Question about Ricoh Office Equipment & Supplies
Como reset el error SC 542 de una Ricoh Aficio SP C231n
boyrevel
  • 71 Answers
SOURCE: sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Posted on Aug 14, 2007
SOURCE: tengo una Ricoh 1075 y me sale el mensaje de SC 541
Possibly the thermal fuse in the fusing unit is damaged. Change and reset as our friend Cogz says.
Posted on Sep 17, 2009
SOURCE: tengo una fotocopiadora ricoh aficio
Limpie o cambie si es necesario el thermistor de la unidad fusora, luego presione total clear key tecla amarilla, introduzca 107 y mantenga presionada la tecla clear stop tecla naranja, mas de tres segundos hasta que el tablero cambie a sertvicio, apague y encienda el interruptor principal y listo...
Buena suerte...
Posted on Dec 07, 2009
SOURCE: Ricoh aficio 1022 sc 546
problema ricoh aficio 1022 copia en blanco aparece codigo
sc 193
Posted on Jan 07, 2010
micromatikal
  • 2777 Answers
SOURCE: I need the reset procedure
This is how you reset that error:
press the yellow "C" button
enter 107
press the red "C" button and keep it hold till the display changes
turn the power off with the big red switch on the unit
turn power on again
Thanks much - if somehow that doesnt work please reply.
Tim
Posted on Oct 25, 2010
How do I solve the sc 542 error problem on Ricoh aficio sp 3510dn printer when it does not have an online button or a number keypad?
You need to switch the power switch off.
Hold down either the online & escape or stop/start & escape while switching the machine on.
The machine should start up in service mode.
Select 1 for service mode
Select 5 for mode
Scroll to 810 SC reset and select enter
Select execute.
Switch machine off and on again.
Jun 22, 2016 | Ricoh Aficio SP 3510DN
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
Codigo sc 542 en ricoh sp 3510 como resetearlo
Oi por favor. Gostaria de resolver meu problema com minha impressora ricoh 3510sf que estar dando o erro sc542. Me manda resposta. emiliomartinscte@gmail.com
Apr 09, 2013 | Ricoh Aficio SP 3510SF Laser Multifunction...
How to restart Ricoh SP C231n?
hi there, try to do the following:
- make a program mode (SP 107)
if you dont know SP mode, press clear/resume button then 1, 0, 7 then clear/stop button for atleast 5seconds.
*the monitor should appear 1.system 2.copy 3.
then press 1, then press 7,8,0,7 then #
*the monitor should appear COUNTER RESET then press 1 to start, let it finished then turn off and on your machine.,
*the SC-542 should disappear
note: if this will not fixed the problem, there maybe a problem with your FUSING UNIT, check it!
Nov 29, 2012 | Ricoh Aficio SP C232DN Laser Printer
My printer ricoh aficio SP 3400SF is showing service call error code SC542. kindly help to come out of this error. \r\nvr babu
FOR RICOH AFICIO SP 3400SF follow below steps.
1. To access Service Mode, On Control Panel press following buttons one
by one immediately.
Cancel Button (Red) ---> 1 (Numeric One) ---> 0 (Numeric zero) ---> 7
(Numeric Seven) ---> Copy Button (Green)
2. In Service Menu you will find Engine reset Menu. In that you can reset
SC 545 in Fuser Reset Menu. And you can also reset SC 542.
Jun 23, 2011 | Ricoh Aficio AP3800C Laser Printer
Como quitar el error sc 819 de una ricoh 3025
• Software application error
• RAM shortage
• HDD error (hard disk drive )
Apr 06, 2011 | Ricoh Aficio 3025SP Copier
Tengo una Ricoh 1075 y me sale el mensaje de SC 541
press "clear" 1 - 0 - 7 and then Stop then turn off then back on
Jan 23, 2009 | Ricoh Aficio 450 Copier
sc 193
Oct 20, 2008 | Ricoh Aficio 1022 All-In-One Laser Printer
61 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
