Question about Electrolux EOB5630 Ultrafan Electric Single Oven
Electrolux cooler fan
The cooler fan will not turn itself off, I have checked the wiring and found the thermal overload which is directly wired to the coolin fan burned out, would this be why the fan is not turning off.
    Guru:
  • 93 Answers
Absolutely, Never registers when the oven is below a certain temp to shut the fan off. It always thinks it's too hot and the fan will continue to run
Posted on May 15, 2008
Hi, My diplomat df800 dl has an electric fan over keeps turning it's self on (it clicks on every now and again and then turns it's self off. any idea?
https://www.manualslib.com/products/Electrolux-Epee63cs-3049318.html
This web site has your owners manual. It is very vague on this condition so, I will speak in general terms. It may have a cool down function that keeps the fan running till a cooler temp is reached. It could be a malfunctioning controller. Without a wiring diagram, hard to be specific. I would call their help line. It is listed in the manual but it appears to be an overseas number. I have not located a stateside number at this time. So sorry I can not be of more help.
Sep 16, 2017 | Ovens
I have a eob6630 Electrolux cooker. Top element / bottom and work ok. But oven cuts out approx 20 mins when cookin. Then switches off. But comes back on when cools. Approx 20 mins. Can anyone advise about...
From my experience the most common reason for this failure is a thermal switch for cooling fan. It is located on the upper side between the wiring and its function is to switch off the cooling fan when the temperature drops even though the oven is already turned off. If the cooling fan does not work then it will increase the temperature on the cabinet and the main temperature limiter will switch off the oven.
Dado
Jul 01, 2014 | Electrolux Ovens
Oven always switching itself off
Thermal overload has failed. This is a sensor usually with 2-3 wires attached
Oct 19, 2017 | Hotpoint Ovens
Electrolux Gas Oven EOG6330; Cooling fan still on several hours after oven turned off. Solution, please.
hi the change over stat is probably faulty one of the wires from the cooling fan will go directly to it. there are 3 wires on it. just replace it. 311 23 97-00/9 is the part no approx £18 +vat
Feb 09, 2011 | Electrolux EOG6330 Gas Single Oven
The oven works fine as in it heats up but when turned off the cooling fan keeps going...used it last night and this morning the fan is still on...turned oven on and it is heating up but as I said the fan...
most ovens use a cut in limpet themostat(sometimes called button stat) typically normally open and closed at 40deg c. it will be this that will be not resetting to the open position at room temp. on rarer models the timer controls the cooling fan. some models of aeg and electrolux have a thermal delaying device located in abulb in the wiring loom. hope this helps
Aug 02, 2010 | Ovens
Our electrolux eob5630 oven keeps turning off
its the thermal cut out. replace it. ISOLATE oven.
slide oven out a few inches, remove knobs, remove front panel(two screws)
you will only be able to pull panel 3-4" due to wires.
Cutout has 2 blue and 2 white wires..
you may need to snip a couple of cable ties.
Put new cutout in one wire at time( easy to forget where they go)
Tidy up wires. Put cover back. Secure oven in hole.
Turn on power. Reset clock(otherwise won't work)
Done 10 minute job
Jul 19, 2009 | Electrolux EOB5630 Ultrafan Electric...
Fan will not turn off
Hi
you have a faulty cut out stat. if you unplug oven , remove from housing and take lid off
near the cooling fan on top cable tied in the wireing is the cut out . it has 4 wires going in it 2 blue 2white just replace it and will be back to normal hope this helps you
regards dan
Mar 16, 2009 | Electrolux EOC6630 Pyrolytic Electric...
Oven not working
I had the same problem. At the back of the stove is a plastic cover with thermal overload written on it.
Switch off your power.Remove the cover, pull out the two luggs and connect the two luggs straight to each other. Make sure the oven knobbs are in the off position. turn on the power. If your oven clock etc. comes on the thermal overload is faulty and needs to be replaced. It is fixed to the stove by a screw from the inside of the oven, so open the door and remove screw to remove thermal overload at the back of oven. Take sample to electrical shop and replace. DO NOT USE OVEN WITHOUT THERMAL OVERLOAD.
Dec 27, 2008 | Ovens
Replacing electrolux eob944 fan oven grill element
...If you can help me to remove the grill element from my EOB944, I will be able to tell you the wirings.
Nov 17, 2008 | Electrolux EOB5610 Ultrafan Electric...
Electrolux Oven EOB6630, similar to above
Hi, I've had a similar problem with my electrolux EOB4633. I've replaced the "thermal cut out unit" and it's working now. Basically this unit switches on the outer casing fan ( on top in my oven ) to keep the casing from overheating. When the thermal cut out doesn't work it fails to switch on the fan and the casing overheats, the oven then cuts out completely until it has cooled down and the cycle starts again.
The bit to be replaced ( part no 8996619267611 ) is located on top of the oven, under the outer cover, just behind the timer & selector switch. It's a small ( 1inch long ) silicon sleeve with 4 wires coming out of it, just unplug the wires and replace it with the new one ( unplug/disconnect the power to the oven, or switch of the power at the mains switch first ), then remove the oven outer top cover ( all you need is a screwdriver ). You'll see the offending unit, probably tie wrapped to one of the wire bundles, quite easily - mine was blackened and charred.
Jan 29, 2008 | Electrolux EOB6636X Ultrafan Electric...
Electrolux EOB5630 Ultrafan Electric Single Oven Logo
511 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
