Question about Troy Garden
Tines make loud noise when forward/reverse lever is engaged on Troy built horse tiller
  • 5 Answers
SOURCE: troy bilt horse pto clutch will not disengage
The problem is lack of lubrication in the pto coupling. Losen the two swing bolts carefuly,block the front under the motor. Separate the tine transmision from the housing and grease both sides with as much grease as you can work in. Work the lever as you do this. Should fix the problem.
Posted on Feb 14, 2009
  • 22 Answers
SOURCE: Troy Bilt Tiller tines do not engage
You likely have a clutch problem, never saw one that a simple adjustment would fix. I'd take off the tiller (there are two bolts that hold the tiller portion to the transmission, and check to make sure the clutch is sliding in and out. My hunch is either the lever is loose on the shaft or the allen-head little bolt that they use to shift the clutch has come out. Be sure to grease the clutch while you're in there.
This should be covered in your owners manual. Shame on them if they didn't mention this.
Posted on Jun 14, 2009
  • 81 Answers
SOURCE: The tines on my troy built Horse tiller do not grb
Since there is no grinding noise, if the problem is in the gear box it isn't too severe. There is a slight possibility that a tooth or two has been broken off one of the gears. But it sounds more like you have a worn drive belt. Most of the time when the tines don't grab or they slip it is because the drive belt have become worn in some way. If it is suppose to be a one-half inch wide belt it could have thinned to a three-eight inch allowing the belt to drop further into the pulley than needed, or it may be "sloppy", not tightening enough to operate the tines if it has stretched. The right belt is very important and is an easy fix. I hope this helps.
Posted on Jun 18, 2009
harlan301
  • 205 Answers
SOURCE: Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Posted on Oct 13, 2009
  • 5 Answers
SOURCE: Troy built horse loses power
sounds like you are trying to till too deep raise tines up a little with the depth gauge then till the same spot again and see if that helps
Posted on Mar 14, 2011
Tines wont engage on my troy built pony. How can i fix it?
The lever for the tines moves easily? Is there an adjustment on the linkage that may need tightening?
May 11, 2012 | Troy-Bilt Pony Garden Tiller
Troy built horse loses power when I engage tines into the dirt. What do I need to service?
Mar 10, 2011 | Troy-Bilt 21AE682L766 Big Red 10 HP...
Tiller will not engage tines
Is this a two speed or a 4 speed ... it is a MTD built Troy or a Troy built Troy or do you know?
There were two versions of Horse built in Troy, New York bu Gardenway ... the two speed and the 4 speed. The two speed used two belts the same size while the 4 speed used one belt on different sized pulleys. There was also a variation that used a slip gear ... this model was built to accomodate other accesories ... log splitter and generator.
If yours is a Troy Built from Garden Way, I can help you. If this one is from MTD, I'm not so sure. Can you ID your machine for me please?
Jun 13, 2010 | Garden
Troy bult junior has new tines , runs to fast...
MAKE TWO PASSES SET THE DEPTH GUIDE SO IT JUST BREAKS THE GROUND, DON'T TRY TO DO IT ALL AT ONCE. SOON AS THE GROUND IS LOOSE IT WILL DIG MUCH BETTER.. IT SHOULD HAVE A FORWARD AND REVERSE FOR THE TINES, GEARS FOR FORWARD REVERSE DRIVE
May 19, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
The tines on my troy built Horse tiller do not grb when tilling. Are the gears in the drive shaft the problem? How do you fix this?
Jun 17, 2009 | Troy Bilt Tiller/Edger 26cc, Model No....
Grinding when Engaing PTO for the tiller-Troy Built Horse 8hp
It's likely that your clutch needs adjustment. To adjust, you just need to loosen the two screws on the plate and slide it a bit so the clutch better engages the rear dog clutch. Have you ever taken the tiller portion off the transmission to grease the clutch? If not, before adjusting it you might want to do that. It could be that the clutch isn't sliding back far enough to engage the rear end and a little grease is all it needs. This service requirement is explained in the owners manual for the tiller. One last point, the tiller must be in neutral when engaging the pto clutch. From your note, it sounded like you were engaging the clutch with the forward/reverse lever in the forward position. The lever must be in neutral when engaging the pto clutch.
Jun 14, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
May 24, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Belts slippin on troy bilt horse
Have you adjusted the locking cam for forward. This cam is held in place with one bolt. The further you move it down the tighter it will make the belt
Apr 02, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy bilt horse pto clutch will not disengage
Jan 17, 2009 | Troy-Bilt Pony Garden Tiller
Garden Logo
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
