I am getting F6 -1 reading? - Computers & Internet
    Master:
  • Computers & ... Master
  • 923 Answers
Yeah, that's a pretty common reading ... but on WHAT?
Posted on May 11, 2017
Convert from decimal numbers to regular readings
read your manual about it,You will receive an answer like this if,you did not include the make or model or serial number or
date of manufacture or complete problem and what needs to be done.
Jun 06, 2015 | Health & Beauty
I have a mastercraft multimeter, it reads volts but wont read milliamps. Checked the fuse, it's good. what else could be the problem? There is only one fuse on the inside, does it protect both volt...
Tom,
Do you get any readings from the meter when attempting to read amps? Are you connecting the meter properly? Some people assume that you touch the test points the same as a voltage reading but that of course is not correct to read amps. You must use the meter to bridge the connection so that the current flows through the meter, otherwise you will get a zero reading.
Jan 03, 2015 | Cars & Trucks
Am not getting a frequency reading on MY-64
That tells me the meter is working perfictly. You can only get a frequency reading when it is AC.
Nov 28, 2014 | Measuring Tools & Sensors
How do I test a motorcycle coil ??
Use an ohm meter. With the coil out, place the meter leads across the electrical wire connections, you should get something like 25K ohms. Then measure from the spark plug lead to one of the wire connections, you should get a much lower reading, like 2.5K or less.
The key here is that you should get a high reading across the wire connections and about 1/10th that reading through the spark plug wire.
If you get no reading or an exceedingly high reading, your coil is damaged.
Jul 22, 2014 | 2006 Harley Davidson FXDLI Dyna Low Rider
SO184 able to read of82b?SO184 able to read of82b?SO184 able to read of82b?SO184 able to read of82b?SO184 able to read of82b?SO184 able to read of82b?SO184 able to read of82b?SO184 able to read of82b?SO184...
so184 just an adapter that he did not read the chip function so184 long as the customer can get him on the chip package on it. TSOP 32 is thought that this type of chip packaging can be placed inside the adapter.
May 17, 2014 | obd2-scanner Car Diagnostic Fault Code...
How to check youself / blood pressure for accuracy i get to different reading the first time then upon checking for accuracy the second time the reading is always different
Hello Dear
All Digital equipments vary in its reading. To get the accurate reading take three readings one after the other and then the average of the reading is the accurate one.
Usually the readings varies plus minus 2 or 3 to the accurate reading.
Hope the answer will help, please rate the answer.
Best wishes
Feb 23, 2011 | Lumiscope 1080 Deluxe Auto Blood Pressure...
Arabic language is not readable when I get SMS. I can see only some blocks in place of Arabic letters. I can read English messages. What should I do to read Arabic language when I get SMS.
Arabic language is not readable when I get SMS. I can see only some blocks in place of Arabic letters. I can read English messages. What should I do to read Arabic language when I get SMS.in LG ku990
Sep 15, 2010 | LG KU990 Viewty
Installed new drive CDRW-DVD\ TSST TS-H492C
of course its not going to read a blank this is a common error that comes up but after you wrote to and in close the session it will read the cd/dvd
Apr 23, 2009 | Computers & Internet
DVD CAN'T READ
get ur DVD serviced this will clear all of ur reading DVD problem................this generally happens due to dust gets cloth at the laser which reads the DVD/CDs
Jan 13, 2009 | Toshiba Satellite A135-S2386 Notebook
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
