Question about Dryers
I have cabrio dryer it's been a year Any time I dry my sheets it gets all tangle together And gets wrinkle I like to know how to fix this problem
robbe-zappa
SOURCE: Paper completely wrinkled
I have two HP LaserJet 1300n printers and like all printers after use (or misuse) they will need PM or repair. The problem with the paper wrinkling is easy. If you have worked on printers then you can make the repair for about $8 - $20 and a couple hours. You can find the service manual at HP's website or online. It is typically a roller or the fuser film is torn. Disassemble the printer/fuser in accordance with the service manual or break out pic, clean, replace part and reassemble. For those who do not want to DIY then you can buy the entire fuser assembly on multiple sites anywhere for refurb w/core exchange to new for $70 - $150. The printers are good printers but like all mechanical devices, they will fail...it's just when and how.
Posted on Jan 28, 2007
  • 530 Answers
SOURCE: clothes and sheets come out wrinkled and twisted
Try not to wash large items with small items the large items like sheet will twist around the small item. causeing twisting and wrinkling. Also If you are overloading the clothes or underloading the clothes they will come out wrinkled. I would try to do some testing wash a load of only towels then wash a load of only t-shirts and other light weight items that you may have. Then do just a load of your jeans. What happens? Please let me know
Posted on Jan 11, 2009
  • 7 Answers
SOURCE: close very wrinkled
I have the same problem with clothes being very wrinkled and clumped together after a full cycle. I believe it is not because of the spin cycle, but because the washer using very little water to wash the clothes, so they bunch up easily and are not free flowing. NOW, I try to use the cycle that uses the "Deep Clean" action or I activate it manually with all other cycles. It adds more water to the cycles and the clothes come out wrinkled, but not as much. Try it.
Posted on May 01, 2009
heatman101
  • 43501 Answers
SOURCE: my whirlpool cabrio gas dryer is not heating. it
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Aug 29, 2010
alvin727
SOURCE: Sheets wind together in a damp ball
Same problem here. I have king size bedding that is being dried in a comercial size dryer. The large dryer rolls the sheets or bedspreads into roll tighter than a Cuban cigar. The size of the load made no difference - one sheet or two. What really ticked me off, I just moved from an apartment with one of those tiny washer/dryer combos and never had the cigar roll problem with the tiny apartment dryer - go figure.
SOLUTION:
What works for me is adding dry towels to the load. It even keeps the heavy kingsize bedspread from rolling into a cigar - it cost nothing.
Posted on Feb 07, 2014
Why are my business shirts on a gentle cycle or any wash cycle so badly tangled togther?
Hi Stella,
I suspect the tangled shirts coming out of the washer is a result of the differences between the way a front loader vs a top loader clean clothes and can not be avoided. I don't think this is the source of the wrinkles though. I suspect the wrinkles are more a result of how long clothes remain in the dryer *after* the cycle has completed. If you remove the clothes *promptly* from the dryer and use a "dryer sheet" you will reduce / minimize the wrinkling you're seeing.
Mar 28, 2015 | Washing Machines
Wrinkles clothes terribly. Solutions.
Check your settings on your dryer. See if it's on a longer duration of time to dry. Dryers have different wording depending upon the make and model. If you're trying to dry smaller loads the heat settings s
does not have to be set for very long. Heavier, loads with thicker clothing will need to dry a little longer. When you take the clothes out of the washing machine, do you shake the clothes before putting them in the dryer? And do you use dryer sheets? Believe it or not, they're not only used to help make your clothe's smell fresh but they also help elevate static and a few wrinkles.
Mar 23, 2015 | Washing Machines
No lint on filter? Where is it all going? Checked exhaust vent bought a vacuum attachment and there is no lint. Twice and sometimes triple the drying time! Help!
Instructions
  1. Dryer Does Not Run
    • 1 Close the door firmly. The dryer will not operate if the door is not completely closed.
    • 2 Press the "Start" button firmly or push the knob in to start the dryer.
    • 3 Turn the dial past the "Off" position and away from "Wrinkle Prevent." The dryer will not start in the "Off" or "Wrinkle Prevent" position.
    Long Drying Times
    • 4 Remove the lint screen. Clean it and replace it.
    • 5 Check the temperature of the room. The dryer will not operate properly in temperatures below 45 degrees Fahrenheit.
    • 6 Inspect the area around the dryer. It requires at least 1-inch clearance on the front and sides of the dryer. A 5-inch clearance is needed on the back of the dryer. Move the dryer, if needed.
    • 7 Separate large loads and do not use an air dry cycle.
    Lint, Stains and Wrinkles
    • 8 Clean the lint screen before drying each load of clothes to prevent lint buildup on clothing.
    • 9 Add fabric softener sheets before starting a drying cycle. If the sheets are added after the load has partially dried, they can leave stains on the clothing.
    • 10 Dry small loads and remove clothing as soon as the drying cycle completes to prevent wrinkling.
    Dryer is Noisy
    • 11 Check the inside of the dryer for loose change, buttons or other items. Empty the pockets on clothing before drying.
    • 12 Separate items that are knotted together and restart the load. Knotted or balled up clothing will bounce and make the dryer vibrate.
    • 13 Level the dryer. Turn the leveling legs on the front of the dryer clockwise or counter-clockwise until the dryer is level. Turning the legs clockwise will lower the dryer. Turning the legs counter-clockwise will raise the dryer.
Jan 15, 2013 | Admiral Dryers
Clothes come out extremly wrinkled on top loding whirlpool washer
This is normal. You can try a lower spin setting or smaller loads. The wrinkles will come out in your dryer.
Jan 19, 2009 | Whirlpool LSR5132PQ Top Load Washer
Clothes and sheets come out wrinkled and twisted
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Twisted sheets
dry your sheets separately.
Oct 28, 2008 | Kenmore Elite HE4 Electric Dryer
Neptune dryer
I have the same problem, but I found that shaking the clothing articles out while they are wet before putting them in the dryer, releases the wrinkles before the drying cycle. They come out looking much better. You can also buy a dryer ball, they are balls with hard spikes, they take away static and also replace dryer sheets, they last up to 3 years. Buy them at any Wal-Mart or big retailer. Good Luck!
Oct 10, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Cloths are wrinkled
how old is machine now? they came out with a new wash plate , designed differently to be less aggressive on clothing. part num W10141017
Feb 23, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Dryers Logo
23 people viewed this question
Top Dryers Experts
