Question about TV Box Televison & Video
Have no got any signal was working connectec to fetch now nothing just blznk screen. Have lots of wi fi conmection so why the problem
Since connecting to fetch tv box was working now not at all have wifi signal but nothing on tv screen
  • 3 Answers
SOURCE: Connection to wifi internet
Try a new partnership with your pc and and use active syn to update your phone.
Under connections you'll find wi-fi in theresomewhere and choose it as default connection and you should be good to go.
Hope this els,
Steven John
Posted on Nov 30, 2008
  • 6 Answers
SOURCE: Unable to connect to wi-fi
I think it is saying that the wifi "card" is set so that it is not being configured by windows.
In XP
Control panel > Network connections
Under LAN or High-speed internet you will see an icon labelled wireless network connection. Right click on this and then click properties. You will see three tabs at the top
General - Wireless Networks - Advanced
Click on wireless networks
There should be a tick-box saying Use windows to configure my wireless network settings. I expect that, in your case, the box is unticked which means that the software supplied by the vendor of the wifi card is configuring the settings. I find that it is usually more reliable to let windows do it.
So tick the box and click OK. You may then have to reboot.
Posted on Jan 05, 2009
SOURCE: wifi not function
My Internet service provider walked me through connecting correctly. I had chosen the WEP security options and should have chosen the WPA-PSK option. Call your service provider and get them to help verify your security access codes.
Posted on Jan 24, 2009
KingDWS
  • 1606 Answers
SOURCE: No wi-fi signal on Palm Lifedrive
Ok first thing to know is if the LD is detecting networks at all. Tap the wfif icon and hit the scan button. If you see a list of available networks that means its working and the problem is the settings.
I'm assuming that it is detecting the network from your description.
The LD supports WEP and WPA so you have other options if nothing else. WEP is nice and simple (most of the time anyway)
On the scan find your network tap edit, Make sure the SSID is correct, Make sure that it says WEP under scurity and then tap the key box where is says assigned.
Now this is the bit that makes or breaks the connection. Make sure the key type is set correctly. You have three choices hex, ascii or passphrase. Most wireless router just use the first two.
You need to make sure that this is set to exactly the same as the router.
For ten digits that means you are trying to use 40-bit hex which is not the easiest but it works sometimes. Ascii tends to go a lot easier and I would suggest you consider switching over the ascii to avoid the headaches. I don't know why the LD does not want to work all of the time when using the hex key but it does seem to have problems. Assuming you have the hex key matching exactly as per the one you have in the router it should work. Should but sometimes just won't. Check your cases and make sure you are only using the basic ascii set not the extended. Stick to number and letters and you should be good.
I have never had a problem with the ascii or passcode but usually do not have much sucsess with the hex setup even when it is correct. I've assumed that it was something I've missed but have not had these problems using other devices.
Posted on Jul 09, 2009
Gort007
  • 1187 Answers
SOURCE: My wi-fi keeps randomly disconnecting but is not bc a weak signal
Your card is ok. There is interference between the router and your computer.
1. The router or the PC may be "hidden" behind a metal cabinet, refrigerator, etc.
2. Move router higher
3. Microwave ovens and some cordless phones (not cellphones) that use 2.4GHz will interfere with the 2.4GHz WiFi signal.
4. Point the router antennas in-line with the direction of the PC.
5. Move the router closer to the PC.
Posted on Oct 06, 2009
I have a Roku in my bedroom & when I try to watch Netflix it just spins & spins & takes forever to load. Once it starts, it stops & starts spending again.
First step, of course, is to unplug the Roku for 10 seconds then plug it back in again and let it connect.
Assuming a Wi-Fi connection is what you are using, it is possible (likely) that your Roku is too far from the Wi-Fi router. Your best solution is to relocate the Wi-Fi router closer to your Roku, or to get a signal booster to extend the range of your Wi-Fi signal.
On a more technical note, your Wi-Fi router may be broadcasting on a channel that has lots of conflict with other Wi-Fi signals in your neighborhood. Changing the broadcast channel requires that you have an administrator login to your router and can make changes. You might have to call your service provider and have them make the changes for you (if you smile right over the phone, they may give you your router's login information, but don't count on it). Best channels to select are generally 1, 6 or 11 to avoid overlap with other channels.
If you have a smart phone and can download an app, look for a Wi-Fi Analyzer app (free). This will show you the other signals around you, what channel they are broadcasting on, and the strength of the signal.
Sep 06, 2017 | Computers & Internet
Tip
Increase iPad, iPhone, iPod battery backup !
  • Minimize use of location services: To disable location services, go to Settings > General > Location Services or use location services only when needed.
  • Turn off push notifications: To disable push notifications, go to Settings > Notifications and set Notifications to Off. Note that this does not prevent new data from being received when the application is opened. Also, the Notifications setting will not be visible if you do not have any applications installed that support push notifications.
  • Fetch new data less frequently: To fetch new data manually, from the Home screen choose Settings > Mail, Contacts, Calendars > Fetch New Data and tap Manually. To increase the fetch interval, go to Settings > Mail, Contacts, Calendars > Fetch New Data and tap Hourly. Note that this is a global setting and applies to all applications that do not support push services.
  • Turn off push mail: Go to Settings > Mail, Contacts, Calendars > Fetch New Data and set Push to Off. Messages sent to your push email accounts will now be received on your phone based on the global Fetch setting rather than as they arrive. If the global Fetch setting is set to Manually, you will not be able to locate your iPhone using the MobileMe Find My iPhone feature.
  • Auto-check fewer email accounts: This can be accomplished by turning off an email account or by deleting it. To turn off an account, go to Settings > Mail, Contacts, Calendars, choose an email account, and set Account to Off. To remove an account, go to Settings > Mail, Contacts, Calendars, choose an email account, and tap Delete Account.
  • Minimize use of third-party applications: Excessive use of applications such as games that prevent the screen from dimming or shutting off or applications that use location services can reduce battery life.
  • Turn off Wi-Fi: Go to Settings > Wi-Fi and set Wi-Fi to Off. Note that if you frequently use your iPhone to browse the web, battery life may be improved by using Wi-Fi instead of cellular data networks.
  • Turn off Bluetooth: Go to Settings > General > Bluetooth and set Bluetooth to Off.
  • Use Airplane Mode in low- or no-coverage areas: Because your iPhone always tries to maintain a connection with the cellular network, it may use more power in low- or no-coverage areas. Turning on Airplane Mode can increase battery life in these situations; however, you will be unable to make or receive calls. To turn on Airplane Mode, go to Settings and set Airplane Mode to On.
  • Adjust brightness: Dimming the screen is another way to extend battery life. Go to Settings > Brightness and drag the slider to the left to lower the default screen brightness. In addition, turning on Auto-Brightness allows the screen to adjust its brightness based on current lighting conditions. Go to Settings > Brightness and set Auto-Brightness to On.
  • Turn off EQ: To turn EQ off, go to Settings > iPod > EQ and tap Off. Note that if you’ve added EQ to songs directly in iTunes, you’ll need to set EQ on iPhone to Flat in order to have the same effect as Off because iPhone keeps your iTunes settings intact. Go to Settings > iPod > EQ and tap Flat.
  • Turn off 3G: To disable 3G, from the Home screen choose Settings > General > Network and set Enable 3G to Off. You will still be able to make and receive calls and access cellular data networks via EDGE or GPRS where available.
  • Avoid Using Winter-board theme
on Apr 04, 2010 | Cell Phones
Tip
Tips and Hints on How to Maximise You iPhone 3GS Battery Life
1. Turn Screen Brightness down to less than a half and turn on Auto Brightness. (Settings - Brightness).
2. Turn off Location Services when you are not using a GPS dependant App. If on a long journey using the iPhone's GPS, only turn the App and the service on every so often. GPS based Apps really eat battery life up!
(Settings - General - Location Services - Off).
3. Turn off Fetch Data. With this feature enabled the iPhone will interrogate the internet or your mail account every so often to fetch data, for example, an e-mail. This drains battery life. (Settings - Mail Contacts - Calendars - Fetch New Data - Push Off).
Or if you really want to keep this feature, just follow the same protocol as above , but instead of switching "Push" off, below that, adjust Fetch Data settings, to fetch on a less regular basis ie Hourly as opposed to every 15 mins.
4. On long journeys when all you need is the iPod functionality, turn Flight Mode on.
(Settings - Airplane Mode Off).
5. Remember to run the battery completely flat every so often. I do it around once a month and then fully charge it again.
6. Turn Bluetooth off.
(Settings - General - Bluetooth Off).
7. For those of us who have an iPhone 3GS or updated software on iPhone, switch on the Battery Percentage for better battery monitoring. (Settings - General - Usage - Battery Percentage On).
8. If you are fairly desperate for battery you can turn off the 3G feature of the iPhone. 3G enables higher browsing speed and better call quality. (Settings - General - Network - Enable 3G Off).
9. Turn Wi-Fi off if not in use. The iPhone will use battery searching constantly for Wi-Fi networks. (Settings - Wi-Fi - Wi-Fi Off).
10. Remember, if you really can't manage with the battery life, you can buy iPhone cases which provide extra battery power.
Good Luck
on Feb 08, 2010 | Apple iPhone Smartphone
How can I connect to router with galaxy tab4 and set up for exteNing WiFi signal
To help you connect to the internet via WiFi from your Samsung Galaxy Tab, follow the steps given below:
- First activate the Wi-Fi connectivity: on the Home screen, press the 'Menu' option and then click on 'Settings'.
- Now click on 'Wireless & Networking' and then 'Wi-Fi Settings'.
- Click 'Enable Wi-Fi'.
- The check mark will turn green and your device shall automatically search for available network.
GuruAid.com
May 19, 2016 | Computers & Internet
HOW TO CHANGE THE INTERNET SETTINGS IN THE HTC WILDFIRE A3333
Wi-Fi provides wireless Internet access over distances of up to 100 meters (00 feet).
To use Wi-Fi on your phone, you need access to a wireless access point or "hotspot". The availability
and range of the Wi-Fi signal depends on the number, infrastructure, and other objects
through which the signal passes.
Turning Wi-Fi on and connecting to a wireless network
From the Home screen, press MENU, and then tap Settings > Wireless & networks.
Select the Wi-Fi check box to turn Wi-Fi on. The phone then scans for available wireless
networks.
Tap Wi-Fi settings. The network names and security settings of detected Wi-Fi networks
are displayed in the Wi-Fi networks section.
If the wireless network you want to connect to is not in the list of detected networks,
scroll down the screen, and then tap Add Wi-Fi network. Enter the wireless network
settings, and then tap Save.
Tap the Wi-Fi network you want to connect to.
If you selected an open network, you will be automatically connected to the network.
If you selected a network that is secured with WEP, enter the key and then tap
Connect.
Depending on the network type and its security settings, you may also need to enter more information
or choose a security certificate.
When your phone is connected to a wireless network, the Wi-Fi icon appears in the
status bar and tells you the approximate signal strength (number of bands that light up).
The next time your phone connects to a previously accessed secured wireless network, you
will not be prompted to enter the key or other security information again, unless you reset
your phone to its factory default settings.
Jan 28, 2015 | HTC Wildfire A3333 Cell Phone
Ok I asked the question three days ago why can I get on a free wifi connection with my phone but not my tablet
The free Wi Fi router may have run out of IP leases on its DHCP server just when you were trying to connect the tablet. If the leases are as an example say one week long then if lots of people connect to the free wi fi they get a lease for one week. So if the device comes back within the week it already has an IP address assigned to it and works. If a new device comes along it has to ask the DHCP server via the WI FI to assign it an IP address. If all available IP addresses are leased from the WI FI router the device will not get assigned an ip address. Would suggest trying to connect the Tablet on another Wi FI system to test it works.
I had this happen on my mobile phone when I was in Surfers Paradise in a Coffee shop and suspected the lease time on the WI FI router was too long for the amount of short term customers using the coffee shop. (the staff had no idea on why the Wi FI was not working so it would have been pointless to try and explain this concept to them and how to change the lease time on the dhcp server) Also there is a limit to the simultaneous number of users on a Wi Fi frequency on one access point . Unless the WI FI uses multiple WI FI access points.
Jan 27, 2015 | Mach Speed Trio Stealth G2 Tablet -...
Why does my moto G from US Cellular get poor signal now that I switch my plan from the $50 plan to the $60 plan
Cellular Signal Boosters / Repeaters
Your cellular carrier can provide you with a "signal booster" device that can repeat and boost a cellular signal you already get in your house. For example, if you consistently have one bar of coverage but no more at home, a booster can take that one bar and turn it into more bars. If you have one or two bars of coverage near a window but no coverage elsewhere in your home, a booster near that window can capture the signal and boost it, providing a strong signal throughout the rest of your home.
Some carriers offer such devices very inexpensively - $50 or maybe even free - especially if you're in an area where they know they know they have poor coverage. T-Mobile now offers such boosters for only a $25 deposit, which you can get back just by returning the booster to them.
Contact your carrier - or look at their website - to see just what they'll offer you and for how much.
Femtocells / Microcells
A femtocell - or "microcell" - is a small, low-power cellular base station that connects to the cellular network via your broadband Internet connection. Essentially, it's a small cellular signal tower that will provide a signal in and near your home, connecting to the larger mobile network over your Internet connection. This makes it ideal for situations where you don't even have a signal bar of coverage you can boost at home. The only "catch" is that your Internet connection must have a high enough download speed. Different carriers require different minimum speeds, but you should be fine as long as you have a solid broadband connection.
Ask your cellular carrier if they offer this sort of product and find out how much it will cost you. As with boosters and repeaters, a femtocell may be available at a steep discount from your carrier in areas they know they have poor cellular service.
You can also buy them easily on Amazon or almost any decent tech store - for instance the one pictured below works for AT&T and supports LTE (though it is a bit pricey), or you can get one that supports Verizon, T-Mobile, AT&T, Sprint, Cricket, and many others, but you won't get LTE support. Of course, since you likely have Wi-Fi in your house, LTE isn't really a big deal and the 3G will work just fine for calls and texts.
Editor's Note: For the official How-To Geek office we got a Samsung microcell device directly through Verizon, which wasn't cheap, and doesn't work all that well. And since it only works for Verizon, any of the people who come by who use other carriers have zero signal, which is really annoying. If we could do it over again, we'd have started with this zBoost microcell that supports virtually every cell provider and has many different models and options to choose from depending on the size of the house. They even have an optional antenna you can install on your roof to give cell coverage everywhere around your house. It's the best choice, and cheaper than most carriers will offer you.
Wi-Fi Calling and SMS
Wi-Fi calling is a feature you might remember from some years ago, but it's coming back with a vengeance. At the moment, in the US, only T-Mobile offers Wi-Fi calling for both Android phones and the iPhone. Sprint only offers Wi-Fi calling for select Android phones. AT&T and Verizon have announced plans to activate Wi-Fi calling in 2015.
Essentially, WI-Fi calling allows your smartphone to receive and place calls and communicate via text messages over a Wi-Fi network. Your home probably has Wi-Fi, so Wi-FI calling will let you use your existing wireless router instead of needing a new, specialized device. You can just improve your Wi-Fi signal strength, and all your devices will benefit!
Wi-Fi calling works transparently. When your phone is on Wi-Fi and has a poor cellular signal, it will connect to the Wi-Fi network and your phone calls and text will be sent and arrive over the Wi-Fi network. When you leave the Wi-Fi network, your phones and calls will be sent over the cellular network as usual. This is all designed to hand-off automatically, so you could start a phone call on your Wi-Fi network and your phone would automatically hand off to the cellular network as you walk out the door, with no interruptions.
WI-FI calling will also work on other WI-Fi networks, so it's helpful if you ever end up in another place where you have a poor cellular signal but have Wi-Fi. To use this, you'll need to ensure your phone has Wi-Fi calling support and that it's enabled. Android phones from T-Mobile and Sprint will often include this feature, so look up how to enable it on your specific model of Android phone.
The iPhone 6 has built-in Wi-Fi calling, although it currently only functions on T-Mobile. AT&T and Verizon plan to support it in 2015. To enable this feature on an iPhone, open the Settings screen, tap Phone, tap Wi-Fi Calling, and activate it.
WI-Fi calling seems to be the future goal the industry - T-Mobile, especially - is pushing towards. With Wi-Fi calling integrated into your phone, you don't need to buy a specialized device. Your home Wi-Fi router works. And, when you go somewhere else where you have a poor signal, all they need is a Wi-Fi network and you'll be able to get a phone calls and SMS messages through it.
Image Credit: Carl Lender on Flickr, Nan Palmero on Flickr, Wesley Fryer on Flickr
hope that helps
Dec 29, 2014 | Motorola Mobility Moto G 16 GB Black...
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
4.Try to turn off/on Wi-Fi on the device.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
Oct 09, 2014 | Worryfree Gadgets 7inch Zeepad 7.0 Android...
Wifi will not connect
The below info is from user manual ... downloadable version @ www.pantech.com
Connectivity
This chapter introduces useful tips on how to connect to the
network available that enables applications of the phone to
run.
Using a Wi-Fi network
Connecting to a Wi-Fi network
1. Tap Settings from the applications menu.
2. Tap Wireless & networks > Wi-Fi settings.
3. Tap Wi-Fi to activate the technology.
4. Select and tap a network. You should enter the password
if the network is secured. indicates a secured Wi-Fi
network.
5. Tap Connect. Once the network is remembered, the phone
will automatically connect to it when in range.
Activating Wi-FI Connecting to a Wi-Fi
network
Note The icon next to each network indicates the strength of the
signal. For example, indicates the signal is poor while indicates
the signal is strong.
Using the Easy Setting
1. Tap on the top of the home screen and drag it down, or
press n in idle mode and tap Notifications.
2. Tap in Easy Setting. The icon turns red when the
function is on.
About network notifications
You are informed by default when a Wi-Fi network is available
around you. The message in the status bar indicates a
network is available. Tap Network notification in the Wi-Fi
settings if you do not want to be informed the availability of the
network.
Setting Wi-Fi networks
4. Tap Network notification if you want to know an open
network available.
5. Tap Automatic connection if you want the phone to
connect to Wi-Fi network automatically.
6. Tap WPS button connection if you want to establish a
new wireless connection using the Wi-Fi Protected Setup
(WPS). You should press WPS button on your Wi-Fi access
point within two minutes.
Searching for Wi-Fi networks
Jan 17, 2013 | Pantech Pocket
Televison & Video Logo
Top TV Box Televison & Video Experts
Christopher Sibiski
Level 1 Expert
electracon
shaun taylor
Are you a TV Box Televison and Video Expert? Answer questions, earn points and help others
