Do I need to have connections on the upper & middle drain outlets on the rear of my arctic king portable A/C before I turn it on?? I have connected the exhaust vent to the window kit.
  • Heating & Co... Master
  • 1,929 Answers
Not if You are connected to the lowest one, no!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Posted on May 10, 2017
Is there any kinds of problems with this air conditioner
Here are some reviews and questions that have already been asked on Fixya. any appliance that is only used for a few months of the year and then rests for months is going to exhibit some problems eventually. Usually just a matter of getting an AC engineer to add some more refrigerant gas.
  • Amazon.com: Customer Reviews: Arctic King MWK-06CRN1 ... www.amazon.com/Arctic-King-MWK-06CRN1-BJ7-Window-Mounted/product... Find helpful customer reviews and review ratings for Arctic King MWK-06CRN1-BJ7 6,000 BTU Window Mounted Air Condit at ... COOL AIR coming out of the Artic King.
  • Amazon.com: Customer Reviews: Arctic King MWK-05CMN1 ... www.amazon.com/Arctic-King-MWK-05CMN1-BI7-Window-Mounted/product... Find helpful customer reviews and review ratings for Arctic King MWK-05CMN1-BI7 5,000 BTU Window Mounted Air Condit at Amazon.com. Read honest ... by Arctic King...
  • Review of my Arctic King 5,000 BTU Air Conditioner - YouTube www.youtube.com/watch?v=oaB2CPeZLTs
    • BY GOLDENSONIC08
    • 7 MIN
    • 20K VIEWS
    2014-06-09 · Video embedded · Just a quick review of my Arctic King WWK-05CRN1-BI7 5,000 BTU air conditioner.
  • Arctic King 10,000 BTU Energy Star Window Mount Air ... https://jet.com/product/Artic-King-10000-BTU-HomeOffice-Window... This Arctic King Air Conditioner is designed to be installed in a standard double ... This 10,000 BTU window mount Arctic King Air Conditioner is one of the most ...
  • How to Repair Window AC ' eBay www.ebay.com > ... > Heating, Cooling & Air > Air Conditioners A window-mounted air conditioning unit can be a lifesaver for anyone in ... How to Repair Window AC. ... Arctic King 8,000 BTU Energy Star Window Room Air Conditioner ...
  • ACE Artic King Window Mount Air Conditioner 5,000 BTU ... www.fixya.com > Forum > Air Conditioners > ACE Recent ACE Artic King Window Mount Air Conditioner 5,000 BTU Model MWK-05CMN1-B, 1 ea questions, problems & answers. Free expert DIY tips, support, ...
  • ACE Air Conditioner Problem Support, Troubleshooting Help ... www.fixya.com > Forum > Air Conditioners ... Manuals & Customer Service for ACE Air Conditioners. ... ACE Artic King Window Mount Air Conditioner 5,000 BTU Model MWK ... ACE Artic King Window Mount Air...
  • Jun 09, 2016 | ACE Artic King Window Mount Air...
    What size hose should I use for the continuous drain operation?
    1/2 inch hose , --bit of garden hose or clear plastic from the hardware shop
    if 1/2" is too big measure the outlet pipe and get plastic hose to suit
    May 28, 2016 | Arctic King 50 Pint Dehumidifier
    Why did my 5,000 btu artic king air conditioner stop working after having it less than one day?
    Can't answer why as no details as to how it's failed, but if you've only had it a day return it to the vendor.
    you have installed it as per instructions? Is it draining ok? No error codes? Checked the power outlet? Fuses or breakers?
    Jun 17, 2014 | Arctic King MWK-05CMN1-BI7 5,000 BTU...
    Thermostat on 2005 aviator location
    Removal & Installation
    Print
    4.6L & 5.4L SOHC Engines
    1. Partially drain the engine cooling system to a level below the thermostat.
    2. Disconnect the upper radiator hose from the water outlet adapter.
    3. Remove the power steering reservoir upper mounting bracket.
    4. Remove the bolts and remove the water outlet adapter.
    5. Remove the water thermostat and the O-ring seal. Discard the O-ring seal.
    6. Installation is the reverse of the removal procedure. Tighten the water outlet adapter bolts to 18 ft. lbs. (25 Nm). Tighten the power steering reservoir upper mounting bracket as shown in the accompanying illustration.
      Fig. View of the power steering reservoir upper mounting bracket and tightening specifications
      Fig. Exploded view of the water outlet adapter and tightening specifications
    5.4L & 6.8L Engines
    1. Partially drain the cooling system to a level below the thermostat.
    2. Disconnect the upper radiator hose.
    3. Remove the coolant outlet connection, as follows:
      1. Remove the bolts.
      2. Remove the coolant outlet connection.
    4. Remove the (A) coolant thermostat and the (B) O-ring seal.
    5. Discard the (B) O-ring seal.
      Fig. Remove the (A) coolant thermostat and the (B) O-ring seal
    To install:
    NOTE Thermostat must be installed as illustrated.
    1. Use a new (A) O-ring seal to position the (B) coolant thermostat in the (C) upper intake manifold.
      Fig. Use a new (A) O-ring seal to position the (B) coolant thermostat in the (C) upper intake manifold
    2. Install the coolant outlet connection, as follows:
      1. Position the coolant outlet connection on the upper intake manifold.
      2. Install the bolts and tighten to 15-22 ft. lbs. (20-30 Nm).
    3. Connect the upper radiator hose.
    4. Fill the cooling system.
    1. Before servicing the vehicle, refer to the precautions section.
    2. Partially drain the cooling system to a level below the thermostat.
    3. Disconnect the upper radiator hose.
    4. Remove the coolant outlet connection, as follows:
    5. Remove the (A) coolant thermostat and the (B) O-ring seal.
    6. Discard the (B) O-ring seal.
    To install:
    5.4L DOHC Engine
    2. Disconnect the upper radiator hose, the heater water inlet hose and the heated PCV inlet hose from the water outlet adapter.
      Fig. Disconnect the upper radiator hose, the heater water inlet hose and the heated PCV inlet hose from the water outlet adapter
    3. Remove the water hose connection and thermostat.
    4. Installation is the reverse of the removal procedure. Tighten the mounting bolt to 18 ft. lbs. (25 Nm).
      Fig. Exploded view of the thermostat-5.4L DOHC engine
    Aug 13, 2012 | 2004 Lincoln Aviator
    I need to change the thermostat
    REMOVAL
    1. Remove upper intake manifold.
    2. Partially drain cooling system below the thermostat level.
    3. Remove upper radiator hose from outlet connector.
    4. Remove coolant recovery system hose from outlet connector.
    5. Remove coolant outlet connector bolts.
    6. Remove thermostat assembly, and clean sealing surfaces.
    INSTALLATION
    1. Place the new thermostat assembly into the coolant outlet connector, aligning air bleed with the location notch on outlet connector.
    2. Install coolant outlet connector with thermostat in position onto thermostat housing. Tighten bolts to 12.5 Nm (110 inch lbs.).
    3. Install upper radiator hose.
    4. Connect the coolant recovery system hose.
    5. Install upper intake manifold.
    6. Fill cooling system.
    7. see thermostat mounting are below
    Oct 19, 2010 | 2002 Chrysler PT Cruiser
    Heating & Cooling Logo
    41 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Tim Whalen
