Question about Exercise & Fitness
Hi my nordi track pro2550 wont start it lights up but wont start . after a few days it worked fine and now wont start again. what can i do to fix it?
  • 298 Answers
SOURCE: my car will unlock and lock fine but but it wont start.
Does it click or chatter when you turn the key?
Dash lights and headlights and horn take a lot less power (Amps) than starting. As an example from cold, your starter moter uses 180-400AMPS(!) when starting (or trying to start) the car.
You have an apparent GROUND and POSITIVE 12v off the battery, but when the starter kicks in it drawas so much power that if there is a loose connection at either terminal of the battery, it will arc and vaporize the metal at that point and all you will get is a click. Take off the battery connectors and clean the posts and insides of the connectors with sandpaper, then starting with the POS (Red +) side, push them on firmly, loosen the clamp bolts tap them several times around in a circle with a small hammer, block of wood or screwdriver handle so they seat all the way down, then tighten the bolts. If it wont go, remove the bolt, insert a flat-blade screwdriver in the **** and twist the screwdriver to expand a bit then tap some more. NOT HARD... just alot of little taps) Put the bolt back in and do the NEG (Black, -) the same way.
NOW it will start!
Posted on Mar 26, 2009
Robert Braun
  • 77 Answers
SOURCE: Does the Nordi Track Commercial zs Treadmill have a 3.0 CHP
It is continuous. Some manufacturers used to say just "horsepower," when "continuous" horsepower was really a better measure. Consumers picked up on this and started asking your question. Now the horsepower quoted by almost all brands, including NordicTrack, os continuous. However, they got lots of consumers asking "What does 'continuous' mean? so now they just say "horsepower," even though it is "continuous" horsepower! For a full explanation of what this means, see treadmill answers.
Posted on May 09, 2010
Testimonial: "That is the best answer I got. What a relief. I just bought the this machine today. Thanks guys. "
  • 1608 Answers
SOURCE: abs light stays on and track light on message
First of all if the ABS and traction control lights are on then you have to get the codes to find out what could be causing the problem.Could be speed sensor,wiring,or module.As far as the speedo it is more than likely the instrument cluster.It will have to be replaced if it is sticking.If you can find a place that rebuilds them then do that.Hope this helps.Good luck.
Posted on Aug 18, 2010
SOURCE: have 1990 chevy cheyenne 350 tbi wont start has
the ignition mogule is prpbably bad .have it checked .
Posted on Nov 25, 2010
  • 6 Answers
SOURCE: Instrument cluster in my 04 silverado v6 c1500
ECM ground is one of a few causes for this condition. Check ground wire passenger side rear of block. Remove bolt and inspect condition of wire. Most times will need to replace 8in of wire
Posted on Jan 01, 2011
I got a bush 24inch led smart tv few days ago and it was fine now the red standby light isnt on at all or wont come on at all how do I fix it or get it to work again
Hi Alex, Red stand by light is not coming on means the power has gone dead. Check the fuse if you can. Replace it with the same rating one. If the set starts working, enjoy watching and if the fuse blows again, consult the TV Tech. Good Luck.
But why all this trouble? Your TV must be in service guarentee. Call the company guys to fix it.
Aug 03, 2015 | Bush Televison & Video
Nissan patrol 55 plate, wont start
maybe but i dont think so, lost key coding woiuld allow to start fine and smooth and then shut down after a few sec. the best way to track this problem would be with a scan tool.
not sure what year or engine is in this nissan 55 plate but scanning for codes would be the best way to start
Dec 01, 2013 | Nissan Pathfinder Cars & Trucks
Nordic track nctl 1199 wont power up
see the video and fix it. God bless you
Nov 26, 2012 | Exercise & Fitness
My sharp cd-ba200 will barley play cds
Put the player On for few hours or overnight. Now remove the panel and get access to the optical head unit, use a clean ear bud to polish the optical head. If not the optical head is weak and must be replaced.
Mar 14, 2012 | Sharp CD-BA200 CD Shelf System
After pressing the 4 wheel drive button it just blinks a few times and stops then 2wheel drive lights comes on. 4wheel drive worked fine the day b 4
these damn things do this all the time, my 03 ? you cant count on it to work any day of the week ! you just get lucky and it works. I get all lights flashing, i get the nuetral light on yet it is in 2 hi. I'm tired of all the codes and replacing parts, 700.00 dollars later and still the same. I just drive it and it fixes itself in a day, maybe next time i start truck. It worked the best when i sealed all the electrical plugs in moisture proof wrapping,but a few months later and its a guess game again so i just drive it !
Jan 23, 2011 | 2000 Chevrolet Silverado 1500
Instrument cluster in my 04 silverado v6 c1500 stopped working then after a few days, started working then after another few days stopped again. how do i fix without spending.... Pannel lights are fine...
Dec 26, 2010 | 2004 Chevrolet Silverado 2500HD
May 08, 2010 | Nordic Track NordicTrack Treadmill, A2550
Screen blanks out after a few seconds. If I turn
Fixya:
My IE 8 loads the correct odds on the tote-board and then suddenly the odds go blank.
I have to click down to another track and then click back up to get the odds working again.
The issue happens again at another track that I click on. Forces me to go through the same proccess over again.
This bug related issue is very aggravating so if there is a fix I would appreciate it.
oppusone
My IE 8 loads the correct odds on the tote-board and then suddenlly the odds go blank.
oppusone
oppusone
oppusone
Aug 31, 2009 | AOC LM720 17" Flat Panel LCD Monitor
Audi tt 180 quattro car wont start. EPC and E-M system lights on
I would suggest you check oil levels etc. Generally these cars suffer from the air mass meter / air sensor problems aswell as coil problems too. Did you ever get a solution to the problem?
Mar 18, 2009 | 2002 Audi TT
Wont power on
hi , please change the signal cable which is connected from CPU to monitor. please rate this comment.
Sep 15, 2007 | Mag Innovision LT765b 17" Flat Panel LCD...
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
