Question about Tools & Hardware - Others
Problem with Parkside PRT25-B1 Stapler. No blockage. Just dead when press switch.
I have had this problem before but it seems to rectify itself eventually if I keep trying it over a few days. Staple slide is working ok as well as the nose switch which depresses when pushed down to operate.
  • 32 Answers
SOURCE: Hi can't seem to reload stapler
All you do is open the end peice and slide the staples in on the two rails, point down. You should be able to see in the end to make sure nothing is blocking the rail with a flashlight. You probably have the wrong size staples. You can only use # 214, 215, 276.
Posted on Nov 26, 2008
rowdy45176
  • 2176 Answers
SOURCE: Disassembled the stapler now need diagram to reassemble
Found user manual online but no parts breakdown, I have a phone number at 1-800-343-9329 and they might be to email you the breakdown. Wish I had better info but this is all they furnish online.
Posted on Mar 15, 2009
comax
  • 154 Answers
SOURCE: Depressing top black bar doesn't cause stapler to
There may be a staple or a piece of a staple jambed in the driver. Sometime taking a screw driver and carefully pushing the drive back will clear the problem.
Posted on Apr 14, 2009
  • 4044 Answers
SOURCE: Sliding door(right side pass.) stuck
On the bottom near the open position of the door is a latching mechanism that is actuated by a solenoid. If the solenoid goes bad or the latch jams the door will freeze in that position. I can tell you where the problem is but because of teh way these interlocks work to prevent damage to the electric closing motor I am unable to explain how to by pass them. You should be able to remove the locking latch so you can close the door manually but that will not solve all of the problems. A Haynes repair manual on the vehicle should give you the steps needed to by pass and repair this problem, Chilton's should as well. These are the best sources I can provide for resolving this issue. The Dealer will most likely want a couple hundred to repair the issue if it isn't under warranty, the Haynes manual will only run about $20 and let you do this repair yourself.
Posted on Oct 31, 2010
SOURCE: I can't seem to reload
With the stapler sitting a solid surface, turn it 180 degrees so it is pointed away from you, and you are looking at the back. Press down on the plastic extension that you see (about mid-height on the stapler). This releases the staple-holding compartment (it shoots out the front of the stapler). Reload it with standard staples, push the compartment back in place until you hear a click. Voila!
Posted on Oct 19, 2011
Where to get switch No KJD22-1 for Parkside table saw. steve
Fixya is unable to suggest sources for a Parkside table saw switch.
Apr 10, 2018 | Saws
I can't seem to reload staples into this stapler. I used the staples that came with it and it worked fine. I try reloading and it doesn't staple.
Apr 15, 2011 | Staples One-Touch DX-3 Desktop Flat Stack...
Hi I need a new trigger switch for my parkside 18v battery operated drill Eamonn
Hi Eamon, If you have the user/owner manual for this drill/driver, it may have a schematic at the back to show the trigger switch with it's part number. It may even give you information on where to send for parts. I'm not familiar with the Parkside brand, so really don't know who to send you to for parts. If you don't find the manual email me and I'll shoot you a couple of ideas.
Mar 23, 2011 | Drills
Primer bulb sticks. i ckd behind the bulb and the line was not kinked. what next?
The bulb pulls fuel from the carb, if there is no fuel in the carb due to a blockage in the fuel filter or carb itself the bulb will just stay in, try just removing the filter in the tank to see if this rectifies the problem, if not there may well be a blockage in the carb itself.
Feb 18, 2011 | Homelite Gas, 16 In. Bar, 38 CC, Chain...
HELP PLEASE!!!!!!! dead short in the brown power wire and traced it to the voltage regulator pulled top off and pulled the contacts apart and there is no more arc were i cut the brn. wire and touching...
hi go to the other side panel take it off and check the condition of the rectifier its a finned alloy
component and check for heat damage melting of wires etc if there is its toast find a replacement
I have seen these catch fire
its purpose is to turn three phases of ac electrical charge from the alternator to one dc charge
to the voltage regulator so could be the source of your trouble if it has a dead short
the bad news is that this has happened so often on this model of bike you will have trouble finding a good one to replace it with avoid patern replacements as they tend to be very unreliable
honda cb250 rectifiers are a lot more plentiful and can be modified to fit
Nov 16, 2010 | 1977 kawasaki Z 650
Stapler constantly shoots out staples even when there is nothing to staple.
There is a contact switch / lever on the staplers that engages the stapler when it is pressed. It must be stuck. locate the lever and see if that's the case, and release it if you can. just my 2 cents, because I'm a copier/fax tech -not a stapler expert :)
May 04, 2009 | Office Equipment & Supplies
Everything turns off when I hit the start switch.
Sounds like poor connections on the battery.
TL
Jan 23, 2009 | 2001 Ducati 748 S
Tools & Hardware - Others Logo
Top Tools & Hardware - Others Experts
John Trevino
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
