Question about Food Processors
How does the safety pin work in the 14056 handle of food processor ?
2 Suggested Answers
  • 145 Answers
SOURCE: Need to clean inside of handle on KitchenAid food processor
The plastic for the work bowl / handle is molded and one piece and cannot be disassembled. My best recommendation is to call Kitchenaid customer service to see what recommendations they have. Within one year warranty, they may replace the work bowl at no cost.
Their toll-free number is: 1-800-541-6390.
Posted on Jul 07, 2009
HOW CAN I TELL WHICH PART OF THE PROCESSOR NEEDS REPLACING WHEN IT WON'T CONNECT
Difficult to tell as I could be a few things.
Motor
Safety interlock
On Off switch
Check the safety pin or whatever stops the power unless the bowl and lid are fully in place. With the blade and bowl off you can defeat the safety by inserting a pen into the hole if it has one or a teaspoon handle into the slot if it has one.
I am a chef and in a commercial kitchen, home type processors last 15 months to 2 years max.
Even if you find the problem your problem will be finding spares unless it is a top brand.
Jan 27, 2016 | Food Processors
Pin dislodged in handle
KitchenAid Food Processor Parts
find your processor here and find parts
ereplacementparts has all kinds of parts available!!!
Apr 04, 2015 | KitchenAid 12-Cup Food Processor Chef&39;s...
Cannot turn the lid on to kitchenaid food processor
It sounds like you need a new working bowl. It is not uncommon for that safety switch mechanism to fail inside the handle.
Jan 29, 2013 | KitchenAid KFP500 Ultra Power Food...
The motor on our B&D PowerPro II food processer runs but does not spin anymore. Can this be repaired?
If the lid is not locked in place it will not work. It's a safety feature. Verify that you've got it latched in tightly under the handle.
Oct 03, 2010 | Black & Decker FP1510 Food Processor
I have a Cuisinart 14 cup food processor which will not turn on
Hi-
We have a Cuisinart and these tools are very rugged- so I doubt that the motor is bad. My only suggestion would be to make sure that the safety catch is being actuated when you click the cover clockwise to secure the mixing chamber. There is a hole in the housing that the acuator pin sticks into to disengage the safety switch. Perhaps the switch is not being pressed off.
Hope this helps,
Jeff
Oct 28, 2009 | Cuisinart DLC-7SFP Pro Food Processor
My kitchenaid processor is not working
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. I am thinking this is an issue of assembly because the light is on, so the unit is definitely getting power.
Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
Jul 29, 2009 | KitchenAid KFP715 7 Cups Food Processor
KitchenAid Food Processor 770 won't run
I am assuming the unit is getting power. The "power" LED should be lit up on the front of the unit.
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. Proper assembly is below:
If this has not resolve the issue, please ensure the outlet is receiving power.
If the unit is still not functioning, take a close look at the bottom of the work bowl where it meets to the motor base. The work bowl, when locked in, depressed a gray plastic peg. This is the safety mechanism. You may trying depressing this peg on your own with a pencil. If this activates the motor, this may indicate your work bowl is no longer seating correctly.
Also check the work bowl handle to make sure nothing is cracked. There is a plastic assembly in the handle that acts as a second safety feature.
If either of these things seems to be the culprit, I would suggest seeking a new work bowl or work bowl lid to correct the issue.
Jun 18, 2009 | KitchenAid KFP670 Ultra Power Food...
Motor runs but switch won't activate despite new parts
Make sure the handle of the bowl is facing the front of the food processor. Place the lid tab just to the left of the handle and slide it toward the handle until it won't turn anymore. Remove the pusher sleeve from the lid and reinsert it with the lock facing the front of the food processor. Slide the lock into the locked position. If it still doesn't work, replace the third piece on the work bowl - the one piece that you haven't replaced. It will then work.
-Tha Mp3 Doctor
Jan 10, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Product won't turn on - safety feature appears broken
I went through the same thing...as it turns out, everything was locked into place but I had the handle in the back rather than the front where the sensor is. Good luck. I hope that helps you.
Dec 17, 2006 | Cuisinart DLC-2011 PowerPrep Plus Food...
Food Processors Logo
66 people viewed this question
Top Food Processors Experts
eyecam
Are you a Food Processor Expert? Answer questions, earn points and help others
