Question about Toys
How do i remove grill on a toy dyna mod no bu61r Regards Pete
Hi, I have just removed the crank speed sensor from a 2001 8n Audi TT and the 3 wires fell out of the plug. Please help. Regards Pete.
Hi pete the plug should have numbers on it (very small difficult to see) the colour code is as follows
no 1 =sw/black
no 2=br/brown
no 3=ws/white
hope that helps
Nov 23, 2014 | Cars & Trucks
How do you open the grill to charge the battery
sometimes there is a Philips head screw in the middle on top of the grill that needs to be removed, and then there is two clips on the side of the grill that pull outward toward the tires to fold the battery compartment down
Mar 10, 2014 | Peg Perego John Deere Gator HPX Ride on...
How do i get my chuggington, puff around old town with pete set make steam?
Look on the bottom of the steam maker, shows how and where to pour water.
Jan 08, 2012 | Toys
Where is the battery?
  • Hi, I can help.
  • The battery is behind the grill of the tractor.
  1. There is a screw top/center of the grill that needs to come out.
  2. Then there is a little latch to move out of the way.
  3. Now the top lip of the grill pulls down and the battery slides out.
  4. Please see the diagram bellow for a visual.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa
Regards, Tony
Aug 30, 2011 | Peg Perego John Deere Gator HPX Ride on...
Grill element not working on rangemaster 110
If grill element not working, switch power off and remove back panel to gain access to wiring. Grill element will be toy element. look for any burnt wire, either blue or brown. Re attach where broken and reassemble. If you have any doubts call a technician. Not to difficult though.
Jun 05, 2010 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Jrg electric fire mod jrg 930 how do you get access into element area
There are two retaining screws partially hidden at the bottom of the front grille. Remove these two screws completely. Then slide the whole grille downwards until the two top retaining tabs are exposed. Lift off the grille.The elements are retained with springs. Push the element deeper into the LH socket until the RHS is free and then remove.When replacing the grille make sure the bottom edge is in first, then slide upwards until the tabs are located in the slots, and replace the two screws.
Oct 02, 2008 | Heating & Cooling
Toys Logo
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
