Im trying to do pip mode - Televison & Video
My 94 ford mustang is a 3,8 v6. It will turn over but wont start. I have checked everything and Im getting power to the coil box but no spark to the plugs, what do you think is wrong?
You can start here;
ICM Test
See Figure 1
  1. Remove the ICM from the front fender apron.
  2. Measure the resistance between the ICM terminals as shown below:
    1. GID-PIP IN: should be greater than 500 ohms.
    2. PIP PWR-PIP IN: should be less than 2,000 ohms.
    3. PIP PWR-TFI PWR: should be less than 200 ohms.
    4. GND-IGN GND: should be less than 2 ohms.
    5. PIP IN-PIP: should be less than 200 ohms.
  3. If any of these checks failed, replace the ICM with a new one.
Sep 03, 2010 | 1994 Ford Mustang
PIP fuzzes out, then snaps back in
It is definitely a circuit problem tf
it could be the pip board and or
components on or around it.would
require technical knowledge to
repair
Nov 30, 2007 | Sony KP-57HW40 57" Rear Projection...
We have a universal remote and the picture in picture was turned on accidentally..how do I turn it off..it's a hitachi tv
Usually the PiP button scrolls through the PiP modes, so your best chance is to find the button that did it and give it another press or two. If you're unlucky, you might find that on the original remote the button to turn off PiP was a seperate one that doesn't correspond to the universal remote... In this case, try unplugging the TV fro the power and leaving for a few hours before turning on again. This might reset the PiP setting.
Jul 11, 2010 | Televison & Video
I want to load my tv code from my vizio on my remote for my 321
I used 0178 to program my universal remote. You can also try 10056, 10178,10864,10885,11756,10056,11758, and 11499. Then you can try by dropping the "1" from the front of these codes.
Most good remotes have a programming function if this does not work, where the remote will "learn" the proper code.
The actual button remote codes are as follows:
0 00117
1 00121
2 00119
3 00123
4 00116
5 00120
6 00118
7 00122
8 00245
9 00249
Vol + 00183
Vol - 00187
Mute 00057
Channel + 00181
Channel - 00185
Power 00053
Enter 00164
Last 00247
Menu 00171
Guide 00244
Up 00168
Down 00166
Left 00170
Right 00037
OK 00164
Sleep 00054
PIP 00197
Info 00251
PIP Swap 00198
PIP Mode 00199
Exit 00216
Audio 00059
Input 00090
Wide 00138
TV 00110
AV 00105
Component 00231
HDMI 00174
MTS 00055
CC 00025
Zoom + 00165
Zoom - 00169
Freeze 00200
RGB 00253
PIP Ch + 00196
PIP Ch - 00203
PIP Input 00199
PIP Size 00201
Good Luck
Nov 30, 2009 | Vizio VW32L 32 in. LCD HDTV
Tiny picture
try hitting the PIP button on the remote, sounds like it is in PIP mode, and the vizios have many configurations of PIP
Mar 19, 2009 | Vizio L30WGU 30 in. HD-Ready LCD...
PIP is causing problems
You are lucky in that this is problem you can solve yourself with a little diligence. The set has defaulted to the 'Theater Mode'. It happens frequently with this model. It is merely a setting in the customer menu. Go into either SETUP or ADVANCED SETTINGS and look for something refering to 'Thearter Mode' and turn it off. An owners manual would help locate it.
Sep 01, 2008 | Mitsubishi VS-50604 50" Rear Projection...
Blurred picture
try the focus adjustment knob on the back of the flyback transformer....if that does not work...order a focus block
Feb 03, 2008 | Hitachi 53UWX10B 53" Rear Projection...
PIP function not working
Hi !
I'll have the same problem, but i solve it when i change the RESOLUTION OF THE COMPUTER of 1680x1050 on 1440x900 at 60hz
TRY IT !
Jan 11, 2008 | KWorld 1680 TV BOX HIGH-RESOLUTION...
I would guess to say the tuner for the pip is bad.
Nov 05, 2007 | Sony KP-57HW40 57" Rear Projection...
PIP for Sony KV-27XBR45 television trouble shooting
If you have the original remote for this TV on the pip menu (left side slider on remote all the way up) there is a pip off button. If you unplug the unit long enough it should go back to normal. If you go into demo mode and then exit mode you will again be out of the pip. With out the original remote you cannot easily turn pip off.
Apr 13, 2007 | Sony KV-27XBR45 27" TV
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
