My computer reads offline for some reason - Office Equipment & Supplies
HP monitor goes on then offline
Hello John,
You have asked Software Variations about why your monitor is going offline. John can you hear the computer hard drive spinning?
also what kind/make of compute are you using the monitor with?
if it is a dell look in the back for lights and write down the exact light configuration and what color the lights are.
with this information we will get you the reason your monitor is going offline.
thanx a bunch
Apr 24, 2014 | Office Equipment & Supplies
Epson printer offline
Hi Dear,
The Printer Offline reason is mention below read the properly and solve your problem.
  1. Check the power button of you Printer it should be On.
  2. Check the data cable it will plug properly.
  3. Go to the system and check the printer property and unchecked the "Use Printer Offline" option.
  4. Check the USB or Parallel cable properly connect with computer.
Thanks
Mar 27, 2012 | Office Equipment & Supplies
What's your problem? my computer says the pritner is offline. how do i turn it onlnie?
There could be several reasons for the printer to show offline in Printers folder.
Click on the link below and follow the steps to troubleshoot the issue.
HP Print Diagnostic Utility
Regards,
Suhail
Oct 18, 2011 | HP Deskjet F2210 InkJet Printer
How do i get my machine offline
try printers and faxes from start menu and find solution under preferences. If not, disconnect the printer from the computer. You must have a good reason for going offline!
Sep 09, 2011 | Okidata 591 Printer
Printer is offline and will not print. Restarting does not help.
When you double click the Printer and Faxes icon in the Control Panel you will see the printer that your computer is currently using. See.... if the printer image is clear it is online and ready to use, if its blurred then its in offline mode and cannot be use.
To correct offline printer.. some possible reasons is on the usb cable.. check if there is no open wire along the cable...Inserting the USB connector on the other usb slot of the cpu sometimes work just wait first until it is read.
If the printer is still blurred and offline after checking the usb connection, the 2nd thing to do is check the properties of the printer if it is set to offline mode. how? Double click your printer icon. It will display the print jobs window. Click on the Printer tab and uncheck on the "Use printer Offline". Cancel all pending print jobs, close the printer window and try again to print.
Aug 10, 2010 | Office Equipment & Supplies
I have a cannon inkjet mp560. when ever I try to print it says "printer is offline" or "printer is not responding. I've tried unplugging the usb cord and turned it off and restarted it, but it will not...
I have a Canon Pixma MX330 color printer. It gets used only occasionally, usually to print brochures and the like. I recently switched it to copy mode by pressing the "copy" button on the front; now it...
Aug 05, 2010 | Canon PIXMA MX330 Multifunction InkJet...
Local disk (D:) offline can you help
That means that the file manager is not reading your card for whatever reason. Firstly, the card may be missing. secondly the card connectors may be dirty with oily finger prints. Thirdly the card may be bad. Fourthly the card slot connections may be faulty. Check all these and if still the card is not read then show to a repairer.
Aug 12, 2009 | ASUS Computers & Internet
Printer status offline needs to be online
Do you mean it says "offline" under the printer icon in your PC's printer dialog box?
Right click it , then select "use printer online".
Please let me know
Apr 04, 2009 | Zebra 110Xi III Plus Thermal Printer
Nothing happens when i tried to print from my computer the status is offline what is wrong
same thing, woring one minute, next minute, offline. cords plugged in , no reason i have found but it happens all of the time
Sep 02, 2008 | HP DeskJet F380 All-In-One Printer
k24674
jasbo
jasbo
