Question about Garden
Changed engine oil with 5W 30. While pressure cleaning noticed blackened concrete beneath washer. Engine stopped suddenly, but not out of gas. Started and ran 1 minute, now can't pull, seized. Ideas?
    Top Expert:
  • Garden Master
  • 44,485 Answers
Take it is a lawn mower
if the oil ran out then the engine is failed
if B&S , cheaper to replace the motor than to rebuild
Posted on May 11, 2017
Can I use 0w 20 Mobil 1 oil in my snow blower
It can be used, although the manufacturer recommends;
Super S 5W-30 Snow Thrower Engine Oil - Sears
www.sears.com/explorer-5w...snow-thrower...oil/p-07188298000P
Sears Rating: 4.5 - ‎5 votes
Oct 21, 2010 - Explorer 5W-30 snow thrower engine oil is a premium formulation for use in all four cycle engines when temperatures are below 32 deg. F. Explorer 5W-30 snow thrower engine oil protects the engine by lubrication, cooling, cleaning and sealing internal moving parts.
Aug 23, 2015 | Craftsman Snow Blower / Snowblower Bottom...
Why is the oil in my honda gc 190 grey
grey oil is water contamination. check for leaking seals to stop water getting to the oil
May 21, 2015 | Karcher 3000 PSI Gas Pressure Washer with...
Can I use 5w 30 weight instead of 10w30 wait for a
Yes
10W-30 is seldom used- the last 15 years
You can use 0W-30,5W-30
I only use MOBIL 1 Extended (walmart)
I would guess all GM Vehicles have called
for 5W-30 since 1980
Oct 16, 2014 | Cars & Trucks
Have a 2003 toyota corolla and oil pressure light came on we changed oil and now its on again what could it be?
If you just changed the oil, therefore we can assume that the oil level is correct at this time and that the correct oil viscosity (5W-20 or 5W-30) was used. Are there any unusual noises coming from the engine? Like, maybe "tapping" or "squeaking" sounds? If so, then the oil pump may have gone bad and is not supplying adequate oil pressure to the engine. Continued use of the vehicle can result in serious engine damage. Have the oil pressure checked by a shop ASAP.
If the vehicle is running normally and no unusual noises are heard, then the oil pressure sensor (a.k.a. oil pressure sending unit) may be sending a false signal to the dash "idiot light". Replace the oil pressure switch.
Hope this helps.
Have a Nice Day !!!
Apr 15, 2011 | Toyota Corolla Cars & Trucks
What grade of synthetic oil does my 2003 vw new beetle take
IF YOU HAS GAS ENGINE USE API CERTIFIED FOR GAS ENGINES USE 5W 30 FOR COLD WEATHER. YOU CAN USE 5W 40 FOR WARM AND HOT CLIMATE. FOR DIESEL ENGINE YOU NEED API SERVICE CF4 OR CG4 USE MOBILE 1 OIL 5W 30 COLD WEATHER AND 5W 40 FOR HOT CLIMATES ALSO CHECK IN OWNERS MANUAL.TO BE ON THE SAFE SIDE OR ASK THE AUTO PARTS SALESPERSON TO LOOK UP TYPE OF OIL YOU SHOULD USE TO KEEP FROM DAMAGING THE ENGINE IF YOU HAVE TURBOCHARGER.
Apr 12, 2011 | 2003 Volkswagen New Beetle Convertible
2003 Chevy Trailblazer V-6 4WD. I just got the oil changed. I think I made a mistake and told them to put in 10w-30 instead of the 5w-30 that the vehicle was used to. Since then, my SUV has been sputtering...
CHECK YOUR OIL DIP STICK MAKE SURE YOU HAVE ENOUGH OIL IN THE CRANKCASE.YOUR ENGINE CALL FOR 7 QUARTS OF OIL. IF YOU HAVE THE INLINE 6 CYLINDER.CHECK OIL LEVEL ON DIP STICK.YOU SHOULD BE AT FULL MARK.AND NOT ON THE LOW MARK.IF SO YOU NEED ADD LITTLE MORE OIL TO GET TO THE FULL MARK.YOU CAN USE 10W 30 FOR SPRING AND SUMMER WEATHER. 5W 30 FOR COLD WEATHER COLD CLIMATE.I RUN 10W 30 YEAR ROUND IN ALL MY NEW CHEVY AND OLDSMOBILE VECHICLE HAD NO PROBLEMS.IF OIL LEVEL CORRECT YOU COULD HAVE FUEL PROBLEMS.COULD HAVE STOPPED UP FUEL FILTER, BAD GAS,
Apr 12, 2011 | 2003 Chevrolet TrailBlazer
What type of engine oil will need for my toyota
FULLY SENTETACHIC OIL ,VERY GOOD FOR ENGINE WITH ALOT OF MILES KMS UP
Jun 18, 2010 | 1998 Toyota RAV4
Gas got into the oil through carb. changed oil. rope won't pull. 13hp briggs on a generator.
STOP...The engine crankcase is FULL of gas and oil..NOT A GOOD THING...
remove the spark plug,,,drain the oil.. let the engine "air" out,,, have the carb cleaned and set..
Jan 28, 2010 | Briggs Stratton 020273 Elite Series...
High gas mileage (15- 20 l per 100km)
try changing the oil also it will cause the engine to burn more fuel with bad oil because it gets hot and evaporates it alot more
Feb 03, 2009 | 2003 Dodge Grand Caravan AWD
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
