Question about Measuring Tools & Sensors
Smart gear weather station model #STG-6083-KB The outside temperature will not display. New batteries in both units. The inside temp and clock display fine
When i Put in batteries the red light on the front of the unit stays lit for about 4-5 seconds then goes out
4 Suggested Answers
SOURCE: Outside unit not registering temp and humidity to base unit
Uniden EWCI936
To get the outside temperature working again, open the outdoor sensor box carefully loosening the one screw with a screwdriver, insert 3 brand new AA batteries, check phone for outside temperature. If not showing on the phone display, try changing the 'channel' setting, just above the batteries. Be careful not to break the tiny switch. Gently use a smaller flathead screwdriver, if needed. There are 3 settings. Mine worked fine on the first setting. If it is showing on the phone set screens, then, carefully screw the lid back on to the sensor box, and re-insert into the sensor wall holder. I keep mine in a plastic bag on a shelf outside, away from sun, so I can get a true reading day or night. It is always a bit warmer in the sunlight than the true outdoor air temperature. Enjoy
Posted on Nov 14, 2010
SOURCE: Sharp Weather Station Model SPC344 The outside
After inserting the batteries, DO NOT set the time until the OUTSIDE temperature registers. That's the trick.
Posted on Nov 06, 2011
  • 43947 Answers
SOURCE: My Smart Gear STG-6007-BB weather station won't pick up the outdoor temperature from the remote sensor. I changed the batteries and reset the unit, but it still doesn't work. Any suggestions?
  • Remove all batteries
  • Install batteries in remote sensor. Allow time for it to begin sending temperature information
  • Install batteries in indoor unit. You should see temperature displayed
Cold weather can cause loss of temperature information
Posted on Dec 17, 2016
My Smart Gear STG-5939-KB, Weather Station does not indicate the correct day. Instructions say it will adjust to the date. The date is 5/4 but the dat says TUE. Any ideas?
Your Smart Gear Weather Station may be defective. I have an atomic lock that indicate DST all year round but changes time correctly. One other thought: your weather station may be set for the wrong year.
May 04, 2018 | Measuring Tools & Sensors
The outside temp won't show up on my new weather station
  • Install batteries in outside unit and wait for it to begin sending temperature signal to inside unit.
  • Install batteries in inside unit. You should see outside temperature displayed.
  • If this doesn't work, the outside unit may be defective.
Apr 04, 2018 | Measuring Tools & Sensors
How do I set the clock to 12 hr not 24 hour time on the Smart Gear 6083 indoor outdoor thermometer? I lost the directions. Thank you so much! It's driving me nuts!
Scroll through the menu to find 12/24 format, press and release the +/- button, then the c*\f* button will change the value and then hit the set button.
Jan 13, 2018 | Smart Computers & Internet
I have the Atomic Clock model W86111. I had to change the batteries on the outside device. The clock outside temp just flashes 63.5 all the time. How do I make it sync to the device outside?
Remove all batteries from outdoor sensor and weather station.
Press one of the buttons on the weather station at least 20 times to clear all memory.
Verify that the weather station is blank before proceeding (there may be lines painted on
the screen that will show when power is removed).
Leave both units without power for 15 minutes (very important).
Insert fresh batteries into the clock.
Insert fresh batteries into the outdoor sensor.
Press the TX button on the outdoor sensor to transmit RF signal.
Keep the outdoor sensor 5-10 feet from the forecast station.
When RF connection is established, the temperature will appear on the station. Allow the
outdoor sensor and weather station to sit together for 15 minutes to establish a strong
connection.
Oct 14, 2017 | Home
Dec 17, 2016 | Measuring Tools & Sensors
OUTSIDE TEMP SENDING UNIT GOT WET AND WILL NOT CONNECT TO CLOCK. HOW CAN I FIX OR HOW CAN I REPLACE?
[PDF]WS-8117 ATOMIC CLOCK WITH OUTDOOR WIRELESS ...
https://www.lacrossetechnology.com/products/.../misc/8117-manual.pdf
NOTE: Do not set the clock until the outdoor temperature is displayed. .... The unit will still try and receive the signal every day despite it being manually set. ..... sunlight, extreme cold and wet/moist conditions as these will lead to rapid changes ... Beforesending the atomic clock in for repairs, contact La Crosse Technology.
La Crosse Technology Top Solutions
https://www.lacrossetechnology.com/support/top_solutions.php
A: Complete a restart for display with the temperature/humidity sensor: ... to rest for 15 minutes can result in failure to connect with the outdoor sensor or missing ... Products set outside of these time zones will not search for a WWVB signal as it is ... locate the Clock or Weather Display near an outside wall and point the unit in ...
Common issues weather stations: Click Here
www.weather-station-products.co.uk/faqs/common-issues-weather-stations
Under £30 £30-£75 £75-£125 From £125 Birdhouses/Feeders Outdoor Clocks ... I'mnot getting any outdoor readings from my outdoor sensor, what do I do? This willcure 90% of all sensor connection problems, important you must ... is the airtemperature, to get this reading you need to place the unit away from direct sun.
Replacement Temperature Sensor ' AcuRite
www.acurite.com > All products
Dec 16, 2015 | Audio Players & Recorders
Outside temp
Remove all batteries. Reinstall batteries (or new ones) in the outside unit. Install batteries in the console. DO NOT TOUCH ANYTHING! Wait until the outside temperature displays on the console. Make any adjustments necessary.
Nov 05, 2013 | Davis Instruments Davis Vantage Vue...
Why is the outside temperature not displaying on the base?
After a battery replacement, the outside and inside units have to "talk" to each other before you can get a display. Also, the outside unit's batteries have to be replaced first. You should not press any buttons for 10 minutes until the two units have finished "talking"
Jan 24, 2013 | AcuRite Acu-Rite 00593W Wireless Weather...
I have this model and the outdoor temp sensor isnt working, and yes both modules have brand new batteries in them. what should i do to get the outdoor temp sensor to work.
My outside display stopped working, but the inside display still worked. I found that one of the two batteries in the inside unit was almost all the way dead. Once I replaced both batteries the outside display worked. I also checked the batteries in the outside unit. After all batteries were installed, I pushed the small button that is inside the battery compartment on the outdoor unit. It's now working perfect..
Oct 10, 2010 | Acu-Rite Acurite Wireless Weather...
Measuring Tools & Sensors Logo
666 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
