Question about Casio Office Equipment & Supplies
CASIO Calculator HR-100TM. How do I just us it as an adding machine?
The Add & = key are combined. How do I get it to operate individually. Also when I enter the first number and the the minus key the the number I was to subtract the press the - key it doesn't work.
SOURCE: Set Tax rate on a Casio HR-100TM
Press the CA button twice. Then push and hold down the %/set key until the 0 dissappearsd and reappears. Then type in your tax rate and the percent key (eg: 8.25%) and then press the TAX+ key. It should save the new tax rate.
Posted on Feb 25, 2008
  • 6 Answers
SOURCE: Tring to subtract
With an adding machine, which is what this is, you enter the number followed by the + or -. If you wanted to add 10+20, you would enter 10 then + then 20 then +. This would show your answer. If you are using the printer and you wish to see the final answer on the paper, hit the * key and your answer will print.
If you are subtracting, let's say 100-40, you would enter 100 then + then 40 then - then *. Adding machines expect you to enter long strings of numbers to total. You may have both positive and negative numbers. So, you always enter the number first followed by either positive + or negative -.
You might have 100 + 25 - 37 - 1 + 50. For that enter:
100+25+37-1-50+ then *
Different than a calculator but the same for all "adding machines". This machine should really be called an adding machine since that is the kind of input it is looking for.
Posted on Feb 04, 2009
SOURCE: how do you subtract
Its a little strange. Suppose you want subtract 10 from 38. Do this:
Enter 38 press plus key.
Enter 10, press minus key.
Press the equal sign. You will have the result.
Posted on Oct 22, 2009
SOURCE: THE CASIO HR-100TM HAS AN E ON THE SCREEN AND
First, check the batteries, and ensure there is not a paper jam in the printer.
If both are fine, then while the calculator is in the "Print" mode, press the [CA] (or [AC]) button 20 times consecutively to clear out memory buffers. Try some numerical calculations, and if the problem persists, repeat pressing the [CA] button 20 times.
If the problem still persists, then the calculator may require service.
http://www.casio.com/support/techsupport/AABF4C3A-D2EF-4BF5-B349-48459AF35FF0
Posted on Mar 01, 2010
SOURCE: how to load paper in
Put the roll on the arms "like a toilet paper roll on the extender", and pull it under. There is a slot, slip the paper into this slot, and press FEED until the paper reaches the ink.
Posted on Sep 21, 2011
What does the MU/MD key on the Casio HR-100TM do?
Here's how to use the MU/MD key. Say you want your item that COSTS you $120 to be priced such that you end up with a 40% margin. MU'MD calculates the final price to achieve the margin.
Enter: 120 X
Enter: 40 MU'MD
Result: 200.00
Proof: 200 - 120 = 80 / 200 = 40%
Essentially the same as using the COST/ SELL/ MAR keys.
The Casio HR-100Tm manual is pretty pathetic. Expected a better one on their website, but alas.
Jan 03, 2017 | Casio HR-100TM Printing Calculator - 12...
Where can I find a user guide or manual for the Casio HR-100TM calculator?
Couldn't find a manual or user guide. The closest I got were two pages, one with the calculator, and one with the group of calculators that explains some of the functions.
If you have a specific questions, please ask.
Good luck,
Paul
Mini printer Compact Type Printing Calculators Calculators CASIO
http://www.casio-intl.com/asia-mea/en/calc/printing/miniprinter/product_list/?m_no=145
May 14, 2016 | Casio HR-100TMPlus Calculator
How do I change the print head on HR 100TM casio calculator
You grasp it and then pull as hard as needed to remove it. next, shove the replacement into the space the removal revealed. Easy. huh?
Mar 18, 2016 | Casio HR100TM 2-Color Printing Calculator
I cannot fine a manual or user guide for the Casio HR-100TM Calculator
You can try this site to download a copy, however my McAfee blocked it when I tried to download it??????? You will try this at your own risk!
http://filesfromtheworld.net/casio-hr-100tm-user-manual/
Feb 23, 2015 | Casio HR 100TM Portable Printing...
Replace ink roll for Casio 100TM
Should just be a matter of lifting up the lid, removing the old roller and replacing it with a new one. That's how mine works.
Oct 10, 2014 | Casio HR-100TM Two-Color Portable Printing...
How do I programed sales taxes on my adding machine?
Sorry it took so long. I had to research and this what I found posted:
Traci Lopez
  • Moderator
Press the CA button twice. Then push and hold down the %/set key until the 0 disappears and reappears. Then type in your tax rate and the percent key (eg: 8.25%) and then press the TAX+ key. It should save the new tax rate. Posted on Feb 25, 2008
Sep 21, 2014 | Casio HR 100TM Portable Printing...
How do I get a casio hr100tm to print the total?
Once you enter your number like so (5.00 press (+) 11.00 (+) 5.00 (-) then press the *key, should be bottom key next to + = key). Hope this helps, sorry to be so late with an answer.............
Jul 22, 2014 | Casio HR 100TM Portable Printing...
Casio hr-100tm ink roller
Check to see whether a fragile plastic roller pin or retainer has broken off. Also, a piece may have fallen out when the old roller was removed.
Aug 30, 2012 | Casio "HR-100TM Two-Color Portable...
Where is the subtotal key on the Casio HR-100TM?
The subtotal would be the last item you see on the display.
Despite my best searches I am unable to find a manual. This seems to be an Asian model.
Jan 09, 2011 | Casio HR-100TMPlus Calculator
Jan 05, 2008 | Casio HR-100TEPlus Calculator
Open Questions:
55 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
