Question about Whirlpool Washing Machines
Whirlpool duet washer f6e3 error as soon as you turn on already changed mcu,CCU,ui still have error what's next
Already tested wiring harnesses
aborcass
  • 2651 Answers
SOURCE: F 06 whirlpool duet washer
mcu is responsible for the f06 fault code
Posted on Mar 24, 2008
57 varieties
  • 1653 Answers
SOURCE: 3 year old Whirlpool Duet - F07 error showing up
No do the following:
  • Check wire harness connections between the Drive Motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the MCU
  • Check the Drive Motor
  • Check the Wire Harness
If the wiring is definitely OK and the drive motor is OK then the MCU is most likely to be the culprit.
Posted on Dec 30, 2009
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Duet Sport f-01 even after replacing CCU
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
blueextc3221
  • 15935 Answers
SOURCE: Removing an MCU whirlpool duet washer
It appears your timer/main controller/CCU has failed in this instance.
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Posted on Sep 27, 2010
blueextc3221
  • 15935 Answers
SOURCE: I have a wfw8300 whirlpool washer i keep getting an f28 error
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@@@@
Posted on Sep 28, 2010
Horn doesn't work
What happens if you apply 12v to the contact at the steering wheel, that would test the harness?
Next is to trace that wire to the next cable plug down the harness and try again. Process of elimination that you are already on.
May 19, 2014 | Volvo 850 Cars & Trucks
Location of foglight wiring harness
The Easiest Way is to Get the Wiring Harness Diagram with the Colors and Verify that you plugged the Fog Lights into the Correct Harness. I once had a FORD that had a Fuse BOX that had a FOG LIGHT and No Power to that Fuse.
Make sure you test the Fuse at the Box and then Trace the wires and if the Switch was wired at the Factory, you should be all set
Apr 09, 2013 | 2006 Buick LaCrosse CXL
I purchased pioneer speakers and am attempting to replace my stock speakers. Problem is there is already a plug and outlet on the factory speakers, which there is not on the new speakers. is this called ?...
yes they are called speaker harness adapters. You can just cut the factory ones off if you know the polarity (positive/negative) of the speaker wiring.
An easy way to find out is take a 9v or AA battery and two pieces of wire. Strip the wire and attatch one piece to the positive and another to the negative of your test battery, I use red wire for (+) and black for (-). Then take the other ends and touch the factory speaker connector (where it plugs onto the speaker). If it moves out or UP then you have the polarity correct and the wire that your red tester went to is the positive of the new speaker and the black test lead wire touched the negative. If the speaker moves in or DOWN then you simply have it reversed.
All pioneer speakers come with a set of wires so you can cut the factory connector off and put the new one on.
Sep 24, 2011 | Jeep Car Audio & Video
I have brought a second hand unit and was wondering if I can order the wiring harness from anywhere or make one???
So you purchased another radio, right? Then it came with the harness already(for the radio and not the car). If the current radio is the factory radio then you need to purchase a wiring harness for the model/year of your car that will be compatible with your car's harness. Wal mart carries some but if you can't find it there then you need to go to your local car audio installation shop and buy one from them(it might be pricey there). Now, if your current radio is aftermarket, look to see if it already has the wire harness in the back. If it does then your good to go, just cut the harness from the radio away from the harness that plugs to the car's wire harness and reconnect using your new radio's harness(just follow the wire's color code). but if it doesn't then you need to buy one.
Jul 06, 2011 | Car Audio & Video
Where is the output speed sensor on my 2000 Volvo S70 ? It seems to have brake and trans problems. The front brake would act like it was trying to apply the brake while driving down the road. The trans was...
Hi.
The problem is either vehicle speed sensor or wiring harness going to sensor. In some case the ECM is defective.
Ensure that you have already replaced the VSS with good ones.
If you have not replaced them yet, then the sensor can be tested reading the waveform. This is done connecting both VSS input and output wires to a machine. The one below is a good VSS wave at 37 mph:
If the waveform is incorrect, the sensors must be replaced, as the ECM returns P0722 when VSS output is incorrect, or when there is no output.
A second test can be done reading the sensor impedance and voltage. Connect a multi-meter to the sensor. Set first on Ohms reading (impedance). A good sensor will read 560-680 Ohms at 20C (68F).
Set multimeter on Volts. Touch rapidly the sensor with a magnet and pull magnet away. The sensor will emit a weak voltage pulse. If that does not happen, then the sensor is broken. Ensure that multimeter is on high volt scale.Voltage will be quite low:
The VSS are located on the wheel shaft. Here a picture:
The VSS is connected to the ECM.
If you have already replaced the sensors you need to check the wiring harness to the ECM.
The wiring harness is tested checking that each wire going to the ECM has continuity. This is done reading impedance between each connector in the sensor , and the respective connector in the ECM. Impedance must be zero or a very low value. If it reads infinity, then the wire is broken.
A second test is done reading impedance between the two different wires at ECM connector. Impedance must be the same as at VSS contacts on sensor. If impedance is zero, then there is a short. Ensure that you choose a proper Ohms scale while doing the test.
If you have already replaced the VSS, repair or replace the wiring harness. The ECM failure returning this code is very uncommon. At most you may have a defective ECM connector.
Regards.
Ginko
Apr 14, 2011 | 2000 Volvo S70
Wiring harness caught fire n i cant destinguish which wwires go to which components...relays, sensors, braking. lights, etc. are the relays run parallel, in series, singular? once wiring is hooked up how...
Its a long process. You actually have to verify each wire with a volt meter. The easier option is to buy an after market wiring harness from a company like painless wiring. It will come with all the correct connectors already on it.
Mar 08, 2011 | 1988 Chevrolet S-10
I have a 1990 oldsmobile silhouette. IT clicks one time and then nothing. took the starter off had it tested the starter is GOOD. What could this prob be?
Sounds like a bad ground or possible burn in the wiring harness. I would check all the factory locations for ground and make sure none of the connections have corrosion or any build up. Also you can follow the wiring harness and make sure there are no burns in it. Also take the battery in to be checked if not already done.
Dec 18, 2010 | 1990 Oldsmobile Silhouette
BRAKE LIGHTS NOT WORKING!!!!1
If you feel up for the challange, you can trace the wiring and use a multi-meter to see if the voltage is reaching the sockets. Also do the same for the fuse box. You can also use a test light for this is you have one.
Also check all wiring in trunk. Make sure all connections are tight. Mabey have a short in dimmer switch. How is the cluster lights? You can also test the headlight switch to rule that out.
Jun 03, 2009 | 1979 Pontiac Firebird
The car is not starting, the engine is turning weakly
i Is the engine wire harness original? or has it already been replaced?
if its original, this may sound crazy unless you already know that MB has a big problem with the wires under the hood.
But your car may need a new engine wire harness.
They start to crumble leaving the wires bare in places to short together and cause all kinds of crazy things.
Your car is at the perfct age to start experiancing this problem.
Unfortunetly the best way to cure this is to replace the harness.
A harness costs about $900 new, plus labor.
To check the harness, I unwrap the wires in several places on top of the engine by the injectors, and for the ignition coils and a few other places, I then bend the wires around a little, and look for cracking or crumbling. If you see ANY cracks in the insulation, that is not good .
To replace the harness is acually easier than it looks. it takes one to two hours, even less if you done one before.
There is a high percentage of the MB that I have seen, have this harness problem..
Good luck, and I hope this info helps
Dec 16, 2008 | 1994 Mercedes-Benz E-Class
How to wire a towbar to a landerrover freelander 03
There is already dedicated wiring for this , remove the right rear luggage compartment cover.You will find a loose white plug taped to the wiring harness , you can plug in a factory harness or cut the plug off (each wire seperately)test each wire and wire this up to your trailer plug.You will get wire details for your region from your nearest repair shop.
Sep 07, 2008 | 2003 Land Rover Freelander
Washing Machines Logo
157 people viewed this question
Dan Webster
Dan Webster
Sal De
