Question about Brother Sewing Machines
I have a Brother CE4000. Bobbin carriage will not spin
The plastic part that holds the bobbin appears to be jamming against the feed dogs. The machine was working fine and then it just stopped. It jammed and bent the needle. Would not advance forward at all. I assumed the machine was dirty, so I took the plate off the top of the feed dogs and cleaned out all the dust. I put it back together and it still has the same issue. Please offer any assistance you can. Is there some adjustment I can make. Thank you in advance.
  • 46 Answers
It is a good idea to clean as you did. However, you must put the needle plate back on the machine first, then the bobbin case is inserted(more on that) then the "L" shaped gray cover. Make sure the b-case is laying level on the surface of the hook and the little bump at about 6 o'clock on the case is touching the spring at about 6 o'clock in the machine. Test a sample.
Posted on Jul 25, 2009
I opend and rise up feed dog and boobin runing around free; if i close feed dog it is jamming bobbin.what a problem
Depending on your machine, your bobbin spool might be too thick
try plastic bobbins, they are thinner than matal ones
Oct 15, 2014 | Sewing Machines
Deco Bernina bobbin jammed, now bobbin won't work
remove bobbin and reinsert. Re thread needle . Make sure the right size of needle for the material. And check that there is not a wad of fluff under the feed dogs.
Best wishes
Aug 22, 2014 | Bernina Sewing Machines
Thread tangling inside bobbin case catching on another part
1. thread machine correctly.
2. make sure bobbin case in spinning in the case in the correct rotation. If the bobbin is spinning off of the bobbin incorrectly, "bird nesting" is the result.
Jul 20, 2014 | Brother NX-400
E6. Motor locked up because the thread is tangled. I have re-threaded machine and bobbin; thread still tangles after 2 or 3 stitches. HELP!
In my Brother CE-4000, it appears as though the feed dogs (which you can change to a higher position or a lower position) are allowing the bobbin case to spin all the way around and then the needle hits the bobbin case. When the feed dogs are in the lowest position, the bobbin case does not spin all the way around when the needle moves up and down (and therefore the needle does not get stuck in the bobbin case. I am wondering if this is a problem with the feed dogs/case?
Jan 18, 2011 | Brother CE4000 Computerized Sewing Machine
Machine Jamming after a few stiches
Change needle
Clean under needle plate where feed dogs are for lint
Clean bobbin area for lint or loose threads
Rethread machine top thread make sure to get every thread guide
keep a check on the thread take up lever to make sure the thread doesn't come off of it
& bobbin
Check tension 3 or 4 is usually good
Nov 23, 2010 | Brother CE4000 Computerized Sewing Machine
The plastic part that holds the bobbin appears to be jamming against the feed dogs. The machine was working fine and then it just stopped. It jammed and bent the needle. Would not advance forward at all. I...
This is the main link for brother usa parts finder Industrial Garment Printers and Industrial Sewing Machines they should have the part or know where you can get it . If you don't find it online call and talk to them. If the bobbin case doesn't fix it you may need the timing set, but I would try the bobbin case first.
Apr 13, 2017 | Brother Sewing Machines
My ce4000 started jamming up thread under the foot and then it pulls the bobbin case and gets stuck so that it doesn't sew at all
If the thread is getting jammed under the FABRIC then it means the TOP thread is threaded wrong. Just the opposite of what we think it should be. If the thread is looping on the TOP of your fabric it's the BOBBIN thread that's not threaded right. If it's a front loading bobbin, the thread should go over the top of the bobbin to the right before placing it in the bobbin case. Hope this helps!
Aug 21, 2010 | Brother CE4000 Computerized Sewing Machine
Thread jams in bobbin case
Open the bobbin area and make sure it is clean.
Change to a new needle.
Thread the machine with the presser foot up.
Make sure the bobbin thread is feeding in the correct direction from the bobbin spool and through the guide on the bobbin case.
Take hold of the end of the top thread and lower, then raise the needle to pull the bobbin thread up.
Take hold of both thead ends and pull them under the presser foot and to the back of the machine.
Place fabric under the presser foot. Lower and hand walk the first couple of stitches.
When sewing, and you need to stop to adjust the fabric, make sure the needle is down into the fabric. This will keep the stitch from malformation and causing a possible tangle.
If you need a manual, you can download one free at the Brother website.
Mar 20, 2010 | Singer 3116 Simple
Sewing Machines Logo
200 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
