Question about Verizon Cell Phones
How do I factory reset my Verizon ellipse tablet that's on but stuck in safe mode
I can tap the screen but it's saying out loud to double tap to activate then press and hold
SOURCE: My dell axim x51v is frozen where says
On the left side of the pda is a little slide button with a lock symbol on it, make sure it is slid down. This button is a key/screen lock to ensure you dont push any buttons accidentally.
Posted on Jun 19, 2009
bhagyavichar
  • 414 Answers
SOURCE: My laptop wont exit safe mode even when pressing
this is a case of os corruption somehow..!!..may b a virus/trojan or hardware or software is responsible..
all u need is the os boot cd anyway..
probably now u got two way out:
goto somecyber n download win xp pro sp2, using any bit-torrentclient(like utorrent) from torrent site (eg. mininova.org so on)..make aboot disk n try..
1) copy the file in windows repair mode or from any identical os n put it in place as stated above..
OR 2) reinstall os..
(to takedata backups u gotta connect the hdd to another pc/laptop, forsuch cases a hdd-case is available in the local spare market, it'llmake behave ur hdd to act as an external removable drive)..
thiscan also b a symptom of faulty/defective of RAM..pen clean/removecarbon& or oxide formed on the teeth with an eraser n resitit..[it'll b more prominent, that if itz cause by ram or not,..if duringnormal operation, a Blue Screen appears/Memory Dump]
though, sometimes itz also caused by the m/b..
there are also exceptions, where it is found that any hardware componenton the system is loose or incompatible (see addon cards, the ram(s),the hdd (if itz making any 'ticking' noise like 'kirr kirr' or 'tuc tuc'), all data cables n power cords, may b dusty, cpu overheating,see filter/power/south bridge/crystal clock generator section of m/besp mosfets and capacitors..etc)..
if once u can login, do the following:
hv a licensed and UPDATED antivirus installed (i prefer avg/kaspersky, , without updation a full version antivirus is useless)..
download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'remove all the unnecessarystartup items from here..(if u can't find what to remove,post me/us inur comment with all the items listed in each n every tabs herein)..
remove all unnecessary software from add/remove programs..
download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
disablethe following: a) 'Automatically Restart' right click on mycomputer->properties->advanced->startup n recovery->(uncheckon the) Automatically Restart; b)'Error Reporting 'right click on mycomputer->properties->advanced->error reporting->disableerror reporting->(uncheck on the) 'but notify me when critical erroroccur'..
Increase the size of Virtual Memory, Initial: 1440; Maximum: 2880
always better to seek professional advice of ur system admin/vendor....
Posted on Nov 12, 2009
  • 8457 Answers
SOURCE: i have a dvdvr375 that needs factory reset. How?
Try unplug,replug the unit back an hour later,should have everythings,reset to Factory setting.If no,electronic component's parts burn in ur device.
Posted on Jul 29, 2010
SOURCE: Samsung Exclaim Stuck in Safe Mode
NEED TO FULLY FLASSH MY SAMSUNG EXCLAIAM SPH M550
Posted on Oct 04, 2010
Deneenie
  • 73 Answers
SOURCE: reset kurio 7 tablet to factory settings
press and hold VOL+ and Power button simultaneiously.
http://www.kurioworld.com/us/pdf/Kurio_Manual_US.pdf
Posted on Dec 22, 2012
Gccant get my sa?fe mode off. My rca andriod tablet
How do I get my Android tablet out of safe mode?
Use the following steps to get out of safe mode.
  1. Restart your device by holding the power button, then tap Power off.
  2. Tap Ok to confirm.
  3. Power the device on. Your tablet should now be out of safe mode.
If the device is still in safe mode use one of the following methods.
  • Uninstall the last application you installed:
    1. From the Apps menu, tap on Settings.
    2. Tap on the app and then tap on Uninstall.
    3. Restart your device.
Perform a factory data reset:
  1. From the Apps menu, tap on Settings, and then tap Backup & reset.
  2. Tap on Factory Data Reset, and then tap Reset Tablet.
  3. Tap Erase Everything to format your tablet back to factory default configuration.
Source: http://packard-bell-uk.custhelp.com/app/answers/detail/a_id/27146
Hope this helps!
Jun 26, 2017 | RCA Computers & Internet
I mistakenly locked it. how do I unlock?
Unlock the Device - Verizon Ellipsis 7 ' Verizon Wireless
www.verizonwireless.com/.../knowledge-base-88769/
Verizon WirelessRegister · Home > Support > Verizon > Verizon Ellipsis 7 > Unlock the Device -Verizon Ellipsis 7 ... Learn how to use your tablet with our Interactive Simulators · View your User ..... Depending upon the screen lock type, do one of the following:.
Enable/Disable the SIM PIN - Verizon Ellipsis 7 ' Verizon ...
www.verizonwireless.com/.../knowledge-base-89029/
Verizon WirelessVerizon Wireless Logo .... Home > Support > Verizon > Verizon Ellipsis 7 > Enable/Disable the SIM PIN - Verizon Ellipsis 7 ... Learn how to use your tablet with our Interactive Simulators ..... Personal Identification Number (PIN) locks the SIM card so it can't be used until the correct code is entered. ... Tap Set up SIM card lock.
How to unlock Ellipsis 7 if you forgot the password?
theinformr.com/answers/forgot-device-unlock-password/
Verizon · Verizon Wireless Ellipsis 7. 9 answers ... How do I reset my ellipsis 7when I don't remember the password or the email and it is stuck in airplane mode? ...About two months ago I purchased an ellipsis tablet from verizon. I do not ...
TECH TALK: Ellipsis 7 tablet (Verizon Wireless) - YouTube
? 7:51
https://www.youtube.com/watch?v=NBp0qIorSOU
Dec 9, 2013 - Uploaded by Alabamas13
My review of the Ellipsis 7 tablet from Verizon Wireless. ... howdo you unlock the freakin puk code ijust bought it from goodwill now its locked.
Jan 22, 2016 | Verizon Ellipsis 7 Tablet for Wireless
How do I get my LG 7.0 tablet out of safe mode?
Get an Android Tablet out of safe mode
    1.Restart your device by holding the power button, then tap Power off.
    2.Tap Ok to confirm.
    3.Power the device on. Your tablet should now be out of safe mode. If the device is still in safe mode use one of the following methods.
      ·Uninstall the last application you installed:
      1.From the Apps menu, tap on Settings.
      2.Tap on the app and then tap on uninstall.
      3.Restart your device.
      ·Perform a factory data reset:
      1.From the Apps menu, tap on settings, and then tap backup and reset.
      2.Tap on factory data reset, and then tap reset tablet
      3.Tap erase everything to format your tablet back to factory default configuration.
Nov 21, 2015 | LG 8GB G Pad 7.0" Wi-Fi Tablet Black
How do i get my tablet out of safemode?
Restart your device by holding the power button, then tap Power off.Tap Ok to confirm.Power the device on. Your tablet should now be out of safe mode.If the device is still in safe mode use one of the following methods.
Uninstall the last application you installed: From the Apps menu, tap on Settings.Tap on the app and then tap on Uninstall.Restart your device. (Next step is if the above last uninstalled app/s did not work.) Perform a factory data reset:From the Apps menu, tap on Settings, and then tap Backup & reset.Tap on Factory Data Reset, and then tap Reset Tablet.Tap Erase Everything to format your tablet back to factory default configuration.
Usually this happens if an uncompatible app or mod was installed. System boot up file misconfigured or uncompatible with recent install, but get rid of that recent install and all should work. I hope this helps, good luck.
Sep 19, 2015 | Computers & Internet
I have my grandaughter tesoar tablet is frozen on the white screen with tesoar across the screen i need help
Hi, you need to do a factory reset!
First, turn your tablet off. Then, power the tablet back up by holding down the volume (either + or - ) and power buttons simultaneously. Continue holding the volume button until the screen says "Booting tablet in recovery mode." This will give you a picture of an Android. Tap the android, and you will be given a screen with several options. Move between the options with the volume + and -, and select with the power button. Go to the option for Factory Data Reset and select it. Scroll down to `the Yes, and then the tablet will erase its memory back to factory settings. Once it has completed, select Reboot Tablet Normally.
let me know how you get on!
Oct 18, 2014 | Tablets & eReaders
How can reset my gzone to factory settings
  1. From a home screen, tap the Apps tab apps_tab.gif (located at the bottom).
  2. Tap Settings.
  3. Tap Privacy.
    linote.gif To determine if an issue is caused by a third-party app, uncheck Automatic Restore.
  4. From the Personal data section, tap Factory data reset.
  5. If presented, tap OK.
  6. Tap Reset phone.
    linote.gif If presented, enter the current passcode or draw the unlock pattern.
  7. Tap Erase everything.
    linote.gif Allow several minutes for the factory data reset and reboot processes to complete.
    linote.gif To setup the device after completing the factory data reset, refer to Initial Activation and Setup.
Jul 06, 2014 | Casio Cell Phones
Unlock pattern
tested 100% working How to Factory Reset Your Android Phone or Tablet When It Won't Boot android-recovery-mode.jpg
Safe mode can help you troubleshoot your Android, but sometimes you'll need to wipe everything and restore your device to its factory state. You can even perform a factory reset when your Android phone or tablet won't boot normally.
Ensure you have any important data backed up before doing a reset. This includes your Google Authenticator credentials, which will be lost during the reset. Disable two-factor authentication on your accounts first or you'll experience some trouble afterwards.
If You Can't Boot
If safe mode doesn't help fix your device, you can perform a hard reset by booting into a special recovery mode. First, ensure your device is fully shut down.
Press and hold the correct keys to boot the device into recovery mode. This will vary from device to device. Here are some examples:
  • Nexus 7: Volume Up + Volume Down + Power
  • Samsung Galaxy S3: Volume Up + Home + Power
  • Motorola Droid X: Home + Power
  • Devices With Camera Buttons: Volume Up + Camera
Similar devices will likely use similar key combinations. For example, the Nexus 4 also uses Volume Up + Volume Down + Power.
If your device isn't on this list and none of the above methods work, do a Google search for the name of your device and "recovery mode" - or look in the device's manual or support pages.
Release the buttons when the device powered on. You'll see an image of an Android lying on its back with its chest open and its internals revealed.
Press the Volume Up and Volume Down keys to scroll through the options until you seeRecovery mode on the screen.
Press the Power button to restart into recovery mode. You'll soon see an Android with a red triangle.
Hold down the Power button and tap Volume Up. You'll see the Android system recovery menu appear at the top of your screen.
Select wipe data / factory reset with the volume keys and tap the Power button to activate it.
Select Yes - erase all user data with the volume buttons and tap Power. Your device will be reset to its factory state and all your data will be erased.
If your device freezes at any point, hold down the Power button until it restarts.
If You Can Boot
You can reset your Android phone or tablet normally from its Settings screen. Tap the Backup & reset option on the latest versions of Android or tap Privacy if you're using Android 2.3.
Tap the Factory data reset option and to through the reset of the steps to confirm the factory reset.
If the factory reset process doesn't fix your problems - or doesn't work at all - it's likely that there's a problem with your device's hardware. If it's still under warranty, you should have it fixed or replaced.
(There's one exception to this: If you've been flashing custom ROMs and messing with your device's low-level software, it's possible that you could have overwritten the stock recovery software. In this case, it's possible that you have a software problem and not a hardware problem.)
goodluck
Apr 20, 2014 | Samsung Cell Phones
Reset rca tablet
You can perform a hard reset on your tablet 2 ways. The first is by going into Settings>backup and reset and choosing the Factory Data Reset option.
If you are stuck at the startup screen or a password/pattern screen and cannot boot into the system, you will need to use method 2, which is booting into recovery mode. Have the tablet powered off first and make sure you have more than 50% charge on the battery. Boot into recovery mode by pressing and holding the volume up and power buttons. At the RCA logo screen, let go of the volume up button and you should next see an android image. Press and hold the power button and tap the volume up button once more and you will be brought to the recovery mode menu. From here, you will need to use your volume up and down buttons to scroll and navigate to the wipe data/factory reset option and use the power button to confirm. When the process is done, go ahead and reboot and your tablet will be set to factory original settings.
Jan 12, 2014 | Tablets & eReaders
Cell Phones Logo
41 people viewed this question
Top Verizon Cell Phones Experts
honeybun1986
john h
Computer Repairing
Computer Repairing
Are you a Verizon Cell Phone Expert? Answer questions, earn points and help others
