Question about Cameras
Flash wont work
Battery fully charged. Selected Auto Flash
  • 4 Answers
SOURCE: Flash is not working
The flash icon appears in the upper left corner of display or it appears as circled flash icon? If flash is open and appears a circled icon, then there’s a malfunction contact that don’t communicate to the camera that the flash is open. Your camera needs service! Be sure the upper part of the flash is unfolded, pointing directly in front of the camera (not downward), because the sensor is just in this second folder. If the icon is not circled, press the right arrow until only the lightning symbol appears (forced flash). Try a shot! If the flash doesn’t pops, then your camera needs servicing (burned or broken lamp or other malfunctions).
Posted on Oct 16, 2007
SOURCE: Sony Cyber-Shot DSC-F707 ...No flash.
Mine started to do that too. I charged the battery and then played with it taking the battery out and placing it back in and it just started to work again. Try placing it in manual mode as in shutter or appeture, rather that automatic and see if it makes a difference. These are things i played with before it started to work again.
Posted on Apr 16, 2008
SOURCE: logitech pocket digital camera
Same happening to me. The solution is to try it in a different USB port, as it is a USB related issue.
Posted on Jul 21, 2008
SOURCE: "Charging Flash"
i just posted the same problem a few minutes ago and now i have the solution!! got to this link http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=437509&lang=en
download the driver if needed (the firmware installation will tell you if you need it) and then download the firmware. immediately after i downloaded the firmware, the "charging flash" went away! hope it works for you too~
Posted on Aug 05, 2008
  • 998 Answers
SOURCE: Dell latitude D600 battery charge light flashing
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 09, 2008
Camera Samsung S630. Flash wont work. Battery's Fully charged. Selected Auto Flash.
Bob,
Why persistently post the same query ? This will not get you faster or different responses - in fact, the reverse.
May 10, 2017 | Samsung Cameras
Nikon coolpix s9500 flash will not fire
You've tried shooting in a dark room? With a fully charged battery? With the camera set to "auto"?
Oct 17, 2014 | Cameras
Canon t3i will not fire
Have you got the camera set for mirror lock up. Check and disable if appropriate. When mirror lock is selected the first press of the shutter button moves the mirror up the second press fires the shutter
Mar 23, 2017 | Canon EOS 600D Rebel T3i Digital Camera
I just bought a canon powershot sx120 is today. I can't get the flash to work. I lift the flash and once in about 20 tried it goes off but other then that it won't even take photos if the flash is up.
If the flash is on AUTO it will only fire if it needs to, such as in dim lighting.
Try putting the flash to ON mode and see what it does.
More likely this is a power problem.
It needs fully charged batteries to fire off the flash very well. If it "won't even take photo's" as you said that usually means there is not enough battery power to charge up the flash, so the whole camera is stuck until it gets done charging the flash.
This issue could be from using Alkaline batteries, they are not very strong and can't keep up with the power needs of a camera.
So if you haven't yet -- try some fully charged NiMH rechargeable AA batteries and it will probably run fine.
Aug 12, 2010 | Canon Cameras
I have a HP Photo Smart R707 with a fully charged new battery and the flash won't work. Keep getting charging flash. Any help on this?
The flash mode has to be set.
There are 5 flash modes:
  • auto - flash fires when needed
  • red-eye reduction - flash fires when needed, but there's a pre-flash to minimize red-eye
  • flash on - flash always fires
  • flash off - flash never fires
  • night - flash fires if necessary (and uses red-eye reduction) to illuminate foreground objects, but shutter stays open to record the background by ambient illumination
http://www.bobatkins.com/photography/digital/hp707.html
Aug 11, 2010 | HP Photosmart R707 Digital Camera
How does the Sunpak Auto 555 Thyristor Flash Unit work concrning a battery? Does it always need the ourside battery pack unit also?
When internal cells are fully charged it do not need external ones
http://www.photographyreview.com/mfr/sunpak/flashes/PRD_84012_3121crx.aspx
Aug 07, 2010 | Sunpak Auto 555 TTL Flash
Why wont camera flash when taking pics? I have new batts
select the flash mode properly ,fully charged mode/auto charged if u do not get fired the flash unit is defective,to be replaced
Mar 02, 2010 | Fuji FinePix A340 Digital Camera
My Olympus FE 360 is less than 6 months old and the flash just stopped working. is it possible that there is a ''simple'' reset or fix/test?
There is no reset or fix test. Just ensure that the battery is fully charged, and replace the battery. Replacing the batteries already reset the camera.
Ensure that you have selected Flash on the menu and shot a picture. If the flash does not start, then usually the small pcb that supplies power to the flash has a blown capacitor.
In that case call Olympus number listed on the owners manual. They will give you instructions to validate the warranty and get the camera repaired.
Regards.
Jul 20, 2009 | Cameras
No Horn
sounds like you have a dirty or missing ground connection or a fuse that's bad. the ground problem is usually best left to a technician (it can get pretty involved, but the fuse is a quick check and fix you can look at it and see if it is blown and get a new one at any auto parts store.
Feb 19, 2009 | Gilera Runner VX 125 Motorcycles
Auto flash not working right
This is actually a repair issue with the flash charging indicator switch. It needs to be replaced as it has failed. You can call Olympus Customer Service to discuss their repair policy and preocedures. Their telephone number is 800-622-6372 option 2 and then option 3.
Feb 17, 2009 | Olympus Camedia Stylus 300 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
