Question about Ariens Garden
I have an Ariens lawn mower. The mower deck starts running when it isn't even engaged! We just put a new belt on. I don't even know where to start.
    Top Expert:
  • Ariens Master
  • 12,744 Answers
To small a belt or put on wrong
Posted on May 11, 2017
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ... > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from
Dec 29, 2015 | Garden
I have a ariens z 2048 when I engage the pto, it works but won't handle an even moderate load. Has new belt and blades would a bad battery cause this?
If your engine is running properly then battery has effect on the PTO.
It is more likely that your engine is running on one cylinder and that the extra load of deck is just too much for it.
Apr 17, 2015 | Ariens Garden
Mower starts and runs beautifully until i try and engage the cutting blade.It smokes badly... doesn't seem the belt is moving. its practically new, just purchased it in July 2013 and only used it three...
Something is jammed under the deck. If the engine runs good until you engage PTO, the problem is in the deck. With engine off, disconnect belt for deck from PTO, then remove deck and flip it over. With belt off try to spin blade. They should spin freely. If not, you have a bad bearing which are fairly simple to replace, just a few bolts. FYI, draw a diagram or take a picture of belt routing before removal, this will be good to refer to for installation of belt when your done. Hope this helps.
Sep 06, 2013 | Ariens Garden
Ariens Sport Zoom 1440 blades engage slowly
check that the grass has not bunched up around the spindle and shaft in such a fashion that it is jamming the blade to the deck and acting like a brake
Jun 06, 2013 | Garden
My deck mower(craftsman 917.271530)keeps shredding deck belts
You either have a bad bearing on one of the pulleys or one is loose and moving up and down drawing the belt when it is engaged. I would pull the mower deck off and go through it .
Apr 17, 2012 | Sears Garden
My MTD riding lawnmower is burning thru the new belts I just purchased.The new belts are 954-0371A which replaces 754-0371A. The old style belt lasted 5 years. Even before engaging the clutch, the belt...
My idea is not about the belts, but is about the deck. If the tensioning mechanism on the deck is getting stuck in an intermittant position than the belt may be just tight enough to turn blades while slipping through the pulleys, this may cause enough friction to start melting your belts. If this is the case you will have to remove your mower deck and see what is preventing the mechanism from functioning properly.
Jul 07, 2011 | MTD LAWN MOWER PART 1909404 BELT
Changed my mower belt now my mower will not start. Is there something i might have done so it will not start. it doesn't even try to turn over.
You may have the mower 'engaged'.
Now you know and I know this is not the case ... but the mower has to know it. There are a series of what are called "operator presence" safety switches. You may have bumped one of these switches into the "engage" mode telling the mower there is a 'safety vilolation' - don't start.
Check out the switches and adjust as may be necessary. You may find out where it is by removing the belt and even removing the deck to see if the engine will start. With the deck removed (yea i know it is a lot of work) you will have better access to the area most likely to have the switches. (There is a switch in the seat also ... you must be on the tracor to start unless the parking brake is set (on most mocels)). You coud consult your operators manual for further details on this matter.
Thank you for your interest in
May 31, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman riding lawn mower...engine dies when blade is engaged
Push the clutch all the way down and try to start, does it crank over?
Let me know.
May 10, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
52 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
