Question about Toshiba Televison & Video
Toshiba thraterview HD 50a,60 not working. Is it worth fixing
Chicony webcam usb 2.0 PLEASE HELP (TOSHIBA)
Honestly speaking, the cost for USB webcams is so low (around $15 to $25) it is not worth the hassle. Just get a new camera and do not get upset with the one you have as fixing them is not worth the cost.
Mar 10, 2014 | Toshiba Satellite A135-S2276 Notebook
I have 60 inch westinghouse lcd hdtv full hd 1080p hdmi that my son hit screen with cell phone did not crack screen but when you turn it on it shows up like a broken piece of glass and rainbow lines s
NOT worth fixing as the entire front screen unit is called a display panel and the cost of the part (not counting major labor to replace it) exceeds the cost of a new set.
Sorry, but panels are rather fragile and this is fatal.
Oct 26, 2012 | Televison & Video
42 inch flat screen shows black screen with sound only no picture
That sounds like the backlight system or its powersupply has failed. If you can see an ghost like image when close and at an angle near the dge (depends on the light) then this confirms the backlight being the problem.
Repair cost should be about $100. You should be able to get this fixed under warrenty if you have any. If not get repair estimates before doing anything. It should be worth fixing but it never hurts to know if it is getting close to what a new replacment tv is worth.
Apr 23, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Toshiba DLP 60" TV not showing TV programs, sound ok
Have the tuner signal board replaced. HDMI does not use the regular tuner bands, it is bypassed when using hd inputs.
Aug 25, 2009 | Toshiba 52HMX94 52" Rear Projection HDTV
Image green tinted.
TRY VIDEO CONVERSION OPTION IN THE MENU,,IF NOT TRY NEW CONNECTERS
May 15, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Toshiba 46H83 HD Projection TV with distored picture
if you are using an areal for your tv move your areal and see if it works or do the tuning for it .
Apr 19, 2009 | Toshiba 46H83 46" Rear Projection...
Toshiba Satellite M35X-S111 HD crashed
how good is ur knowledge bout laptop mobo is not that simple and do u have the right tools
maybe read this might give u a little idea
good luck
Jun 13, 2008 | Toshiba Satellite M35X-S111 Notebook
Televison & Video Logo
29 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
