Question about Maytag Washing Machines
My detergent drawer is jammed and off the track in my Maytag front loader washer
  • 64 Answers
SOURCE: leaking detergent
Sounds like the back of the soap drawer or inlet hose is partially blocked. Check whether junior has posted a toy car in the drawer
Posted on Oct 26, 2007
SOURCE: Can you use Oxyclean along with detergent in front loaders?
I use 2 Tablespoons of Liquid Detergent and a 1/2 to 3/4 scoop of Oxyclean and I have had good results in my Front Loader. Clothes come out very clean and there is no residue on the inside of my washer.
Posted on Oct 07, 2008
  • 43 Answers
SOURCE: Leaking Water
try pouring boiling water down soap draw possible blockage due to cheap wash powder take off lid and massage down pipe then put on wash with no clothing
Posted on Nov 10, 2008
SOURCE: front loader LG washer drawer for detergent is stuck won't open
Remove the top of the washer by removing the 2 retaining screws (phillips head) from the back of the unit & sliding the washer top back about 2" & pulling up. You will see a white detergent dispenser box with several hoses coming off the back in the left front of the unit (this box contains the detergent drawer). The lid to this box is held on by 8 pressure snap clips. You only need to release the 4 snap clips (3 large, 1 small at the rear) on the right side of the box (nearest the washer drum). Pull up on the right side of the lid while pulling out on the detergent drawer. It should come out normally. Do not reassemble until you read below, then reverse the steps to put the washer back together.
The problem will be the "softener" lid (blue). It will not be sitting down in the drawer assembly & will catch on the lid of the white detergent dispenser box. Simply remove the blue lid to avoid future jambs. It only serves to identify the fabric softener recepticle & it keeps fabric softener from splashing around when water enters the system. You may need to remove the entire detergent drawer periodically to clean (push down on the blue thumb indent inside the drawer to release it from the housing).
Hope this keeps you from drilling through the lid & ruining a $23 part, like I did.
Posted on Jun 16, 2009
  • 9 Answers
SOURCE: which compartment does my detergent/fabric softener go in?
You can get all of Whirlpools user guides here: Generally the one one the left - is for pre-wash (if clothes really soiled), the middle one is for powder (if you use it) and the last one is for softener or bleach.
I just use liquitabs - which go directly into the drum, and fabric softender.
The soap drawer won't open. Never had this issue before.
Is the machine a front loader? Is the drawer on the front of the machine? What is the Brand? I have a Samsung front loader and my detergent/bleach & softner drawer pulls out from the front. There are two drawer release locks on the drawer track (one on each side) if the drawer will give you any wiggle try pulling or pushing up gently. This may unlock the track. It sounds like the drawer was pushed in too hard... hope this helps
Oct 13, 2014 | Asko W660
Kenmore HE 4t Elite Front Loader Washing Machine
Inside the dispenser drawer, at the bottom there is a tab that you can push down to remove the dispenser drawer. Remove the drawer and check if the dispenser holes are clogged, this is a common cause.
Mar 22, 2008 | Kenmore Elite 45986 Front Load Washer
Washer detergent drawer will not open...drawer lock or detergent cup?
Something has jammed the drawer closed. You will need to access the top of the dispenser.
Remove the 2 screws holding the top lid in back. Slide the top lid rearward and remove.
Pry open the top of the dispenser top and using a small screwdriver, unsnap the lid snaps.
This will release the drawer and you can clean out any debris that caused it to jam up.
Good luck.
Jul 08, 2011 | LG WM-2277HW Front Load Washer
Water is pouring out of the detergent dispensing drawer from my 1 year old Samsung clothes washer model WF328AAW. When I opened the drawer, it was full of water. Something must be plugged. Is there...
Pull the drawer out you will find detergent has built up in side the dispenser probably from from way too much detergent, modern front loaders work best with a small amount of detergent and liquid detergent normally will wash better.
Apr 17, 2010 | Samsung WF203ANW Front Load Washer
LG Front Loading washer detergent drawer is jammed and will not open
you're in a bad spot. you will need to remove top metal panel of washer; and carefully separate the drawer housing a little and wiggle the drawer out. one of the compartments in the drawer popped up and jammed the drawer.
Feb 15, 2010 | LG WM-2277HW Front Load Washer
Water pouring from detergent, bleach, etc.. dispencer. Help!
This is joyce
He is right the Jets are probl stoped up with mold,
you need to take drawer out look to top of machine where water comes into drawer to dispense to your detergetnt, and see if their is mold, if so take squirt bottel full of bleach and squirt it up on the mold and let sit a while and then take tooth brush and scrub off as good as possible, run one cup bleach in machine with out any clothes . on hot cycle. do this 2 times see if this helps .
let me know. it can only help cant hurt.
willl make machine smell better, and never shut door to front loader completly shut, it needs air to dry or else it will mold.
Feb 11, 2009 | Maytag MAH8700A Front Load Washer
Clothes smell musty like wet towels after washed and dried.
check your detergent you are using, it should be a HE detegrent for High Efficency machines, too much regular detergent will suds up and nver be removed from clothing causing such a smell.a quick test to see if your using too much detergent, grab a sock form oyour drawer(clean one) place it in a glass of water and swish it up and dowen a few times, if soapy bubble wateris present then youre over soaping!
Jan 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
Detergent drawer will not open
Here's a possible solution: Remove the two screws on the bottom side of the plastic clips on the back of the washer (leaving the clips attached to the washer's top), then use the palms of your hands to sharply push the top back about an inch and a half and lift the top off the machine. Now, if you can see enough through the translucent plastic to tell where the hang up is, you can drill a small hole in the top of it to allow you to push that part down so the drawer will open. Then, use foil duct tape to seal the hole.
Jan 12, 2009 | LG WM-2277HW Front Load Washer
Water leak from detergent drawer
Remove the control panel. Inside you will find a service tech sheet that will identify the error code.
There may be an obstruction in the water valve inlet flume forcing the water to travel in the wrong direction.
Jan 05, 2008 | Maytag Neptune MAH7500WH Front Load Washer
Water leaking out front of maytag washer
Remove the top cover of the machine. Check to see if the three tubes going into the dispenser drawer hv not come loose. Tighten well.
Sep 11, 2007 | Whirlpool WTW6400SW Cabrio Washer
Open Questions:
Washing Machines Logo
42 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
