced.
If your model has an LCD type display, it may be weak LEDs or other failing components in the display backlight circuit.
We regularly repair microwave displays for $39.95 nationwide.
It's pretty rare for a microwave to have a display brightness feature.
Let us know if we can help you further.
Nov 16, 2012 | Whirlpool MH2155XP Microwave Oven
The brightness of the display panel on the GE XL1800 is so dull I cannot even read it. How do you increase brightness?
There are two main causes for this:
- Dust & other particle buildup on the front of the display gass and the rear of the display window. This can be cleaned.
- Your vacuum display tube is wearing out and the control circuti board must be replaced.
Cleaning the display is easy, but you need to be careful so you don't break the glass.
First you would unplug the microwave or turn off its breaker.
Then see the video here that shows you how to remove your control panel assembly in less than 5 minutes.
Next, disconnect the keypad strip as shown in the photo below, then remove the screws that hold your circuit board in the plastic frame.
Then carefully (since the display is made of glass) remove your circuit board.
Using a soft cloth (since paper towels can scratch) lightly dampened with non-ammonia cleaner (since ammonia can damage some polycarbonate plastics), gently wipe off the front of the glass.
Then gently wipe off the back side of the plastic display window in the plastic control panel frame.
Reassemble, reinstall, and power it up, and it should be brighter, sometimes a whole lot brighter!
If that does not brighten it up enough, then you will need to replace the entire circuit board, since the display tube on this brand is not available as a separate part.
You can use the disassembly instructions above, and the board can be ordered by entering the full model number from the tag in or on your unit here.
For those with other brands, or whose model does not show up there, see this page for tips to finding helpful exploded views and ordering appliance parts and accessories.
May 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Digital display is too bright... how can it be adjusted ?
There's no built-in adjustment for the brightness, but we regularly repair microwave displays and controllers, and we can easily modify the circuit to lessen the brightness.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Jan 10, 2010 | Sharp Microwave Ovens
After turning the bright light on above the stove
You may have shorting keypad or a problem on the control board.
FixYa's Web site is currently not notifying us when replies to our Clarification Requests are posted, so please reply back directly to me for free help and tips.
Please include your full model number and color.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
William E. Miller
prototech@usa.net
Oct 05, 2009 | Kenmore 62622 Microwave Oven
Digital display lighting
The solution depends first on the type of display your microwave has. Please refer to the picture. The left side shows a partially defective LCD type display. If you have this type of display, we regularly repair them for $32.50 nationwide. The right side is a VFD type display which is weak due to age. On some brands and models, we are able to get a replacement display tube and repair it to a like-new brightness. Feel free to e-mail me at _ if you have other questions.
Sep 17, 2006 | Frigidaire FMT144G1 Microwave Oven
Microwave Ovens Logo
54 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
