Question about Health & Beauty
Hi? My edlund digital Poseidon scale does turn on and it only shows dashes ?
  • Gene May 11, 2017
    Hi Cotton Tail, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Have you tried replacing the batteries and resetting the scale?
    Habit-Forming:
  • 135 Answers
Hope this link is of some help...https://www.youtube.com/watch?v=BO89hqZfye4
Posted on May 11, 2017
Edlund ers 300 scale
This is not a camera - please repost in a more appropriate forum
Jul 13, 2017 | Cameras
Dashes
I have a Health-o-meter but not the same model. Mine still has the instructions pasted (loosely) to the bottom.
The secret is that you must initially press the lower (left or right side) corer for just a second or two. That causes a few dashes and then the scale reads 00.0. Then get on the scale and get your reading.
Alternative behavior:
If you initially press the corner for more than a few seconds it will cycle through User Numbers one through four. If you use that feature it remembers your weight from the last time so you can see the difference.
Apr 15, 2014 | Health-O-Meter Health o meter 844KL...
Error 2 . How can we solve this problem. Thank you, Margaret
I found this procedure which was given by Taran_2005. I just come to try him(it) on mine, that works.
"The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
  1. Remove the battery from the scale.
  2. Sit the scale on a hard surface floor.
  3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
  4. Re-install your battery.
  5. Place the scale back on a hard surface floor.
  6. With one foot only, place just enough weight on the scale for the display shows zero's or dashes. Once you see zeros or dashes remove your foot.
  7. Wait for the scale to turn off again.
  8. Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away."
Sep 10, 2011 | Terraillon FBC Alteo Family Body Control...
Instruction manual for poseidon jet stream regulator
Manual:
http://www.frogkick.dk/manuals/poseidon/1999/
Service manual for all poseidon regulators (trained scuba technicians only):
http://www.frogkick.dk/manuals/poseidon/2003/manual.pdf
May 31, 2010 | Poseidon Odin/Jetstream Regulator
Taylor 7532S, battery replaced, error message 0-Ld
Try to reset the unit. Use the following steps
- Open the battery compartment on the bottom of the scale. Push the tab on the door and lift the cover.
- Remove the battery from the compartment. Close the battery compartment door.
- Sit the scale right side up on a hard surface floor.
- Step on the scale and stand still on it for five to ten seconds. Step off the scale.
- Turn the scale over and open the battery compartment. Re-insert the battery. Close the battery compartment cover.
- Place the scale right side up on the hard surface floor.
- Press one foot on the scale until the display shows zeroes or dashes. Remove your foot.
- Wait for the scale to shut off by itself. When you step back onto the scale, it will be reset.
Hope this solution has been helpful?
Jan 26, 2010 | Taylor 7532 Ultra Thin Glass Digital Scale
Nothing will display on the read out
  6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jan 03, 2010 | Taylor Dgtl Body Fat Scale
Scale displays OUT2
you need just to recalibrate it:
The procedure is standard for semi-all models of pocket scales, but the way how to get to calibration mode differs from model to model (or vendor to vendor).
In brief:
1.While turn-on get to the calibration mode (by pressing and holding the ON button, or holding TARE while turinig on) You should hold this "magic" combination until the LCD will show a number (large number - it was more than 2000 in my case). This number is a raw data from the sensor.
2.Now release the "magic" button.
3.Press it one more time, the display will show 2Ero and then 100.0
4.Now put calibrated weight of 100 grams on the scale and wait 3 seconds.
5.Press "magic" button again.The display will show CAL and then PASS.
6.Now remove the weight and turn off the scale.
7.Thats all - now you can use your scale as usually.
Jul 26, 2009 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
How to calibrate a taylor scale 5571
The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight,to calibrate, or some other unusual error.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department.You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jun 13, 2009 | Taylor Body Fat Analyzer & Scale, Model...
Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Feb 11, 2009 | Taylor & Digital Scale Lithium Scale
Digital scale
if scale  shows 0.000 after placing some weight on pan, it means sensor or load cell connection is open, please check sensor connection.
Mar 23, 2008 | Digi 2.5 lb x 0.0002 lb AC/DC Digital...
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
