Question about Cell Phones
Phone has been saying Alta syncing for 2 days. I have the app and I have contact with my phone but it still does not show steps on my phone.
Cpyles07
  • 56 Answers
SOURCE: Motorola H700 wont sync with my Palm Treo phone?
Did the headset become unpaired with he phone? If so make sure the boom is closed and Hold down the button on the side until it starts to blink then run the wizard
Posted on Dec 06, 2007
  • 47 Answers
SOURCE: change display of contacts to first name, last name in outlook 2003
In most phones, there is an 'options' or 'preferences' in the address book that allows you to sort by first name, last name, etc.
As far as Outlook goes, when you are in the contacts tab, there is a link on the left that says "customize current view". Click on this and you can select fields to pick what fields you want displayed or select sort to pick how they are displayed.
Posted on May 11, 2008
SOURCE: LG kf510 cell phone won't sync to PC
I had the same problem.
I had thought PC was lost update the driver and I found the driver in following link:
http://uk.lgmobile.com/web/web.product.manualSoftwareRF.laf
After updating this driver, the software worked good.
Posted on Mar 06, 2009
erincinci
  • 148 Answers
SOURCE: Unable to sync contacts from outlook to htc diamond
Hi. In the sync options, there should be a couple of different options such as selecting either the phone or the outlook for the master of the contacts. So if you can change the option to copy contacts from outlook to phone (should be reverse in order to continously backup phone data) I think that tick will be seen when you got all your contacts to your phone. Hope this helps.
Posted on May 22, 2009
anandg27
  • 1272 Answers
SOURCE: phone memory
As it shows less internal memory, it seems that you have transfered some data like mp3, video clips through bluetooth to this phone and it was saved in the recieved folder which autmatically saves in phone memory. Try saving the data to memory card and you will get the phone memory free.
Posted on Jun 23, 2009
My fitbit Alta lost it's charge and now the time and date are wrong. I also just got a new phone and don't remember how to sync it
You must reset it. Read the instruction manual
and proceed with the Steps for Sync.
Blessing
cuadra2016@yandex.com
cell+WhatsApp:+50588611441
Oct 26, 2017 | Exercise & Fitness
Tip
Contact Numbers How Facebook Mobile Phone Sync
<p>If you have an iPhone or Android phone, you can sync your Facebook contacts to your phone. Otherwise, if another mobile phone, the synchronization feature of Facebook contacts may not be available. Android and iPhone smartphone users have it easy. With a few taps, you can configure the synchronization feature; the Facebook application handles the import and exports your contacts from that point forward. <br /> <p><br /> <p>Android <br /> <p>1. Put on your Android phone, and go to the home screen. <br /> <p><br /> <p>2. Touch the "Facebook" icon and press the "Menu" button on your phone. Touch the "Settings" from the pop-up. <br /> <p><br /> <p>3. Scroll down to the bottom, and tap the "Sync Contacts" option. <br /> <p><br /> <p>4. Choose what to synchronize. Your options include "Sync All" or "Sync existing contacts." The last option is just to sync contacts from Facebook with people aligned with your "Contacts" app exists. If the person is not there, it will not sync. I want all your Facebook contacts to your phone to get, then you choose "Sync All". <br /> <p><br /> <p>5. Touch the "OK". Facebook will start regardless sync contacts in the background when the application is running or not. Every time your contacts are updated, it will also synchronize the data. <br /> <p><br /> <p>iPhone <br /> <p>1. Turning your smartphone iPhone, and go to the home screen. <br /> <p><br /> <p>2. Touch the "Facebook" icon to start the app, and then the "Friends" icon in the app yourself. <br /> <p><br /> <p>3. Tap the arrow at the top right and select "Sync Contacts". <br /> <p><br /> <p>4. Move the slider to "Synchronize" to "ON" position. <br /> <p><br /> <p>5. Tap the "Sync Contacts" button after reading the disclosure law. The synchronization process should begin immediately, as well as your Facebook friends and downloads their photos to your profile "Contacts" app. <br />
on Aug 18, 2011 | Facebook Social Network
How do I reset the time on my fitbit alta
Theoretically the Fitbit should keep the time updated though syncing, but there are some things that throw it off. I would try these steps in this order. Check after each step to see if you have the correct time before doing the next step.
1. Re-sync your Alta to your phone/computer
2. Check your settings on your dashboard to make sure you have the correct time zone selected.
3a. If you sync to a phone make sure you do not need to update the app then try disconnecting and reconnecting the Fitbit (in your Bluetooth settings).
3b. If you are syncing to a computer, then try re-syncing your Fitbit. you might need uninstall/reinstall your software and make sure you are running the most recent version.
4. Try removing the Alta in the Fitbit app (should be under device settings) and then reconnecting it.
Hopefully one of those steps will get you on the right time, but if not, try resetting your Alta by doing the following:
  1. Plug in your Alta in a USB (computer, or adapter) as you normally would to charge it. It should begin charging.
  2. Press the button on your charging cable three times within eight seconds, briefly pausing between presses. (The button is on the end of the charging cable).
  3. Eight seconds after the first button press, you'll see the Fitbit logo on the screen. This means Alta is restarting.
  4. After you see the logo you can unplug your tracker from the charging cable.
Oct 20, 2017 | Exercise & Fitness
How do I reset the time on my Alta fitbit?
Theoretically the Fitbit should keep the time updated though syncing. I would try these steps in this order.
1. Re-sync your Fitbit to your phone/computer
4. Try removing the device in the Fitbit app (should be under device settings) and then reconnecting it.
Hopefully one of those things will get you on the correct time :)
My Fitbit Alta is showing incorrect time. How can that be changed?
Oct 12, 2017 | Exercise & Fitness
How do I set up and edit my Contacts on my new Apple iphone .
If you have a Mac, you can import certain formats from previous address books or, if you already use Contacts, simply sync it on iCloud.
On the phone itself, you can open the Contacts app or the Contacts button in the Phone app, and add each address, one-by-one, by touching the + icon in the upper right of the screen and completing the blank card. Once you touch "done", you can go on to the next.
Feb 17, 2015 | Apple iPhone 5c
How do I transfer contacts from my Samsung to an iphone 4s
It is easy to transfer contacts from Samsung to iPhone using a third-party Phone Data Transfer. In the video below, you will find a reliable tool that helps you make the transfer easily.
Oct 11, 2014 | Apple iPhone 4S
After dialing a number there is a delay of about 15 seconds before the call goes through
If you search online for this issue you will find many people telling you to root your phone, to delete the cache, etc. In my case I solved it by synchronizing all contacts again. Do you use your google account to sync them? If you do, then follow these steps below:
Try this:
0- Make a backup of all your contacts. This is only for safety, but its HIGHLY recommended.
1- Download any app from google play to delete all contacts. I used Contact Remover
2- Go to Accounts and Sync
3- Tap on your google account so you see all that your are synchronizing.
4- tap on the menu button and tap on Remove Account option.
5- Open the Contact Remover app and delete all contacts from the phone
6- Add back your google account and wait for it to sync all your contacts again
Dec 02, 2013 | Lands Phones
My nokia 5800 screen is broken and i want to copy my contacts to pc or another phone
You can copy the contacts to the PC easily....But to other phones it tough since you don't have the display.
Contacts to PC:
You should first have Nokia PC-suite for it.
If you don't have, download the PC-suite from here
http://europe.nokia.com/support/download-software/pc-suites/compatibility-and-download
Now connect the Phone with nokia PC-suite using the USB cable.
Since you don't have the display.Press OK (because internally the phone asks for the PC-suite connection)You need to say ok for it.
You can see two options in Nokia PC-suite.
1)Content copier:
2)Nokia PC sync:
using thes two methods you can copy the contacts now:
Content copier: Click on it and follow the screen step by step and save the contacts in PC
Nokia PC sync: Sync the contacts with outlook.Follow the screen accordingly and save the contacts in excel sheet.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Aug 01, 2010 | Cell Phones
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
