Question about Carrier Heating & Cooling
I want to know if i can replace a carrier C024509H01 with a mco mh8-fc thermostat? only 3 cables reach to the carrier thermostat... are they enough to feed the mco thermostat?
  • Thomas Woodburn
    Thomas Woodburn May 10, 2017
    Sorry, I found it. Looks like a basic tstat. Where on the tstat are your wires landed?? What letters, please??
  • Thomas Woodburn
    Thomas Woodburn May 14, 2017
    Looks like the valve will go to O and C. Not familiar with that type, sorry
  • 1,448 Answers
I'm not seeing your carrier tstat, is that the model number?
Posted on May 10, 2017
Testimonial: "The carrier termostat is a 40SMC028N. I looked power directly from the board to feed the new tstat (MCO MH-8) L and N connectors. Then I disconnected the fan connector from the mainboard (INDOOR FAN - 3 cables) and connected it to the MCO HI,ME and LO connectors. I can hear the fans starting when I order it from the new tstat. I hope I'm doing everything well up to these point. Now I need to connect the Valve ON / OFF connectors from the new stat to the carrier and I don't know where to get the signal out on the carrier board (maybe from the CDU connection).Any suggestion??"
  • marbellait
    marbellait May 14, 2017
    I'm taking the signal from the internal board off and connecting the new stat directly to the indoor/outdoor units interconnections.
  • marbellait
    Ceiling Unit Carrier 40SMC028N, Room Controller Carrier EB6005, External Unit 38YY-028G - New Thermostat MCO MH-8-FC
Hood latch will not open
did you ask SUZUKI if there is more than one cable.
some cars have 3 for different body types.
you buy this at suzuki? if not this is common.
Oct 05, 2013 | Suzuki Forenza Cars & Trucks
Oven cooks too fast and burns the food
My electric oven, Garland master 200 only reach a maximum of 250* and I only saw 1 of 3 elements turn red
Dec 14, 2012 | Garland Convection Oven - MCO-NAT Gas
I have the carrier infiniti system. When my thermostat reaches the set temperature it doesn't always shut off. I shut off the main control to let it reset. It works for a while and then it starts
Carrier Infinity system is a variable speed unit that will just slow down as it approaches set point. Unless it overshoots the set temperature (you have it set on 72 and the temperature keeps rising above 72) this just sounds like normal operation.
Nov 13, 2012 | Heating & Cooling
Need to know wiring diagram for IMIT TR2 9325 thermostat
The three connections are labled (C),(1),and (2). (C) is common (useually the white wire). (1) is hot power into the thermostat (black wire). (2) is ran to your heater. So when the thermostat is turned on it will connect (1) and (2) until it reaches tempature. Hope this helps.
Nov 20, 2011 | Cars & Trucks
Displaying E2
E-2 in Carrier Thermostat-Not enough voltage for the thermostat. Contact dealer for further information. Thanks.
Jan 31, 2011 | Carrier TSTATHCP Programmable Thermostat...
My Carrier thermostat keeps running my heater. I adjusted the temp lower but it didn't stop running. I changed the mode to off and then it stopped. However, the mode button was insensitive and I had to...
sounds like that thermostat has reached the end of the road. My advice is to replace the thermostat because its 6yrs old and is worn out due to continued use. programmable t-stats have a wide price range to meet your needs. and the batteries in a thermostat are only for back-up power because the thermostat runs off of a 24volt power supply from the air handler.
Nov 28, 2010 | Carrier Heating & Cooling
1992 mazda mx3 heater blows warm, not hot
If it ran out of water and you filled it up just before the problem started then their may be air in the system so will need bleading. If that's not the problem then could be a sticking thermostat. Vheck these first and let me know if you need further help I can advise further. Cheer's
Sep 12, 2009 | 1992 Mazda MX-3
Cool air from Carrier unit barely blows out vents,unit stays on
undersized is just that...you and I got taken to the cleaners.but i did put an adjustable vent in the cod air return vent duct next to the floor...it helped mine but i say some installers should.....well you know
Aug 04, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Magic Chef MCO 153 UQ heats but doesnt' turn
You can still use it, but must be aware that this is a relatively high power microwave, so food will burn if it isn't turned.
Jul 28, 2009 | Magic Chef Microwave Ovens
Electric immersion heater keeps cutting out
Sounds to me like you have a bad thermostat. You should be able to give a model number to any local plumbing supply place and get one for replacement. make sure power is of the unit before replaceing.
Feb 02, 2009 | Carrier TSTATHCP Programmable Thermostat...
Heating & Cooling Logo
78 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
