Dometic RM2620 Refrigerator Logo
Posted on Jul 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Refrigerator not getting cold enough
Refrigerator will start to get cold than after a while it seems to be luke warm its like it needs to be charged with freeon
Anonymous
Level 3:
  • Master 744 Answers
  • Posted on Jul 25, 2009
Anonymous
Master
Level 3:
Answers
744
Questions
0
Helped
240192
Points
2381
Hi..
the blower is broken or frozen.You need to defrost and clean it or the air passages are clogged...
thank u
rate me
2answers
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
Lennox 10HPB36-10P is blowing luke warm air.
What coil is getting cold? In cooling the evaporator coil should be getting cold not the outdoor condensing coil. Verify you have the tstat setup for heat pump, verify you have a proper refrigerant charge.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
1helpful
I have a trane xe 800 its blowing air but not cold air, i felt the copper/bronze tube running into the unit it is luke warm also no chill at all. where should i start checking to get my house cold again.
Hello, if the pipe with insulation is luke warm then either the unit is empty of refrigerant due to leak or the compressor is not running at all. Start by going tje the outdoor unitnand checking if the compressor is running, if it is then the unit has no refrigerant, if the compressor is not running then either a bad capaitor orbthe compressor itself might be bad.
2answers
Talkwhy is my ge refrigerator model gss20 iepaww side by side ( freezer not staying cold enough after i defrosted it after 3 weeks my refrigerator is also luke warm. after i unplug it and defrost it works...
Hello and Welcome to FixYa!
Check for the defrost unit working... There should be a periodic defrost cycle running to melt the frosted ice. If not, then the thermostat unit along with the timer and the heaters needs to be examined. Check for the drain channel for any blockage/clog... If there is some dust on the condenser coils, vacuum the coils to remove the dust/lint else ignore that too... Carefully diagnose the tripping of the thermostat/defroster unit as it seems to be faulty.
Hope, now you got a better picture,
Best of Luck,
Concerned.
Why won't the fridge or freezer get cold enough? We have turned it to the middle, highest settings, on Eco and off Eco...nothing seems to work. We have unfrozen meats in freezer and luke warm milk
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Not getting cold enough to freeze, How to check Freon
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Freezer not freezing and blowing luke cold air. Fan running full time.
rotate the defrost heater timer until it clicks and see if the defrost heater is working
13helpful
2answers
Freezer/fridge won't get cold enough
Madezmom, you have a defrost issue. If your model starts with 106 you more than likley have a bad defrost bi-metal, I will attach a picture of bad one. This sits on the evaporator in the freezer section behind the panel. You will have to remove the shelves and remove the back panel. Defrost the evaporator completely. The part number for the bi-metal is 2196155. See if yours is bulged like the one in the attached photo. If so, that's your problem..Catriver..post back.
Top Dometic Refrigerators Experts
Jay Finke
Jay Finke
Virgil Watts
Mike Cairns
Mike Cairns
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
