Question about Hardware & Accessories
My melnor water time is leaking all over is it due to freezing? what can I do about it?
  • 2,414 Answers
Buy new one is better the fix. There is one time product
I don't think they make any replacement part for it.
Good luck
Posted on May 10, 2017
Melnor Aquatimer leak
The seal inside the timer is defective.
Jul 06, 2017 | Refrigerators
Melnor sprikler not ocillating
Do you have hard water? They operate via a water pressure powered mechanism, either the mechanism is stuck and needs a push, there is insufficient water pressure, or it is clogged with sediment.
Jul 10, 2016 | Melnor Oscillating Sprinkler
I have a Melnor 3015 aqua timer (2007 model) that leaks. I am fairly certain it is the connection between the solenoid and the valve but I cannot figure out how to open the thing without breaking the
It's made that way. The case is not meant to be opened, it's a sonic weld (melts the plastic together). It's meant to be a disposable device; it breaks throw it away and buy a new one. Also known as planned obsolesce.
Jan 24, 2015 | Melnor 3015 6 Zone AquaTimer
Melnor 4 zone aqua timer dosent follow program
Water timers and Melnor timers last a year or two. They come with 1 year warranty for defects in workmanship.
Change batteries, reset timer if there is a reset protocol, buy another timer. Melnor, Orbit, are major brands. Gardena is not supported. Yardworks repackages other brands.
Copy following link for all watering and irrigation timers on market, with links to manuals for each brand:
Add a comment and say what you find.
Jun 20, 2013 | Aqua Hardware & Accessories
Melnor water timer
Melnor is major water timer company, and not off-brand. However, water timers last a couple years, or less, sometimes they last long time but that is not often.
If not drained completely of water, they will break when water freezes.
Copy following link to identify all water timers on market today:
Most timers have 1 year limited warranty for defects in workmanship.
Jun 05, 2013 | Hardware & Accessories
How do I get free instruction for Water Timer Vigoro Duo- Deluxe Water timer # on front top lefte is 225-379 # on back is 0708
The vigoro duo delux might be same as Melnor 3100
Open following links:
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 02, 2011 | Hardware & Accessories
Verve Digital Water Timer as sold at B&Q have lost the operating instructions.
Verve water timers might be Melnor:
Open following link for manuals.
Links to other water timer manufactures and manuals are found on following link:
Jun 14, 2011 | GARDENA Water Timer
I need a water proof outdoor time for my overhead drip system. Each season I end up buying a new one. My vigoro 196-036 appears to have frozen and busted an internal gasket. Any suggestions
Water timers are made of plastic.
If water is inside any plastic fitting, and there is a freeze, then plastic will crack.
Raindrip, Melnor, Gardena drip systems are made of plastic.
I don't know anyone making a brass drip timer that could expand instead of crack, because the expansion would damage timer shut off valve.
There are 2 strategies to solve problem:
1) Remove timer from cold area during freeze.
2) Wrap heat tape around timer so it will not freeze.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 29, 2011 | Hardware & Accessories
Lost directions to set timer Melnor 604 F
Melnor 604F Instructions (from Label on unit)All indicator light flashing - replace 9V battery inside unit
1. To Start - turn dial to Off and press Enter.
2. Set Time - set current time and press Enter (Yellow ring).
3. Set Start Time - Set time to start first irrigation cycle (Yellow ring) and press Enter.
4. Frequency - Set frequency of irrigation cycle; e.g., twice a day set 12 h. (red sector ring) and press Enter
5. Duration - Set duration of cycle (Green band) minutes and press Enter.
To change duration - turn dial to new duration and press enter.
To turn water on manually - Turn dial to ON position, water will turn off in 30 min.
Do not press enter in the OFF position as the unit will clear program. You will have to reprogram unit
via steps 2-5 above.
Jan 31, 2010 | GARDENA Melnor/Gardena 101 Flowmeter Water...
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
