Question about Coffee Makers & Espresso Machines
I cannot get in to my Meijers perks - Coffee Makers & Espresso Machines
Why doesn't percolator run long enough
The thermostat in the base of the pot needs replaced...it is the little round thing pressed against the base of the pot. (You can see it after removing the base of the pot.) Pull off the leads and remove the screw holding it in and get a new one at goodmans.net ($10 including shipping...I just got one from them.)
You should take a picture before removing anything to make sure that you get the leads connected up correctly.
You have a main perk element and a keep warm element in the base of the pot. Plus a thermostat pressed against the bottom to sense temperature. Upon plugging in a cold pot, the thermostat reads zero ohms and applies 120 volts all to the perk element. Then when the thermostat senses a high enough temp, it opens and 120 volts is still applied to the perk heating element, but this time through the keep warm element (about 200 ohms or so). So now the perk element although hot is not hot enough to continue perking, just keeps your already perked coffee warm.
On a cold pot, you should read about 17 ohms looking into the pot...on a warm pot (with the thermostat opened up) you will read in the hundreds of ohms.
May 11, 2014 | Farberware FCP280 Stainless Steel...
It seems to be perking correctly but stops and then starts to perk again and again, this continued until I unplugged it, and also the light to indicate it was done never came on
Your pot needs a keep warm element. the main element works ( perks and perks) The thermostat works ( it turns the main element on and off.) The pot goes on and off because the water is getting cold The problem is the keep warm element. The reason, your pot perk's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix, it is the small looking white rope that runs around the bottom of the pot. Thanks and please ask if you need more help. Go to repairshack.com for the part. Ron
Sep 25, 2010 | Faberware 10-22 Cup Coffee Urn
I have a 55 cup Farberware Urn. Pot will perc coffee sometimes & sometimes not. Problem exists since new, & have replaced both thermos. Water gets very hot, but not as Coffee. Sounds like...
Hi. The spring slips onto the stem just under the coffee basket, it holds the stem with pressure so the perked coffee go up the stem onto the spreader, check repairshack.com Ron
Aug 15, 2010 | Faberware 12-55 Cup Coffee Urn
Coffee not hot right after finishing percolating. But gets hotter with time, about 5 minutes.
Hi. you need a thermostst. You perking is turning off to soon, 1 it perks, so the main heating is working, It perked, 2 the keep warm element works because it is keeping the water hot and is making the water hotter. You can get the thermostat from repairshop.com.
It is a very, very easy fit and cheap part. Good luck Ron
Mar 08, 2010 | Faberware Coffee Makers & Espresso...
Need a manual for west bend party perk, no. 58030
wont shut off automatically and the light wont go on
Dec 11, 2009 | West Bend 58030 Coffee Maker
When I get to level 15 it will let me upgrade my stats but won't let me pick a perk. The done choice is shadowed as if I'm not allowed to pick it so the game is basically over there.
To choose a perk, besides reaching a new level, you must also have certain amount of points in specific skills, for instance, for the Cyborg perk you must have level 14 and science 60% and Medicine 60%. Try reaching level 16 and you may see available perks for you to choose.
Jun 07, 2009 | Bethesda Softworks Fallout 3 for Xbox 360
VillaWare mini-perk 5120-o5 clear perc top
I have a miniperk 5120-05 that has stopped working.  I will let you have the whole thing if I can not get it fixed.
Jul 24, 2008 | VillaWare Mini-Perk 5120-05 Coffee Maker
Coffee Makers & Espresso Machines Logo
27 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
