Should my tv be set on atv or dtv we don't have cable its a digital tv with a digital antenna on our roof
    Top Expert:
  • Televison & ... Master
  • 41,853 Answers
Should be set on dtv; atv is analog
Posted on May 11, 2017
Testimonial: "when I checked the channels there was a check mark by the main channels and they were set on atv how do I get it changed??"
  • Diane Lulloff May 11, 2017
    just did the setup wizard again hopefully that helps
SOURCE: LCD TV LA40A650A1F. TV/DTV
samsung advised  atv/dtv selection by that button not available on australian series 6
Posted on Sep 23, 2008
  • 1779 Answers
SOURCE: No DTV on my 2006 Polaroid FLM-2632 model 2700?????
Try going into your menu and putting the input to Antenna, then reprogram, let me know!
Posted on Feb 18, 2009
SOURCE: Dynex TV Model DX-LCD32-09 Does Not Pick Up DTV Signals
Yeah I have the same model and there's no built in antenna. You have to use an external. I used to work for the geek squad in a Best Buy store and I can tell you from experience that that salesman may or may not have actually known that there's no antenna built in. It's not uncommon for them to tell small lies like that to get you more interested in the product. I witnessed it a million times before I finally quit because they wanted me to be the same way.
Posted on Feb 28, 2009
  • 8457 Answers
SOURCE: I am in Los Angeles,Ca. Converter box signal problem
Just go to walmart and buy a good digital antena.Should work great.Just rescan all ur channels again.
Posted on Mar 11, 2010
Testimonial: "thanks...should i get an outdoor one on the roof? It's got hills around here How do you know which way to point the antenna? i am in Los angeles"
welcomejee
  • 10594 Answers
SOURCE: broken coax cable connector/DTV/TV Cable/Antenna
Tuner will be replaced because Coax Connector is fixed part of tuner and next problem is that tuner is not available as spare part, it is mounted on tv main board so main board will be replaced to solve Coax Connector problem OR check with local tv repairman if he can do some thing with connector.
Below image is main board of tv and tuner is marked with yellow circle to have better idea.
Hope this will help.
Thanks.
Posted on Jul 09, 2011
How do I watch normal tv on my audiosonic television ?
That depends upon which source your "normal" TV is connected. If you have a cable box using a coax cable, then you will either select the DTV source if the cable box uses digital output or a digital over-the-air antenna, and ATV source if the box is using analog signals or if you are using an analog over-the-airwaves antenna. If you are using a cable box but have an HDMI cable connecting it to the set, then you need to choose HDMI1 or 2 as appropriate. If you have a box that uses the red-black-yellow RCA cables, then select the AV input. Remember that for ATV and DTV inputs from a cable box, you usually have to tune the set to either channel 3 or 4 and use the box to change the channels.
Jan 05, 2016 | Televison & Video
I cannot change from the ATV to the DTV. ANY clues on how to do this??
Got to know the model number of your tv. If the set is only atv then you would need a decoder box to convert digital signal from antenna or cable company to analog channel or to composite input on the tv.
Mar 17, 2015 | Televison & Video
I have color on all but 1 TV station. That staion has color on other TV's in my house. Any sugestions?
Ur tvs in ur house it is getting a paid tvs incomming broadcasting tv signals like a cables or a satalites dishes companies?Yes,than that incomming broadcasting wire that plug into ur tv Ant. input port hole might have some kind of signals interference at that channel frequencies,call ur cables tvs or satalites tvs companies providers for an answers and get their field Tech. to come out and check it out.If all ur tvs in the house are analoge tvs and u are using a DTV signal through a DTV converter box to getting a Free over the air DTV air to recieving tv broadcasting tv channels stations only than tries it with another antenna signals sources like a better antenna design like a portable digital antena or good roof antenna should solved this problems.
Oct 03, 2011 | Philips Magnavox 20MS3442 20" TV
Does this model have a digital tuner or do I need to have a box to watch televison over the air?
Yes this tv dose have a digital tuner inside of it,all flats LCD and Plasma tvs are Digital tvs they all can get free DTV air broadcasting tv channels.All digital flats LCD and Plasma tvs are DTV set u just require a very good like a roof Antenna or a newly Digital design portable Antenna connected the tv incomming air broastcasting signal cable back of to the flats screen tvs at the axail input call ANT.Then go into the tv menu.Goto setup go down pick AIR than press the enter button for scanning for free DTV air broadcasting channels.After the tv finish scanning for channels than the tv will let ur tv to get all the free DTV broadcasting channels.
Sep 29, 2011 | Olevia LT32HVE 32 in. LCD Television
I purchased the PT902/37B and charged it of course. Turned it on for the first time and the instructions say I have a no/weak signal, I reconnected the antenna and still nothing. Can you help? Thank you,...
U follow the tv owner manual instuctions for scanning for the DTV free over the air broadcasting by the tv stations signal yet.Do that first,still have a message weak or no signals.Buy a newly design Digital antenna or have a roof antenna already hook it up to the tv,follow the owner manual rescan it again will have all DTV free over the air broadcasting tv channels.
Jun 13, 2011 | Philips Televison & Video
Why won't my new Vizio DTV work on an antenna without the digital box?
Do you have the antenna aimed correctly and the correct antenna for the distance between your location and the stations? Check antennaweb.org and tvfool.com for the directions to the stations you should be able to receive. Antennaweb assumes an external antenna and is very conservative in the station list. TVfool gives the stations you should get with various different types of antennas. Tall trees and buildings will block signal strength so consider the environment around you.
With digital signals, if you do not have enough signal strength for a given tuner, the channel will not come in. An amplifier may help you get the signal, particularly if the signal is shared to several devices. Failure of an amplifier or lightning surge protection can stop the signal from reaching the TV. A surge through the antenna can damage the tuner.
A damaged cable can also be a source of a problem. Check the outside portion of the wire as well as the interior wires. Replace any that have damaged insulation or ends.
For this TV, if you have done a channel scan with the TV set to the Input TV/DTV, and the Signal Source set to Antenna. Turn the antenna and then set the Additional Scan to On. (Menu > TV > Channels > Additional Scan.) Then do another channel scan.
If you need a copy of the manual, see: http://www.vizio.com/m220va.html#support .
Jan 22, 2011 | Vizio M220VA 22 in. LCD HDTV
I have an LG47LG70 tv which has recently started flashing the screen on and off when hooked up to the local antenna. It works fine when hooked up to the Dish Network cable. I have replaced the antenna...
Tries hook up to a roof antenna or a better antenna like a digital antenna.Than rescan ur tv again,for those DTV free air channels again.Ur tv now,should get all those DTV free air channels.
Nov 05, 2010 | LG 47LG70 42 in. LCD TV
Tv wont pick up channels
Have you been into scanning settings and set to DTV , it seems like you are either on ATV or have a bad Antenna connection. If signal is weak from your Antenna you can add a booster in the section between your wall socket and the TV. You cannot use Satellite dish connections to receive either ATV or DTV signals without a set top box ...
Dec 05, 2017 | Coby TF-TV1901 19 in. LCD Television
My dtv keep saying nosignal antina hooked up .protron tv was working fine ran scan station. stop playing
dtv needs a strong signal to keep track of the channel. The antenna is good inside the room but tends to be affected for interferences. to catch signal (as in the past with ear rabbit antena) is difficult inside the room. and roof antenna is better but needs a good installation. the cable channels can work digital without the dtv. Is hard to give you any idea besides this ones because i don't know how the set up[ is in your case problem, but i hope i could help you a little. Now if the antenna is rasonable good and still having problems with your channels the suspect the dtv failure.
Apr 24, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
Can I receive a digital signal and if so, how?
I'm pretty sure this TV already has an NTSC/ATSC/QAM tuner in there, and should need no converter box whatsover... I say this because I own one...
Mar 09, 2009 | Insignia NS-27 TV TV
Televison & Video Logo
Top Televison & Video Experts
