Question about Garden
Need a pump for predator 4hp 2500 2.4 gpm item number 62201
2 Suggested Answers
  • 12 Answers
SOURCE: AR 2.5 GPM 2500 PSI pump allows water through when
pump requires rebuilding
Posted on Mar 16, 2010
Oil leak under machine, how do you tell if pump needs more oil
Oil is leaking from the engine. Pump does not have oil in it.
Sep 01, 2016 | Campbell Hausfeld 2500 Psi, 2.4 Gpm,...
Looking for part number on carburetor for workforce WF80710
Did you check with Home Depot to see if they can help you? It is one of the products they distribute under the Homelite brand.
Sep 25, 2015 | Homelite Workforce 2500 PSI 23 GPM Axial...
Where do i get a 2200 psi pump?
It depends on what you want the pump for, but at 2200 psi, I presume you are looking for something like a pressure washer pump.
Harbor Freight sells a 1600 or 2500 psi pressure washer
If you need just the pump, here are a couple of websites to check out:
Pressure Washer Direct
Northern Tool
And you can check on Amazon or eBay and see if someone is selling one there.
Sep 04, 2014 | Garden
Brand new will not start
is there a fuel shut off valve thats not turned on
Apr 03, 2012 | Homelite Workforce 2500 PSI 23 GPM Axial...
Need Manual for WorkForce Pressure Washer WF80710
Nov 09, 2011 | Homelite Workforce 2500 PSI 23 GPM Axial...
1/2hp Hayward Pump for existing inground pool
you will be fine with the 1/2hp. The Hayward will move quite a bit of water as well. It may not move as much water as the 3/4hp but it's very close and the 1/2hp will cost a little less to operate so if anything, you may just have to run it for one additional hour per day to compensate. You will be surprised how much water a 1/2hp will move. The only issue with smaller pumps is if you have pop-up cleaner heads or a suction driven automatic cleaner such as a kreepy krauly, however, if a 3/4hp will run it, a 1/2hp will run it as well. You can install a larger motor on the super pump but it will not move more water unless you upgrade the impeller as well. Just make sure you don't use a bigger impeller than what the motor is rated for because it will strain the motor and cause it to overheat. Hope this helps.
Feb 20, 2010 | Hayward SAND FILTER, PRO SERIES
How do you wire a 2 wire Franklin 1/2 HP 10 GPM
you can just install a regular plug to the end of the wires and plug it in,, but you will need to add a ground wire,, if there is only 2 wires there should be 3 so look for a screw with a spiral clasp on it for the ground,,
Apr 21, 2009 | Franklin ELECTRIC/LITTLE GIANT PUMP 1/4HP...
I have experienced this same problem and all I needed was to prime the pump. Unless your pump cannot pump up that high.
Jan 09, 2009 | Little Giant Opwg 71 71 Gpm Out of Pond...
Execetive 56 4hp pump
Looking at the face of the pump, the impeller unscrews by turning it counterclockwise. Also, for some strange reason, the 4HP pump gets a 3HP impeller; the rating is embossed, in very small letters, near the center of the impeller. The 3HP impeller part number is: 310-4200.
Be sure to change the seal: US Seal P/n: PS-1000.
Oct 20, 2008 | Waterway Spa Pump Executive 56 Frame 4hp...
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
