Question about Garden
My gasoline leak is on a Simplicity lawn tractor. Regent Series, 14HP Hydro, #1692354
5 Suggested Answers
wireguy212
  • 1627 Answers
SOURCE: simplicty lawn tractor wiring dia
Have you priced a wireing harness they're not that expensive and fairly easy to change and may solve your problem quicker and cheeper in the long run.
Posted on Dec 07, 2009
  • 38 Answers
SOURCE: My simplicity Coronet Hydro 13 lawn tractor loses
The fluid in the transmission is a multigrade oil. sometimes you can change the oil by removing the transmission partially or entirely and change the oil to a heavier grade like 15W40 or 20W50, the transmission has a vent mechanism on top that is where the oil would be extracted or drained from and then refilled, the level at full cold is 1" to 1 1/4" below the bottom edge of the inside of the vent pipe or plug boss. some of these had a flat vent plug, some have a hose with the vent in the end attached at a nipple and still some older units had a reservoir like on the larger tractors. The reason your trans is slowing is due to wear in the hydraulic pump face.
Posted on Jun 04, 2010
  • 38 Answers
SOURCE: require a spindle for mastercraft riding lawnmower
This is a MTD brand mower, most mower shops stock these spindles, sometimes in a less expensive after-market version, take your local mower shop that model Number and they should be able to get your new spindle
Posted on Jul 04, 2010
  • 692 Answers
SOURCE: My MTD 14hp lawn tractor (38", 6 speed) shuts of
You have a short somewhere . A cut or stripped wire that , at the time of lowering your deck, touches the body. It's like turning off your key. Look around under your deck and you will find what I'm talking about. Fix wire and tie up to prevent future problems. GOOD LUCK.
Posted on Jun 17, 2011
Cant disengage tranny manualy
Hydrostatic Drive Problems?? - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
May 30, 2006 - I can't seem to get it disengaged to mave it manually. ..... I have aSimplicity 4212 Hydro drive that will not move under its own ... avisk8 - would think so - if the manual sez it's purpose is to let you disengage the tranny so that ...
Oct 14, 2015 | Simplicity 38in Regent 21hp Briggs
I have a b&s model 330000 engine which seems to leak a small amount of oil on the left side of the engine ans accumulates on the frame rail of the lawn tractor before dropping to the ground. i rec
My guess, without seeing the engine would be a seal or gasket is bad. Use Gunk brand degreaser to clean the engine. Start it up after that with the engine cover off and watch for leaks.
Jun 23, 2014 | Simplicity Regent 22 44 Riding Lawn Mower...
Simplicity Problems overheats after 1/2 hour of use
remove the tin cowling over the fins of the motor and clean out debris. Grass -mud -ect
Jun 12, 2013 | Simplicity Regent 22 44 Riding Lawn Mower...
I need a new deck for a 16LTH44 Simplicity
You could consider just getting a new shell and transfer the parts.
Oct 01, 2012 | Simplicity Regent 22hp Briggs & Stratton...
Simplicity lawn tractor problem
Check your fuel cap. If not venting properly, gas can be forced to places it shouldn't be. I also agree with carb over haul. If alot of gas in oil & alot of gas outta exhaust, lean towards carb issue.
Mar 19, 2012 | NRS Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
