Question about Konica Minolta Office Equipment & Supplies
I have Konica minolta 210 copy print karne par halka print ata he
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 79 Answers
TONER RATION IN DEVELOPING IS LOW.
change developer
Posted on Aug 13, 2017
  • 8 Answers
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Posted on Feb 02, 2008
osiriscompu
  • 16 Answers
SOURCE: Konica Minolta magicolor 2430DL
Open the top cover. Remove the drum (part with long green handle). Below the drum you will see a strip of glass about 4-5 inches long. Take a cloth and wipe across the glass.
This will normally clear up any white lines in your print.
Posted on Jul 19, 2008
  • 10 Answers
SOURCE: service manual for KONICA MINOLTA Bizhub 210/162
Swithc off the machine Press stop button and hold switch on the machine. problem will go.
Good Luck
Posted on Jan 07, 2009
taminol
  • 62 Answers
SOURCE: driver konica minolta 210 bizhub for type
Hi plujan,
As far as I am aware, the driver for this product is not available for the 64bit O/S.
I can only suggest trying the 32bit version.
You can find drivers here
http://m-press.uk.com/support.php
Click on Software and Drivers, then use the drop down menus.
Good luck
Posted on Jan 31, 2010
xeerie
  • 347 Answers
SOURCE: i connect the konica minolta bizhub 210 to my win
SOLUTION:- Follow these steps. 1-First of all take a usb cable. 2-Connect its one end to Bizhub 210 and the other end to your computer. 3-you will see your computer will show a notification " Found new hardware". 4-Now insert the printer Driver disc of Bizhub 210 in CD-ROM. 5-autoplay will show at the desktop 6-Now click on "Install Printer" 7-Follow the instructions and install the drivers. 8-when the drivers are correctly installed you will see printer icon of bizhub 210 in "Printer and Faxes" at control panel of your computer. 9-Now right click on this icon and click on "Properties" 10-now click on "PRINTING PREFERENCES" tab. 11-select Paper size, i.e if you are using A4 size in bizhub 210 then select paper size=A4 from the list. 12-now give a print command.ctrl+p. of any document. 13-printer will start printing.
if still having problem, then please do check the usb cable, it may be broken. if there is any other printers are installed on your computer which are not in use then remove them/ delete them. use konica minolta bizhub 210 as a default printer.
Posted on Jun 30, 2010
How to fix trouble code 0910
Unrecoverable error (The count is made by C-5402.)
An abnormal operation accurs when an interupt copy is made (copy print job 1). Estmated defective par Overall control board (OACB).
Oct 15, 2014 | Konica Minolta Office Equipment & Supplies
Is it possible to scan using 210 model scanner by network?
Yes, it is possible ti use Konica Minolta bizhub 210 photocopier as a network printer.For this simply purchase network card Model NC-502 for bizhub 210.
Dec 17, 2010 | Konica Minolta bizhub 180 All-In-One...
Samsung s3310 network problem
samsun s3310i network problem
Nov 25, 2010 | Samsung S3310 Phone
My copier is konica minolta bizhub 210 have problem error code M1. please help me solution.
My Friend You must do general service in your photocopier and then you must program your machine.
Sep 29, 2010 | Konica Minolta bizhub 180 All-In-One...
I connect the konica minolta bizhub 210 to my win xp system then i try to print but i can't the system show the message "failed to print" what is this .please help me
Jun 28, 2010 | Konica Minolta bizhub 180 All-In-One...
41 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
