Question about Samsung Washing Machines
Samsung washer model#wf306law/xaa error code tE - temperature sensor problem. what part do i need
    Top Expert:
  • 867 Answers
This could be either a sensor or a wiring issue, You need to check the wiring that runs from the sensor to the electronics, the wires can break inside the plastic sleeve and cause the electronics to think there is a sensor fault, It could be a sensor fault but i usually find a broken wire in these machines.
Posted on May 15, 2017
My Samsung refrigerator Model RFG297HDRS-XAA has 15-E code flashing.
Existing error codes for Samsung fridges run from 1 up to 13, in the majority of models as far as I could find out.
You might be having two error codes instead of one code
error 1 and Error 5.
Error 1 refers to 1. Ice Maker Sensor:
Ice Maker sensor connector missing, contact failure, electric wire cut, short-circuit, Ice Maker sensor failure.
Indicates an error when the temperature sensed by Ice Maker sensor is higher than 150 or lower than -58.
Error 5 refers to 5. Ice Maker Function Error:
Ice ejector and level failed three times or more.
Jul 12, 2017 | Samsung Refrigerators
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
How do you fix a EE Error code?
If the error is tE (instead of EE), then your Samsung washer has a problem with the temperature sensor. This is a thermistor on most of their models. If the machine is under warranty, contact Samsung for the repair. Otherwise, please add a comment with the full model number of the washer or dryer with the error. Assuming the part hasn't come loose (it's held by some clips), it needs to be replaced.
To check out the part, you need to unplug the appliance and get behind it. Then take off the back panel. The thermistor on the washer is mounted near the bottom of the back of the washer tub.
For Samsung dryers, the code could be Et. Then the EEPROM is faulty and again needs to be replaced.
I hope this helps.
Dec 15, 2014 | Samsung 4.2 Cu. Ft. FrontLoad Washer And...
Samsung washing machine wf306law xaa where is debris filter?
I have a
WF306LAW/XAA Samsung, and no idea where this filter is! Any help?
Nov 13, 2013 | Washing Machines
I'm getting error code tE on samsung silvercare WF316LAS/XAA
tE is mostly related to
temperature sensor wire and connection problem. Look for a broken or loose wire.
Dec 07, 2012 | Washing Machines
Samsung front loader washer Model: WF306LAW
The "3E" error code indicates that a high current is detected.
A "3E" error in a Samsung washer indicates that there is an issue with the motor. Restarting the cycle may clear the error, but a service technician should be consulted if the error code appears again.
Oct 17, 2012 | Washing Machines
How do you install a pump motor on a samsung washer model # WF306LAW/XAA
remove back panel and you should see the pump .remove the clamps on the hoses and there should be 3 bolts securing pump to base, remove with socket, 1/2
Aug 26, 2010 | Samsung WF328AAW Front Load Washer
Samsung front loading washer temperature sensor problem
It may not be your temperature sensor or thermistor. If you have a tE error code on your Samsung washing machine, first check the wiring. My Samsung washer had three visits by the repair tech. and new parts ordered again and again. I looked on a British web site and two people said that it turned out to be wiring broken in several places. Sure enough, I found a broken wire. Technician didn't look for that. Hope it's as easy for you.
Feb 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
75 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
