Should my tv be set on atv or dtv i dont have cable we have a digital tv with a digital antenna and its saying no signal
2 Suggested Answers
  • 36596 Answers
SOURCE: Should my tv be set on atv or dtv we don't have cable its a digital tv with a digital antenna on our roof
Should be set on dtv; atv is analog
Posted on May 11, 2017
Testimonial: "when I checked the channels there was a check mark by the main channels and they were set on atv how do I get it changed??"
How do I watch normal tv on my audiosonic television ?
That depends upon which source your "normal" TV is connected. If you have a cable box using a coax cable, then you will either select the DTV source if the cable box uses digital output or a digital over-the-air antenna, and ATV source if the box is using analog signals or if you are using an analog over-the-airwaves antenna. If you are using a cable box but have an HDMI cable connecting it to the set, then you need to choose HDMI1 or 2 as appropriate. If you have a box that uses the red-black-yellow RCA cables, then select the AV input. Remember that for ATV and DTV inputs from a cable box, you usually have to tune the set to either channel 3 or 4 and use the box to change the channels.
Jan 05, 2016 | Televison & Video
I cannot change from the ATV to the DTV. ANY clues on how to do this??
Got to know the model number of your tv. If the set is only atv then you would need a decoder box to convert digital signal from antenna or cable company to analog channel or to composite input on the tv.
Mar 17, 2015 | Televison & Video
I purchased the PT902/37B and charged it of course. Turned it on for the first time and the instructions say I have a no/weak signal, I reconnected the antenna and still nothing. Can you help? Thank you,...
U follow the tv owner manual instuctions for scanning for the DTV free over the air broadcasting by the tv stations signal yet.Do that first,still have a message weak or no signals.Buy a newly design Digital antenna or have a roof antenna already hook it up to the tv,follow the owner manual rescan it again will have all DTV free over the air broadcasting tv channels.
Jun 13, 2011 | Philips Televison & Video
Cannot get TV to work on antenna...In menu I set cable to off, then initiate autoprogram but tv says "no signal". My antenna has a bulit in digital to analog converter. Suggestions?
Must buy a Digital converter box and to install it seperatly to devert back to tv anlogue tv signal to make the tv to work.Tv antena inverter alone can't convert analogue signal to digital signal only can give basic tv antena for better antena reception.Tries websites like Ebay.com,Amazon.com to buy a stand alone digital converter box to install and that didigal antena install and auto scan again u should able to get all the free DTV air stations.
Feb 01, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Why won't my new Vizio DTV work on an antenna without the digital box?
Do you have the antenna aimed correctly and the correct antenna for the distance between your location and the stations? Check antennaweb.org and tvfool.com for the directions to the stations you should be able to receive. Antennaweb assumes an external antenna and is very conservative in the station list. TVfool gives the stations you should get with various different types of antennas. Tall trees and buildings will block signal strength so consider the environment around you.
With digital signals, if you do not have enough signal strength for a given tuner, the channel will not come in. An amplifier may help you get the signal, particularly if the signal is shared to several devices. Failure of an amplifier or lightning surge protection can stop the signal from reaching the TV. A surge through the antenna can damage the tuner.
A damaged cable can also be a source of a problem. Check the outside portion of the wire as well as the interior wires. Replace any that have damaged insulation or ends.
For this TV, if you have done a channel scan with the TV set to the Input TV/DTV, and the Signal Source set to Antenna. Turn the antenna and then set the Additional Scan to On. (Menu > TV > Channels > Additional Scan.) Then do another channel scan.
If you need a copy of the manual, see: http://www.vizio.com/m220va.html#support .
Jan 22, 2011 | Vizio M220VA 22 in. LCD HDTV
Digital Signal on my Conia TV has gone. Cant access menu for DTV
I would guess that you are using either cable or satellite for reception. If that is the case, the signal is already a "digital" one. The digital reception you are attempting to receive is the over-air broadcast signal that was implemented recently. This change-over only effected those using external antenna connections. Cable and satelite systems have not changed.
Hope this helps,
Dan
Jun 18, 2009 | Televison & Video
My dtv keep saying nosignal antina hooked up .protron tv was working fine ran scan station. stop playing
dtv needs a strong signal to keep track of the channel. The antenna is good inside the room but tends to be affected for interferences. to catch signal (as in the past with ear rabbit antena) is difficult inside the room. and roof antenna is better but needs a good installation. the cable channels can work digital without the dtv. Is hard to give you any idea besides this ones because i don't know how the set up[ is in your case problem, but i hope i could help you a little. Now if the antenna is rasonable good and still having problems with your channels the suspect the dtv failure.
Apr 24, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
Can I receive a digital signal and if so, how?
I'm pretty sure this TV already has an NTSC/ATSC/QAM tuner in there, and should need no converter box whatsover... I say this because I own one...
Mar 09, 2009 | Insignia NS-27 TV TV
Cable box
Yes, this TV will need a converter box if you are getting off-the-air reception. It does not have a DTV tuner built in (too old) although is a high-def capable set.
Dec 06, 2008 | Mitsubishi WS-55807 TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
