Question about Samsung Cameras
Camera Samsung S630. Flash wont work. Batterys Fully charged. Selected Auto Flash.
hardrocko
  • 1476 Answers
SOURCE: Camera will not turn on
Remove the battery for about 30 minutes. This will reset the unit and if it is a software issue it should be OK. You can also try it on the AC adapter in case the battery connector is defective. If reset allows it to work on AC but not battery you have a problem with the DC input connector. If you are good with your hands, have jewelers screwdrivers, magnifying glasses, a steady hand and lots of patience as well as good soldering skills you can remove the cases and repair the input connector. If you are not confident about doing this you will need to seek the help of a reputable repair shop. Hopefully, removing the battery and resetting the unit will solve your problem. Good luck.
Posted on Jul 25, 2006
  • 641 Answers
SOURCE: samsung s630 drivers/vista
As far as I know, you don't have it in the Samsung web site. Contact Samsung and ask them were could you get the drivers for your camera. Enclosed you have the link for it http://www.samsungcamerausa.com/support/contactus.asp Good luck and let us know with your results.
Posted on Aug 19, 2007
hittin1
SOURCE: samsung s630 camera
okay.... Try this if lens is stuck out... look at the side profile of the lens... you should notice the it is not even.. the lens is probably stuck at a slight angle.. GENTLY force the lens to where it looks even... should fix the problem.... worked for me.
Posted on Feb 25, 2008
SOURCE: The view screan on my Samsung S630 camera is all blurry
Hi Guys
Every time I'd try to turn my camera on, it would give three beeps and then go off.
I decided to search your Fixya tips, and I found it. All I needed to do was press and Hold the OK/Menu button while I turned on my Samsung S630 camera and it worked!!!!!!
Thanks for the tip, and I hope Someone else will get the same benefit
Elizabeth Flood
The view screan on my Samsung S630 camera is all white looking and blurry! The photos that I take look the same.
Any tips will be most appreciated.
Elizabeth Flood
Posted on Dec 05, 2009
SOURCE: My samsung ES55 camera wont switch on and its
I have a Pink Samsung ES55 and The first time I pressed the power button it turned on. However when i went to turn it on the second time by the power button it didnt work. I tried to charge it again and it didn't work by this time I thought I'd broken it or something but then i pressed the bottom play button in a square/box twice and it came on I was so seriously relived. :) hope I helped
Posted on Mar 10, 2010
Camera Samsung S630. Flash wont work. Battery's Fully charged. Selected Auto Flash.
Bob,
Why persistently post the same query ? This will not get you faster or different responses - in fact, the reverse.
May 10, 2017 | Samsung Cameras
My Samsung S630 Digital Camera doesn't flash after a series of picture taking. Now it fails to flash although I set in Manual mode and selected Flash manuall, but still t doesn't flash. What should I do?...
Hi there remove the memory card and reset the camera. Now turn on the camera with out the memory card and make the camera flash light ON mode and take a snap. If the flash not working after this setting, then you need to replace the flash tube. The flash tube is cut off and thats why its not working.
Feb 19, 2011 | Samsung Digimax S630 Digital Camera
Kodak C340 I installed new batteries and docked it over night and the camera still dose not turn on
with new batterys you may find if quicker to charge them in a battery charger and not in the camera,,,the camera charger is for "topping up" the batterys realy not fully recharging them its so you can leave the camera on its docking port and it will have fully charged batterys in it when you wont to use it,, to fully charge a new set of batterys it could take days,,,,so overnight is to short a charge to recharge them,,,leave the camera on its docking station for a fuw days at least, or use a home charger for your type of battery ie:AAA or AA, both take 16 hours to recharg fully
Feb 16, 2010 | Cameras
My camera turns on but the capture button stopped
Be sure you have fresh batteries or fully charged rechargeables. Go into the camera menu and find "reset"...follow the on-screen instructions.
Dec 31, 2009 | Samsung Digimax S630 Digital Camera
Samsung s630 flash doesn't work
At this price point, they really are not worth investing time and labor required to attempt repair. Sometimes it simply makes more sense to dispose of the old and purchase new.
Feb 25, 2018 | Samsung Digimax S630 Digital Camera
Samsung S630 Flash Problem
Does the flash fully charge?
If so, it may be that the flash tube is faulty and will require replacing.
This should be done by your authorised Samsung repair centre.
Nov 02, 2008 | Samsung Digimax S630 Digital Camera
Flash wont work
According to the symptoms it seems that the capacitor of the flash unit is not charging properly.So, you have to change the flash unit.
Thanks & Bye
And dont forget to rate the answer.
Oct 08, 2008 | Samsung Digimax S630 Digital Camera
My samsung wont turn on
It's not the camera. Are your batteries suggested for digital camera use? Have you checked the expiry date? this camera is quite the battery ****- even if your batteries show up as fully charged, a lot of brand's don't have enough power to support this camera, so MAKE sure you buy good batteries.
Jun 30, 2008 | Samsung Digimax S630 Digital Camera
S630 wont turn on
I have this camera and mine did the same thing. YOU SHOULD DEFINATELY TRY DOUBLE AA RECHARGEABLS. I know you probably have ehard that they're no good, bubt my camera works for days if i fully charge the batteries, So, try some new and FRESH batteries for your camera.
May 26, 2008 | Samsung Digimax S630 Digital Camera
Flash not working
Flash not working seems to be an ongoing problem with this model. Contact customer support at samsungcamerausa.com and fill out a repair request. My camera is also an A402 over 2yrs old and supposedly they are going to repair the flash free of charge. You'll have to pay to ship it.
Sep 24, 2007 | Samsung Digimax A402 Digital Camera
Cameras Logo
55 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
