Question about JBL Audio Players & Recorders
I had 2 Jbl TLX speakers which were destroyed when a tree fell on my shed. I need to get a valuation for replacement for insurance purposes. What would be today's replacement and cost?
  • JBL Master
  • 16,199 Answers
You leave out the most important bit which is the model number as they are all called TLX! Depends if they are floor standing or bookshelf? Take a look at the link and read the reviews. They tell the price.
Jbl TLX speakers Google Search
Posted on May 10, 2017
While parked a tree branch fell on the truck now it won't start it ran fine before the tree branch fell
A Tree Fell on Your Car: Now What?-Allstate
https://www.allstate.com/tools-and.../car.../tree-fell-on-car.aspx
Allstate... parking lot to avoid door dings," so you can imagine his dismay when a tree ...Gregg did his best to salvage his truck after the storm passed, but the ... If you're the owner of both the fallen tree and the vehicle, your homeowners insurance policy likelywon't ... What steps should you consider when a tree falls on your car?
Will landlord's home insurance pay for tree that fell on my car?
www.insure.com > Ask the Home Insurance Expert
Jun 4, 2014 - If a storm causes a tree at your rental property to fall on your car, don't expect ... Will landlord's home insurance pay for tree that fell on my car during a storm? ... The landlord, thus, won't be found liable by the insurance company and ...damaged if you also knew of the tree's fragile condition and parked by it.
Responsibility for damage caused by falling trees is a ...
www.post-gazette.com/...falling-trees.../2012112...
Pittsburgh Post?GazetteNov 23, 2012 - Pittsburgh Then & Now ... The philosophers wanted to know what happens when a tree falls in a forest. ... and knock branches onto your home, causing serious damage." Coverage ... But if you do the same to your own property, your own auto policy probably won't cover damages to your trees and shrubs.
DOT hits tree, tree branch damages legally parked car ...
Jan 25, 2016 | Cars & Trucks
What is the use of felling axes?
The felling axe purpose is to cut across the grain of wood as in the felling of the trees. There are different weights, shapes, handle types and cutting geometries to match the characteristics of the material being cut.
Feb 03, 2013 | Garden
I have a JBL TLX PS10 sub woofer, and it keeps blowing fuses almost immediately.What do you think the most likely problem is? also, where can I download a free service manual for this item? I have removed...
Edwards Electronics not only repairs the following amps they also do upgrades to them so they do not burn up again: TSS1100 TSS1200 PS10 PS12 E250P PS210 and a few others - Look on Google for them or Ebay. Thanks.
Aug 17, 2011 | JBL TLX PS10 Speaker
Hi can you tell me that impedence on JBL TLx4 speakers- i need to know if they are compatible with my denon RCD M37 dab player thanks
hi,
Is it JBL TLX 420 then its impedance is 4OHMS. You cant connect these speakers to denon rcd m 37, because its output impedence is 6 to 16 ohms.
ok
Jul 04, 2011 | JBL PSW-D110 Speaker
I have an older JBL TLX PS10 sub woofer but hardly used. I get a green light when plugged in. However, the speak makes a loud continuous noise when I plug in the Y connector to the low level input. It...
Just touch your fingertip to the input connector on the sub -- similar noise? That would be its amp picking up the hum of the room through your antenna-like body. IF that is the same noise, you need to make sure your input cable is shielded and connected at both ends BEFORE applying power to the electronics at either end.
Be mindful of electronic noise sources such as track lighting, UV lights, motors, TV's, etc, and route the signal and power cables well away from them.
Try reversing the orientation of the AC plug at the sub and see if that helps out.
Feb 10, 2011 | JBL TLX PS10 Speaker
I been having a problem with my JBL TLX CSS-SUB1, I don't have the manual. Connecting speaker wires from the JBL TLX CSS-SUB1 to the a Digital Audio/Video Control Center ( it's a reciever) I confused,...
The connection on the receiver would be the sub woofer out. Not a sub woofer out LFE, a sub woofer out with speaker wire connection. From there you plug it in to the top section of the available terminals on the sub you are referring to (speaker level input). One in positive and the other in negative matching what you did on the receiver with correct ends. The speaker connections underneath the top connections is for additional speakers like surrounds to be able to be connected directly to the sub woofer speaker level out for sound. This of course would be for an older receiver connection. I do not think it is possible to convert this connection to an LFE and have it work properly. If the receiver does not have sub woofer speaker connection and only a RCA out then you can try to connect both rear speaker connections from the receiver to the speaker level inputs on the sub and then connect your rear speakers to the speaker level output on the sub to power them. This is an active sub woofer but for some reason they made it connect as if it was passive. I am not sure if this sub is designed for really low frequencies required for movie or if it is better for music.
Nov 01, 2010 | Audio Players & Recorders
JBL TLX PS10 Subwoofer - Does not work
If you have checked the fuses which it sounds like you have, your amp may be out. Take that RCA and plug it into the other speaker. If thar she blows, treat as warranty and call the factory. If this is helpful, please post as such.
Jan 17, 2009 | JBL TLX PS10 Speaker
24 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
