Question about Seloc Yamaha Mercury Mariner Outboards 2.5-225HP 1995-2004 Repair Manual 1-4 Cylinder, V4, V6, 4 Stroke, Includes Jet Drives with 1 Year Online Subscription - Seloc
20 hp yamaha 2 stroke new water pump still not pumping water to powerhead
Took out thermostat,same as before ! Verified pick up tube in pump assy and inlet screens are clear . Can feel hot air blowing out inspection hole while running !! Possible base gasket or hole in pick up tube further up ???
Waterpump 2002 ford turaus 3.0 durtec
3.0L Engine
VIN S Engine
  1. Before servicing the vehicle, refer to the precautions section.
  2. Drain the cooling system.
  3. Remove or disconnect the following:
  • Splash shield
  • Lower heater hose
  • Radiator lower tube bolt
  • Radiator upper front tube bolt
  • Air cleaner assembly
  • Battery and tray
  • Water pump belt
  • Upper radiator hose
  • Engine vent hose
  • Transaxle 10 pin connector
  • Radiator bypass hose assembly
  • Thermostat housing
  • A/C compressor brace, if equipped
  • Water pump mounting nuts
  • Connector hose
  • Water pump
To install:
  1. Install or connect the following:
  • Water pump
  • Connector hose
  • Water pump mounting nuts and tighten them to 15-22 ft. lbs. (20-30 Nm)
  • A/C compressor brace, if equipped, and tighten the nuts to 15-22 ft. lbs. (20-30 Nm)
  • Engine vent hose
  • Water pump belt
  • Battery and tray
  • Lower heater hose
  • Splash shield
2. Fill the cooling system.
3. Start the engine and check for leaks.
Dec 06, 2015 | 2002 Ford Taurus
2010 yamaha 200 hpdi
Have you replaced all three filters under the cowling?
1. Primary Filter (1st one in the Plastic Bowl)
Reference # 12 in "Prim Fuel" Image
2. Screen on the bottom of the Fuel pump-Inside the VST
Reference # 27 in "VST" image
3. Filter between the VST and the HPDI Pump
Reference # 19 in "VST" Image
Number 2 and 3 get overlooked often, and they are pricy, but they do need to be changed.
If that has been done, the problem most likely is in the fuel pumps
Reference # 24 in the "Prim Fuel" image.
The can be tested by removing them from the powerhead, DO NOT remove the fuel lines, just unbolt them from their mounting leaving the fuel lines attached. Then squeeze the primer bulb until firm. If fuel leaks from the center hole on the fuel pump, Replace them both.
e87e836d-4c03-41b2-984e-2496eb73ed3c.jpg 7cff4158-0f6c-4620-803c-7841ea37bc6a.jpg
Jul 07, 2014 | Boating
1996 yamaha waveraider 700 Thermo Switch Assy what dose it do?
Yamaha 60E-82560-A1-00 Thermo Switch ASSEMBLY ...
? 2:22
www.youtube.com/watch?v=n2DMKPy8mys
Jul 15, 2013 - Uploaded by PartsPak6
Buy Yamaha 60E-82560-A1-00 Thermo Switch ASSEMBLY at: http://www.PartsPak.com/ProductCart/pc ...
Jun 07, 2014 | Yamaha 12V Air Pump
Yamaha 20 hp model 2010 petrol mixing with sump oil . problem came quite quickly at least a half litre increase after about 8 hours runing
Could be too much idling,4 strokes like a good run to get rid of fuel in oil,too much pitch on prop can also not allow motor to rev enough
Aug 14, 2013 | Clymer Marine Maintenance and Repair...
Hot water out of telltail
the real test is to sprinkle water on the powerhead an see if it sizzles.
Nov 18, 2012 | RTO Outboard Motor Bass Fishing Boat Rod...
Overheating yz250f
Hi, Anonymous and the usual suspects are:
1. Low coolant level.
2. Restricted radiator air flow.
3. Faulty thermostat.
4. Coolant pump or fans inoperative.
5. Vent hose crimped.
6. Air in the coolant and needs bleeding.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.vitalmx.com/forums/Race-Shop,42/yz-250-overheating,1216349
YZ250 overheating again Yamaha 2 Stroke
YAMAHA YZ250 LC Owner Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Jul 10, 2012 | Yamaha YZ 250 Motorcycles
Water flow
you will have to strip the bottom end and renew the water pump impeller ,not a easy job if the bolts have corroded up with the sea water ,soak then in engine oil for a day or so before you try
Dec 17, 2011 | Clymer Marine Maintenance and Repair...
YAMAHA 2001 40 HP NOT PUMPING WATER,PUT OUTBOARD DEEP INTO CONTAINER OF WATER,AND FAILED TO PUMP OUT WATER,EVEN AFTER LOW REVS,SWITCHED OFF IMMEDIATELY BUZZER ALARMED
Hi, it needs to have the water pump overhauled and it is not something you should attempt on your own. Take it to someone experienced to have it done correctly. Regards Phil.
Nov 01, 2011 | Light Outboard Motor Boat Bass Fishing...
Older mecury wont pump water
when you install a new pump it will "cavitate" (pump air) unless you pack it with petroleum jelly.
Jul 29, 2010 | Boating
Seloc Yamaha Mercury Mariner Outboards 2.5-225HP 1995-2004 Repair Manual 1-4 Cylinder, V4, V6, 4 Stroke, Includes Jet Drives with 1 Year Online Subscription - Seloc Logo
Top Seloc Boating Experts
Bill Boyd
Steve P
Steve P
Are you a Seloc Boating Expert? Answer questions, earn points and help others
